Whirlpool MH1150XMQ Microwave Oven Logo
Posted on Jan 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kid put mom's curling iron in microwave. Turned it on and now nothing. No lights, nothing. Is there a fuse to check? Maybe it is too far gone? Thanks
Anonymous
Level 3:
President:
  • Master 1,654 Answers
  • Posted on Jan 11, 2011
Anonymous
Master
Level 3:
President:
Answers
1654
Questions
0
Helped
598078
Points
5047
There is very high voltage present even when disconnected from mains. unplug from mains & leave for 1 hour. remove cabinet. there is a fuse which controls everything usually located near the transformer or where the mains cable enters. check fuse and replace. it needs to be the correct fuse for the appliance
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Once you remove the control panel assembly, the fuse is located in a holder behind that area toward the top. The tech sheet shows part locations
GE Profile Microwave, model JES2251SJ02, just stopped working.
1= reset the c.breaker from your home see if are tripped and reset.
2= open for thermal fuse open, test continuity with DVOM OR VOM and replace.
3) test the power cord for open or broken or break.
4= check the switch for door maybe is open must be continuity until 0 , or swtich defective see the diagram attached. God bless you
Have a whirlpool microwave model GH5184XPS-4. This morning I turned the "Cooktop Light" on and a few minutes later I heard a small pop, looked over and the lights had gone out. One of the bulbs...
yup most probably that is the case.
you can locate the fuse usually it is placed near the main power supply or just trace the supply cord going in your unit. but before you open your unit be sure it is unplug to avoid electric shock.
slowly disassemble the unit and be sure that you can replace all the screws back to it original positions. after locating the fuse, check if it has a continuity and be sure to replace the same fuse rating. also investigate why the fuse had blown up and look for abnormalities.
if nothing found then replace the fuse and put all back then test the unit. if still it blows fuse, their must be something wrong with the unit and have it service to qualified personnel.
1helpful
Hamburger in foil wrap put in microwave - shorted unit out
Hi- The first thing here is safety. If the power supply is good- 120v at outlet- then address the fuse in the cabinet. Open door, remove screw(s) holding control panel, and tilt out panel. Fuse should be visible. Check for continuity. If bad, replace with 15amp appliance fuse. Plug in and check for operation. If fuse blows again, unplug and start looking at a new microwave. Let me know if this info helps. Have more if needed- Thanks- Ed
GE SpacemakerXL Microwave Model JVM1450 It's been working great. Then put somethingin,turn it on. It ran 30sec. made a growling sound,like it was straning or slowing down,then Blew the fuse.I replace the...
SOUNDS LIKE MAYBE HIGH VOLTAGE RECTAFIER SHORTED MIC ARE VERY DANGEROUS THEY HOLD VOLTAGE EVEN WHEN UNPLUGED YOU MAY CONSIDER PRO ON THIS SORRY
Microwave doesn't work after I accidentally put foil inside.
I think you have a blown fuse. If this link works it will take you to a you tube video.
https://www.youtube.com/watch?v=HV4SJA-_N_c
I'm not good at links, so if it doesn't work look on you tube for ge microwave replace thermal fuse.
And buy mom some flowers or some Sherries Berries.
MVH350 not turning on
Have you checked the main fuse?
1994 Whirlpool Microwave Mod MH7115XBQ-2
You can find exploded view diagrams and order parts here: http://tinyurl.com/gv383 The most likely causes are: diagram 5, ref. 5 fuse diagram 7, ref. 2 thermistor diagram 2, ref. 5 control board If it's a problem with the control board, we repair them nationwide for $32.50. We also have important safety and disassembly information we recommend: http://tinyurl.com/yzjozk
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
