Question about Frigidaire GLEQ642A Electric Dryer
Frigidaire Dryer clunking sound
Before the problem a bed sheet was caught between the drum and frame. Now it makes a thumping sound when drum rotates completely while running. Need to know what can be done to solve the problem and how to open the dryer to get access to the problem. Thank you
  • fhord Jul 13, 2008
    Same problem
  • EODLDO Dec 12, 2008
    I found the cause of the problem to be the he drum rubbing on the top of the fnedan housing inside the dryer. The seam where the sheet metal that is used to construct the drum is joined together rubs on the top of the fan housing. This causes a thumping sound every time the seam comes around and rubs on the fan housing. I believe it was caused by the movers as we just moved to VA from FL. Does the drum need to be aligned or balanced?
  • 979 Answers
Try aligning it first. It won't be hard to do. You can use points of reference to let you know if you are aligned correctly.
Posted on Jan 28, 2009
Maytag dryer
If this is the metal drum model of Maytag dryer, then the drum is likely out of round and will be evidenced by a broken spot weld on the seam where the drum is welded. I have had to replace mine for that very issue. Not cheap! Hope that is not the case for yours, but just rotate the drum by hand and you will see a high and low spot during the rotation. If the high and low spots are consistent, you know your drum is out of round and likely has busted spot welds. You can run it like that for a while if you can stand the thumping. If no out of round condition, then check the roller alignment and see if the bracket got tweaked not allowing it to rest on the drum. Again...if it touche s the drum and then leaves the drum as the drum is rotate by hand, the drum is out of round. Hope this helps
Feb 15, 2017 | Maytag Dryers
Tip
How to care for your mattress
Although mattresses come with a warranty, this does not mean that you should not care for it properly. The following is a list of ways in which you can further the life of your mattress and keep it in great condition.
Ensure proper installation
Make sure to let your mattress breathe - when you take a vacation, do not leave sheets on your bed; try stripping the bed twice a week and leaving it without sheets until the time you are going to bed
Do not jump on the bed - keep children from jumping on your mattress
Keep your bed from sagging by using a supportive bed frame
Use a mattress pad to absorb moisture/perspiration that can be easily removed and washed
To help minimize wear and maximize comfort make sure to rotate your mattress every two weeks during the first three months after purchase and every two months after that
Here is a great guide on how to properly rotate you mattress:
http://www.wikihow.com/Rotate-a-Mattress
on Aug 28, 2012 | Furniture
Inglis dryer making thumping sound when drying
is the unit level, open the dryer try moving the drum around, see if the drum loose, there mite something in the machine that got caught on the drum some how and when it goes around it bangs,
you mite try spinning the dryer without turning it on and listen to the drum and see if you can hear any thing hitting the drum or what is make those load sounds. if you cannot turn the drum manually you mite bribe a guy or friend to check it out for a beer or glass of wine, and if they down drink bake some cookies.
good luck rod
Dec 04, 2012 | Whirlpool Inglis IP8200 Dryer
Creda simplicity TVU1 tumble dryer is making a thumping noise while drying
Hi dave hemming.
I do not believe it is a bearing that is causing your thumping noise
No...you do not need a new drum...all you need is new drum rollers
You probably have a flat spot on one of the rollers, it will make the thumping sound when the drum rotates.
Go to the following webpage and get your drum rollers and install them and that should take care of the noise you are hearing
Please take time to rate me
Bud
http://www.appliancepartspros.com/index.aspx
Oct 13, 2012 | Dryers
Dryer makes lots of noise when drying..squeaky ans sometimes a "thump"
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 07, 2010 | Kenmore 64882 Electric Dryer
Thumping/rubbing sound in drum
The belt tensioner roller has a flat spot caused by a worn bearing that catches and stops whilet the drum is turning. This causes the flat spot and the noise its making. You can purchase a new roller by itself and do change the belt the same time too
Apr 08, 2010 | Frigidaire Electric Dryer
Thumping sound from loose drum
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 10, 2009 | LG DLE5977 Electric Dryer
Electric Dryer Thumps
that gap in the drum is most likly hitting a roller in the back of dryer so my best guess is replace drum if you feel it's not that change the felt around door thank you for useing fixya rate me
Apr 01, 2009 | Dryers
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Clothes get caught between frame and drum
Is this the dcvh515 GE? Mine began doing that and then started making a high pitched scraping noise that sounds like it's coming fron the door gasket/seal.
Dec 21, 2008 | Dryers
Frigidaire GLEQ642A Electric Dryer Logo
366 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
