Rank: Guru
Rating: 91%, 827 votes
With your access to help at work, this should be pretty easy.
Any repair is DONE AT YOUR OWN RISK.
Consult with your work mates after reading this through.
Disassemble the parts in a row representing the order of assembly and take a picture of them from different angles.
Take each orbital gear and hold four fingers down on this at the ordinal points of a compass rose. See if you can slip a feeler gauge under any portion of the ring and where, mark the center of this area with a dot from a Sharpie.
All the ring gears that you can slip a feeler gauge under and have marked may need to be replaced but, you can try the below first..
Take a block of maple slightly larger than the largest ring gear, hold the ring down on an actual flat steel surface and then hold the gear down firmly with the maple block by another block of wood, Tap this firmly with a rawhide hammer until the ring gears are all flush and you cannot slip a feeler gauge under the previous dots you placed. Do this carefully and slowly so as not to crack the ring gear. Check the ring again with another run at it with the feeler gauge and repeat this process until you succeed with all rings and the feeler gauge test.
Now you have to address the mounting point at the camera. Run the same feeler gauge test on it. If this is not flush you really have a problem that you should consult with your work mates. I'd say reassemble the lens, mount and use your hands to re-seat the mount point so it is flush and perpendicular to the range finder body versicle axis. This is where your workmates come in, they may have a sensible solution for this point in the process
Regards,
Worldvet
Comments:
Jul 24, 2008
- I"d say from your latest comments this is an alignment issue. There should be internal set screws to align the receiver lens that you can adjust to adjust the long range laser return setting.
If you've no doubt looked for and cannot find one, I wonder what Nikon felt they could do for you other than giving you a refurbished model for that price, which may be better than buying a replacement for this one.
