Question about Canon ZR800 Mini DV Digital Camcorder
Battery Removal I am new to the digital camcorder world...just udpated from an analog. I bought the Canon ZR800 and it came with a generic looking battery connected to it and already charged. It slides up and down with a click, but I can't release it. I have read the book, but it doesn't say specifically how to do this. I have pressed the black button that says "BATT" and it still doesn't release. What am I doing wrong? Thanks in advance for any help!
  • 752 Answers
While pressing the "batt" button, slide the battery all the way up, then pull it away from the back of the unit.
Please mark as solved.
Posted on Aug 05, 2008
Computer doesn recognize camera
Have you downloaded the drivers for that camera: http://www.usa.canon.com/cusa/support/consumer/camcorders/minidv_camcorders/zr800#DriversAndSoftware
Also if it still doesn't work try taking the memorycard out of the camera and reading it using a memory card reader.
Oct 10, 2013 | Canon ZR800 Mini DV Digital Camcorder
Tip
Digital camera battery, camcorder battery and charger online store -...
Laptop batteries, like all rechargeable battery packs, lose their charging capacity over time. Because new Laptop batteries are expensive, replacing the individual cells inside the battery casing can save a lot of money. However, rebuilding a battery sometimes does not work as expected, so it’s important to be willing to purchase a new laptop battery if the procedure fails.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250
HP Pavilion DV1100 Battery 12 cells
1、Allow the laptop battery to run down completely. Turn off your laptop, then remove the battery. Write down the model number located on your battery to help identify the type of Li-ion replacement cells you need to purchase.
2、Split open a small section of the laptop battery pack (at the seam) with a screwdriver or craft knife. Continue to pry the plastic case loose moving around the outer edge until the entire top is free. This may take a bit of force.
3、Note the number of cells inside the case (usually four to eight). Write down the part number and voltage information printed on the cell casings. Draw a diagram showing the arrangement of the cells and how they are connected, or take a few photos to help with reassembly.
4、Purchase the correct number and type replacement batteries from online shop such as udtek.com, based on your battery model and cell specifications. Six Li-ion cells typically cost around $30 to $40.
5、Carefully remove each cell using a craft knife and wire cutters as necessary. Each battery pack is different, but the cells are usually wrapped in a plastic casing with metal contacts attached to one end. Lay the metal contacts, wires and casing material aside.
6、Use double-sided tape or a solder gun (only if necessary) to attach the metal contacts to the cells and circuit board. When finished, the old cells should be completely stripped (naked) and the new cells should look like the old ones as much as possible.
7、Place the new cells inside the case, referring to your diagram or photos if necessary. Glue the battery(Compaq DV6000 Battery) pack top back on. Charge the new battery for at least 24 hours before using it.
Tips & Warnings
Keep an eye on the new battery while it charges for the first time. If the contacts are not connected properly, the battery could overheat and cause damage to the laptop.
on Oct 21, 2010 | Computers & Internet
Flashing red symbol on screen - not 'no cassette loaded' symbol.
I had the same problem with my ZR800. After lots of searching on the net I found out what the symbol indicates. It means that the little battery that holds the memory for the clock is weak. It's under a little cover behind the main battery compartment. I put in a new one that the flashing icon is gone. I put the battery I took out into another ZR800 and the icon started flashing on it. A simple solution that Canon should have posted in the manual.
Dec 19, 2009 | Canon ZR800 Mini DV Digital Camcorder
Computer reconized canon zr85, but not the zr800
load or reload the drivers for the zr 800,you should be able to get the drivers off of canons website
Dec 03, 2009 | Canon ZR800 Mini DV Digital Camcorder
I have canon zr800 camcorder,its battary not gatting charged.
can you try to used a new battery if it works i think your old battery have a problem.
thanks,
Jun 23, 2009 | Canon Video Cameras
CANON MINI DV
It probably has a defective power supply and will need to be serviced by a professional.
Jul 26, 2008 | Canon ZR800 Mini DV Digital Camcorder
Canon ZR800 won't connect
Your saying 4 pin USB firewire. Which one is it?
It should be 4 pin firewire.
What is the error message that you are getting?
Jun 09, 2008 | Canon ZR800 Mini DV Digital Camcorder
Batteries and chargers
the 18 should just be the higher capacity battery-can't see any problems
Apr 26, 2008 | Canon ZR800 Mini DV Digital Camcorder
Canon ZR800 Question
I don't think everything will remove off the screen. Your battery level and timers will remain on the screen at all times.
Sep 26, 2007 | Canon ZR800 Mini DV Digital Camcorder
Canon ZR800 Mini DV Digital Camcorder Logo
44 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
