Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Internet problem doesn't work when router is connected
  • ablaman Jul 20, 2008
    No internet connection whilst connected to Motorolasurfboard 5101 on Optus internet.
    Lights flash accordingly, but no connection is being detected.
    DNS servers have bee manually entered and still no change.
    Wireless connection is acive, settings can be modified but no difference.
    Problem Solver:
  • 6 Answers
What is this for can you be more specific? i.e Xboxlive. or just Home Use? Because it seems that if your router is connected it could not be picking up any internet connection or network.
Also to help. what is your : ISP??
Posted on Jul 13, 2008
Cannot connect to the internet. Have the wireless USB piece and is set up, but will not surf.
  1. Test your internet connection by directly connecting your modem into your computer.Bypassing the router.If it doesn't connect to internet then your router isn't the culprit.Contact your internet service provider for your area.If it does not connect then follow below step.
  2. Reconnect your router to the computer.Turn on your computer and find program associated with router.Select "options" select security options and select security mode and turn your router off.Attempt an internet connection. If it does not connect to the internet then your router might have broken and tell it to a company. If it does connect then your computer may have experienced a security breech that router does not allow it.
  3. Run a virus scan or malware scan for your computer.
If you have further query then contact me. Thanks for using FixYa.
Sep 04, 2011 | Computers & Internet
How can we set a password to the linksys wireless-g boadband router
Power On your router after after Connecting your adapter, turn on the router, wait for few seconds and then connect the router to your PC's Lan Card Port from one of the ethernet ports (not the labelled internet port). Open your internet browser and type in http://192.168.0.1 (if it doesn't work, use http://192.168.1.1) and press enter to open the page, once it's loaded, you'll be presented with the login page, in the USERNAME box, type in admin and leave PASSWORD blank (empty) and then press Enter. Once you are logged in, go to the admin section and change your password. If Admin panel isn't available, you can look for configure or change password.
If the above method doesn't work, click this LINK and follow the instructions. Let me know if you need further help.
Good Luck.
Thanks for using FixYa,
Aug 31, 2011 | Linksys Wireless-G Broadband Router
Have a self addressed ip address and can not access internet using my ewire router from Windstream but can connect to internet using my neighbors internet. Using Macbook 10.5.8 Just updated safari and...
Hey there.
You probably have set up your router wrong, try resetting the router and configuring it again. If it still doesn't work try directly plugging in the WAN cable into your computer and see if it works. If it doesn't you should check with your ISP.
Have fun :)
Aug 14, 2011 | Computers & Internet
The router doesn't recognize the dsl modem. I have hooked up to the internet directly from the computer and modem-no problem using the same cable the router can't connect to the...
connect the Ethernet Cable to lan Port and make new connection from Window (PC also should connect to the Lan Port) and configure the username and Password (test it ) if it is going this mean the Wan Port Has some Problems......
Jul 12, 2011 | Computers & Internet
Reset the router
1. On the back of your router there is a little black reset button. Use a pen or paper clip and press down for 10 seconds. Make sure the lights on the router stop blinking for one second. Release the button and make sure to reset your wireless security and network ID.
2. If that doesn't work just unplug your routers power cord. This is the easiest way to reset your internet connection without resetting your router to factory settings.
3. If neither of those work, unplug the power cord of your modem. This will completely reset the internet connection without resetting the routers settings.
Jul 09, 2011 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
I accidentally plugged the router out and now my Internet connection doesn't work. The local network connection is displayed as working and responding nevertheless. The second and fourth (starting...
Power down your router and computer. Wait 15 seconds, then turn on the router first, then the computer. If this doesn't work, you can also try rebooting the modem as well. You will then need to power all three down, then start with the modem and wait a minute as it boots up and runs its auto-tests, then the router, then the computer.
Jun 20, 2011 | D-Link DIR-300 Wireless Router
Cant setup or connect to internet through router
Different ISPs require different configurations. If you have a Linksys router, such as the WRT54G, there are 2 ways on how you can configure it, either by running the Setup CD or by doing manual configuration. This particular router has its own web utility and you can access it by typing its IP addres on your web browser, ex. http://192.168.1.1. By default, it doesn’t have any username and its password is admin.
Once you’re inside the setup page, you can configure now the router for DHCP, PPPoE or STATIC IP settings. For DSL customers using a PPPoE account, some modem needs to be configured into BRIDGE MODE first and then the router will be set to PPPoE with the correct username and password (given by ISP). If your a DHCP account, modem doesn’t require any configuration. It will work with its default setting and the router would be set to DHCP. Once done, powercycle your devices to establish internet connection.
Jul 02, 2010 | Linksys Wireless-G WRT54G Router
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Cannot maintain wireless connection
Try manually add the network. If the problems continue, I would turn the laptop in for repair/replacement (if it under warranty).
May 15, 2008 | HP Pavilion dv9730us Notebook
Sympatico & DLink DI-704P
It usually is simple, and hopefully the answer is as well. If you haven?t already done so unplug the modem and the router. Wait for a few seconds and then plug the modem in followed by the router. Reboot your PC and try the Internet again. If it still doesn?t work then I would try doing a hard reset of your router and reconfigure using the setup process outlined by the manufacturer. If that still doesn?t work let us know and we?ll continue ?.
Jan 01, 2007 | D-Link DI-704P Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
