Question about Car Audio & Video
If i am installing a cb radio in my car, how do i wire it
Well, the one thing i didnt do was pay these guys money for the answer, and just asked my friend. I really like this website though, because the'll be glad to ask for your money for the answer, but if you have the answer the'll be glad to ask you for it for their own profit
Posted on Jul 13, 2008
D104m6 wire it to 2510 cb
Pretty sure it can be done but you need a wiring diagram for the radio pinout and the mic. Best leave it to a CB service shop.
Oct 11, 2014 | Uniden 5 Pin Cb Microphone Fits Hr2510 Hr...
How to install a cb radio in a 1997 chevy truck
get a dc plug for your cigarette lighter and connect it to the radio wires(black on black red to red) its the best and fastest way for install and cheap.
May 25, 2012 | Cobra 29 LTD CB Radio
Is it possible to convert the texas ranger tr-396fc from cb to 10 meter amateur band?
Note - You must have an Armature License to legally perform this conversion.
1. Remove bottom cover from radio. 2. On the main PCB, locate J33. (See diagram above) 3. Locate wires on pins marked "P5" (yellow) & "P6" (grey). 4. Cut wire on "P5" (yellow) and install a SPST switch in line. 5. Cut wire on "P6" (grey) and install a SPST switch in line. NOTE: By using two of the function switches available on the radio will eliminate the need for two new switches to be installed and mounted.
Mar 08, 2011 | Ranger Communications TR-396FC 40-Channels...
I have a whine in my dash that can be heard when the engine is reved. It feeds through to my CB radio when the radio is miked up
Interference may be caused by non - resistor spark plugs. If you don't want to change your plugs for resistor plugs, you may be able to get an inline resistor for the antennae from your local electronics supply store, like radio shack. Failing that, you can buy a cb antennae with a built in resistor coil that will also do the job. If you buy the new antennae, go to a cb shop to have your antennae tuned to your cb - it will increase your range and clean up your sound too.
Hope this helps, and please rate my solution!!
Nov 17, 2010 | GMC K1500 Cars & Trucks
I need diagram on how to install or wire my CB IN MY CAR. The CB is already connected to a 400 watt linier that is mounted to the bottom. Mounting,installing not an issue. Proper wire and antenna hook up...
The CB radio its self just needs to be connected to power, and the antenna connected. You need to use at least RG-8x coax or you risk it frying from the extra power from the amp.
The radio needs to be attached to the amps input, then the antenna needs to go to the output of the amp.
Then most importantly the antenna must be tuned to lowest SWR. It must not exceed 1.5 and even that is pushing it.
Apr 07, 2010 | Radio Communications
HOW DO I INSTALL ROGER BEEP ON A GALAXY 33 CB RADIO
Does the roger beep come with instructions? It can vary between beep boards.
Typically it gets installed inline with the mic jack.
There is a wire or pin on the board where the tx wire, and the rx wires go.These wires get disconnected from the mic jack, then a wire goes to the tx pin. Then there is an audio wire that gets connected to the audio wire of the mic jack. Then the black wire to ground, and the red wire to switched 12v right off the power switch.
Here is a schematic of the board connected to the mic jack so you know what pin is what.
Again, I would need to know what roger beep board you would like to install.
Feb 22, 2010 | Galaxy Radios DX-33HML 40-Channels Base CB...
I want to install a car cb in my house, what do i need to convert it so i can use it indoors? can this be done? i read to use a 12 volt inverter, but the cb has only wires that have been cut, no cigarette...
Ok, these are hard wire for installing in a vehicle. There are a few ways, of the easiest would be the 12v converter. You can do this by purchasing a cigarette plug and wiring it in. Red to red and black to black. If you do not want to go this way, you can use a battery charger for a vehicle to power your cb then everything else is just like a car.
Sep 28, 2009 | Midland 77-092 40-Channels Base CB Radio
Not able to transmit or recieve on cb radio in car
It could be your ant. a broken coax wire or a bad ground could cause this a could a broken or shorted wire on your mic.
Jun 02, 2009 | Maxon Radio Communications
Galaxy DX 959
Mar 08, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Cb radio installation
You can Go with what you have
PlEASE RATE My ANSWER
Jan 16, 2009 | Cobra 18 WX ST II 40-Channels Base CB...
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
