Question about Sub-Zero Bottom Freezer Refrigerator
550 Ice Maker Making Hollow cubes or Small Cubes
Ice maker is making hollow cubes and small cubes that are getting caught in the mechanism. any idea if the whol ice maker has to be replaced or can I buy a thermostat? Thanks
  • Anonymous Mar 15, 2014
    can you clean the ice cube maker
  • Anonymous Mar 25, 2014
    Ice maker does not turn off but continues to make ice with or without ice container.
Hollow cubes are usually a result of lack of water supply
Posted on Jul 19, 2008
Frigidaire side by side with ice maker .. ice maker jams and quits making ice
Hollow ice cubes are a result of lack of water to ice maker. This can be caused by lack of water pressure (clogged filter, bad water valve, obstructed fill tube, etc..) you will need to find the cause to correct this hollow ice cube issue. The ice maker should take on 5.5 oz of water when it cycles (2/3 cup). Mot of the time its a water supply issue and the line could be kinked behind the unit as it was rolled back into place.
Good Luck
Dec 30, 2013 | Frigidaire FRS23H7CS Side by Side...
Why are the ice cubes from the ice maker hollowed out in the middle?
in the ice maker there is a series of small pipes about an inch long emersed in a tray of water,the gas flows throught these pipes frezzing the water making the ice and thats why its hollow in the middle
Aug 26, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Making hollow ice cubes
Hollow ice is a sign of not enough water going into tray . Replace the water inlet valve (piece that the wall water line connects to on refrig ) .
Aug 29, 2009 | Refrigerators
Ice maker makes hollow ice cubs or cubes with
Whats happening is the ice isnt freezing all the way. Try cleaning your condensor's under the frig.In Hotter weather when condensor's get filled with dust it causes the frig to cycle to ofeten. In turn your cubes aren't freezing all the way.
Jun 26, 2009 | Whirlpool Refrigerators
Ice maker is afflicted
Hello there. Sorry for your trouble. Your problem is common. I will try to help u. here is some information to get you started:
If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Get back and let me know if this helped and what is still a problem.
May 21, 2009 | Refrigerators
Ice cubes are hollow.
some fridges are designed to make hollow cubes where they always hollow or just recently
Apr 13, 2009 | Refrigerators
Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
Nov 05, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker making hollow cubes
check your incoming water pressure, change the water filter recently? hollow ice cubes is a sign of low water pressure
Mar 05, 2008 | Refrigerators
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
Admiral Refrigerator makes hollow ice
Hollow ice cubes are due to low water pressure to the fridge. Water thru the door should have good pressure behind it. This is a good indicator of water pressure. Should be able to fill a glass quickly. Causes for low pressure are self-piercing saddle valves on the water line (switch to drill type (1/4") valve) or reverse osmosis system or filtering system on water line to the fridge. R.O. systems should not be used. Increase water pressure and that will fix the hollow cubes. The loud noise may be the sound of the water valve on the fridge when it is acivated. This sound is normal and some are louder than others.
Oct 05, 2007 | Admiral 26 cu. ft. Side-By-Side...
Sub-Zero Bottom Freezer Refrigerator Logo
1,116 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
