Question about Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum
It is me again...
Ok, thank you for the help! I did have the top off, but did not know the taking the motor loose trick, thank you for that! Now I have a couple of more questions, and thank you so much for all of the help! I got a belt from sears, & the sales guy sold me an off brand belt. It looks just like the belt that broke, although do you have to force the motor back down into place? I think it may be the wrong belt? I have looked on the Hoover website & they do not even have parts listed for this vacuum? Is this the timing belt, or do you by chance know the model number? Thanks :)
  • 1,673 Answers
If it a Savvy, then it is the timing belt, part # 91001028. If this is a V2, then there is no belt.
Posted on Jul 20, 2008
The motor on my carpet tool (beater brush) stopped running yesterday. The main vacuum still works, but the switch for the carpet tool just clicks and doesn't turn it on.
Knowing the model would help.
Possible problems:
Broken or disconnected wire in hose, connections, power nozzle.
Hose needs replaced. Check all connections for discoloration and cracked supports. Have power nozzle checked at a vacuum shop. Depending on the model, take it to an authorized Aerus Electrolux store for this.
Bad power nozzle motor Needs replaced.
Bad switch. Take the whole machine in for thorough check and repair..
Jan 25, 2011 | Electrolux Vacuums
I can't remove nut from end of vacuum.
The nut is reverse threaded . If you hold the fan with one hand use a ratchet to loosen the nut, you will have good enough leverage to break it, but if you don't then here's a little trick....Take your vise grip pliers and clamp it to the belt end shft of the motor. Now with your worktable (or floor) brace the vise gripped motor shaft . with the ratchet, turn the nut to the right. Like you're tightening it. this should be sufficient enough torque to bust that nut. I hope I was able to help you , let me know. Thanks, Rene (the Vacuum Doctor)
Nov 12, 2009 | Vacuums
Kenmore 3.9 with power-mate Model 116 2839581. Can't locate screws to allow cover removal for access to motor
You have to take off the top of the power nozzel that has the light lense. There are two pressure locks,one on each side. Use a screw driver to release. You will see the screws.Take the two screws out and on some models, there are two pressure locks on the back of the nozzel. Again use the screw driver to release. The top should come right off.Hope this helps.
Oct 18, 2009 | Kenmore 22313 Bagged Canister Vacuum
The dealer told me my problem is its over heating
there should be screws on the top of the base take them out then the cover should come off.ther there are 2 screws on both sides of the motor that hold it to the base.take them out then you are at the motor.look at the motor casing and you will see screws 2 on top and 2 on the bottom that will take the casing off the motor.use a small paint brush to clean the motoe and casing
Mar 07, 2009 | Eureka Whirlwind 4496 Bagless Upright...
DC15 Animal brush motor not working?
Just had the same problem. Switches and motor checked ok, then found the circuit board on the left hand side of cleaner. The fuse (on the board) looked ok, but when removed and checked for continuity I found it had blown. The problem I have now found is that the fuse cannot be ordered only the complete board. Hope it gets the brush roller going again.
Mar 01, 2009 | Dyson DC15 All Floors - The Ball Bagless...
I'm not really a technician, but I used to sell Filter Queens and was taught how to maintain them, and have tackled "fixing" some problems. I am a 71 year old great-grandmother of 8, but have good health...
i just took my old majestic apart to fix the motor
on mine, when you open the top of the machine where the exit hook up is
you take out those three screws
the top case comes off and you can get to those three screws and alot more of the motor as well
Good Luck !
Feb 25, 2009 | Filter Queen Majestic Canister Vacuum
I am not sure what exactly you are referring to but I think that it may be a motor lead.
See pictures below (shown is white but second wire to the motor is black)
Oct 30, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Belt type
The belt number is 91001028. The belt will be snug but not real tight, so the belt you got may not be the right one. Most repair shops for vacuums should have this belt in stock.
Jul 12, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Screw rusted; cannot remove
ok for one, once you remove the screw hopefully you havent damaged the armature, which is the most important part,,,,1. get vice grips 2. try to get something to lock the sides down, ......question first, do you know if it works, if it does why are you taking the screw off, also if it doesnt its unfortunately probaly not worth fixing, if you need parts off of it just crush the side open..... if you come across another unit that has a screw loose, use silicon on the bolt and screw it will help keep it from rusting...
Jan 25, 2008 | Rainbow 75th Anniversary Canister Vacuum
Brush belt came off my Bissell ProHeat
take the bottom cover off the machine so you can see the brush that the belt drives, you have to take the brush out next. slip the belt on the brush then set the brush back in you should see where the belt hooks up to the motor, now heres the trick they are all different here some belts are put on where they are straight like a car it just loops both sides. put it on this way first if the belt is very loose when installed this way, it means you might have to twist it half a turn for it to be on right, you will be able to tell though. because if its loose it wont turn the brush. i think you can handle it.
Oct 03, 2007 | Bissell 8910 ProHeat Clear View Upright...
Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum Logo
52 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
