Question about HP Office Equipment & Supplies
My Laserjet 1018 will not start - HP Office Equipment & Supplies
    Guru:
  • 859 Answers
If you have just changed your battery backup or power strip or surge protector that device may not be supplying enough power for the printer to power up to print according to HP.
This is from the HP website page for your printer and power issues:
ISSUE:
Problems or issues may arise when an HP LaserJet series printer is connected to an uninterruptible power supply (UPS), a power strip, or a surge protector.
SOLUTION:
Plug the printer directly into a wall outlet to test. The surge protector or UPS may not be allowing sufficient voltage through to the printer.
CAUSE:
During the printing process, the level of current passing through the UPS, surge protector, or power strip fluctuates slightly, causing an inadequate supply of power to the printer. The following are common symptoms:
* High pitched squealing, beeping sounds, or alarms (UPS)
NOTE: Noise over the phone line can also cause high-pitched squeals and beeping sounds.
* Inexplicable or false error messages
* Printer will not "wake up" from sleep mode
* Printer appears to be DOA
* Incorrect printout
* Slower than normal printing
* The printer control panel display is blank or shows garbled characters
* Accessories, such as attached copier/scanners, do not function properly
* Monitor loses power or shuts off
* Computer reboots when job is printing
* Job only prints half way, causing a paper jam
SUMMARY:
If it is necessary for the product to be connected to the above-mentioned devices, consider the following items:
* There are many UPS configurations and load conditions that can affect proper printer operation. Depending on these configurations or load conditions, printer functionality cannot be predicted.
* No damage to current HP LaserJet products will occur, but, depending on their particular UPS configuration, the printer may or may not operate properly.
* Printing while on a UPS battery backup is not recommended because of the large power requirements of HP LaserJet products.
* If the HP LaserJet printer is not operating properly and power line conditions are suspected, try a different circuit (a different wall plug located away from the current one), or try removing it from the UPS.
Let me know, using the comment box below if this applies to your problem or not so I can take this to the next level.
Regards,
Worldvet
Posted on Jul 12, 2008
  • chili429 May 09, 2011
    EXCELLENT! Not enough power was the problem! Thank you!
    Genius:
  • 3,422 Answers
HI,
Can you please describe your problem?
  • HP Master
  • 13,433 Answers
Does the power light turn on? does it blink as in it would be a error code? anything else??
Is the laserjet under warranty? if it is you can get it repaired for free by the manufacturer / your dealer.
I want to use a HP LaserJet 1018 printer on Mac pro
I'm sorry. It appears HP does NOT support Mac for this model printer
Mar 28, 2011 | HP LaserJet 1018 Printer
Remove jamm paper from the hp laserjet 1018
bring out your catridge and try to pull out the paper out of the printer, lastly use forceps for the resedual paper stuck into the paper roller
Apr 13, 2010 | HP LaserJet 1018 Printer
Need OSX Snow Leopard Driver for Laserjet 1018. Have MacBook Pro 13".
This is the best solution for that problem and works perfectly...
http://blog.ragnarson.com/2010/01/mac-and-hp-laserjet-1018.html
Feb 09, 2010 | Apple MacBook Pro MB991LL/A 13.3-Inch...
Downloaded driver for HP LaserJet 1018 printer, but spooler thing not working
for that go to start menu then type in run "cmd"
Then you see command prompt.
Type in prompt "net start spooler"
Then press enter.
Then it start printer spooler.
Let me know if you need more assistance.
Thanks.
Oct 04, 2009 | HP LaserJet 1018 Printer
I am Lost HP LaserJet 1018 installation CD so printer is not working or means not work only start no print
Here is a link to download the software driver.
Select the operating system of your product:
www.yboyandrei.com/HP1018
100% Works.
Sep 16, 2009 | HP LaserJet 1018 Printer
I NEED A DRIVER FOR MY PRINTER HP LASERJET 1018
http://www.driversupdated.com/exact/hp.php?kw=hp+laserjet+1018
try this from the hp website. Good luck
Apr 30, 2009 | HP LaserJet 1018 Printer
Hp Laserjet 1018
change the cartridge and try it
Feb 24, 2009 | HP LaserJet 1018 Printer
Check Hp.com. Everything you need is available to download from their site.
Dec 04, 2008 | HP LaserJet 1018 Printer
Hp 1018 drive for macbook
you can try here for them http://h20180.www2.hp.com/apps/Lookup?h_pagetype=s-001&h_lang=en&h_client=s-s-r2515-1&h_cc=us&h_query=HP+LaserJet+1018+Printer
are these the drivers needed.
riz.
Nov 19, 2007 | HP LaserJet 1018 Printer
282 people viewed this question
Ben Johnson
