The appliance is a Jenn Air gas oven/range.
The F9 error code won't go even after several resest and power shutdown, The oven door is locked and will not open
Take a 24 inch peice of coat hanger make a small u in one end and insert it from the left side gentlw fish for the door latch hook and pull it over to un latch the door and let me know if the code goes away
Try the other left side
It requires a very light force. The latch is located in the center. However, my range had to be approached from the right side. I thought, what the heck try it from the right and it worked instantly.
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Thanks for the suggestion..I was able to get the oven door open with the coat hanger..The F9 code still comes on despite numerous resets/power shutdown..
