Question about Elna 1010
Elna 1010 needle jam
When I get it all threaded up and start sewing, it will sew for a little then the needle locks up. It get stuck in the dog or whatever its called. Why does it jam?
  • 3,053 Answers
Hello, h
I am trying to help you out here. Maybe this will help some? I am known on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved. I do this on my own time for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about Sewing Machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/sewing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help. It would make my time worth. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Posted on Oct 30, 2011
Tip
Have you acquired an early Swiss Elna Sewing Machine??
There are still many of these Elna Supermatic sewing machines around and being used; they might not have all the electronic bells and whistles of a new model but they are a very well made solid metal case machine, parts can still be found and they will produce a good quality stitch and handle a wide range of fabric types.
Maintaining these early models means regular cleaning and oiling. Each time you get your Elna out to sew you need to remove the needle plate and open up the bobbin cover, take out the bobbin then using a little brush carefully remove all lint and fluff that you can see from the race, around the feed dogs and in the surrounding area. Your model may have marked red dots for oiling points, usually one in the middle of the bobbin holder, and often another red dot nearby in the race area. Plus a couple on the body area sometimes or top of the machine. Oil these marked points with a drop of good quality clear sewing machine oil when you get the machine out to sew, especially into the bobbin holder, then run the machine slowly without a bobbin or thread for a few seconds to spread the oil through the moving parts.
Use Swiss Elna metal bobbins only, they are very distinctive and only have holes on the top with a smooth underside and are slightly dished. Always wind the bobbin with holes on top and load it into bobbin holder same way; this way you always have the thread coming off the bobbin in the right direction.
It is important to always click the bobbin thread into the tension spring on the outside of the bobbin holder, there is usually an audible sound as you get it into tension. Just hold the thread tail with one hand and pull it around into the groove on the outside of the bobbin case, then put a finger onto the bobbin to hold it still, and push down on the thread tail with your index finger to push it down into the tension spring, you should hear it click in. Lift the thread tail vertically to check, the thread wont come out if its in fully.
Whenever you start a new seam ALWAYS hold the two threads at the back of the needle plate firmly as you start stitching until you've completed 4 or 5 stitches, to keep them clear of getting pulled back into the bobbin race. This saves those horrible jam ups happening when you start a seam.
Change your needle regularly to ensure it is sharp and use the right sized needle and type for the fabric you are sewing; these machines take the standard 130/7H needle system, and always install flat shank to the back of the needle bar.
Happy sewing on your vintage Elna.
on Oct 02, 2011 | Elna Sewing Machines
In my old but good elna sewing machine thread got stuck in bobbin case and it is jammed
then you need to get the bobbin case out and clear all thread . if you can not get it then you need to take to a repair shop
Nov 02, 2015 | Elna 2005 Mechanical Sewing Machine
My very old little elna lotus (not sure if zz or sp) has suddenly jammed solid with the needle down through a piece of material. I can't move the flywheel at tall and I can't free the materia
Try unscrewing the needle, and then pull up the plate, and sort outthe threads very carefully with a quikunpick. When starting to sew, have slightly longer threads, make sure they are behind the needle, and hold them in your left hand. Especially when sewing very fine fabric, start slowly until you are sure the threads are forming properly, then it's OK to speed up. Use your ears, if it doesn't sound right, stop immediately. If you are going to use fine slippery fabric, be sure to do a trial piece first, rather than muck up your project. Elna machines are lovely to use, I've had one for over 40 years, still in daily use. Oiled with one spot of oil each time I use it, fluff regularly cleaned from underneath with the little brush supplied.
Apr 15, 2013 | Elna Sewing Machines
OK I CAN'T GET THE NEEDLE ON MY ELNA 1010 TOPICK UP THE BOBBIN THREAD WHY
sewing machine shop technican's have special tools to adjust the
timing on sewing machines.
if you do take the machine to be timed, when you get the machine
home,, sew on the machine right then to make sure that it sews
the way it's suppose to,
Jul 31, 2012 | Elna 1010
I have for gotten how to make the machine sew and im having trouble threading a bobbin for my moms machine elna 7000 i need a manual or a quick note to get started
YOu can down load a manual from here http://www.arizonaexpressionz.com/elna_instruction_manuals/Elna7000.pdf
Just remember to click the bobbin thread into the tension device correctly and hold the two threads behind the pressure foot when you start each seam - Elna top loading bobbins give great stitch quality but you just need to keep stray threads out or they'll jam up.
Also, you must use the Elna plastic bobbin that the manual specifies for this machine - the 5000, 7000 and 9000 were Elna Tavaro Switzerland's first foray into computerised machines and first released in 1986.
Also, please check the manual when you go to buy twin needles, there are two types now as computerised machines usually need the twin needles offset from the shaft position. They have red or black plastic block between the shaft and the twin needles - I think you need the red ones but just double check the manual to make sure. And you can't do all the wide stitches with a twin needle as it will strike the foot.
Hope this helps a little.
Jan 16, 2011 | Elna 2007 Mechanical Sewing Machine
The feed dog on my Elna 1010 will not lift up when I slide the lever across. We have taken the bottom off and looked underneath and although the bar slides across it does lift the feed dog. What do I do?
Have you actually tried to stitch yet? Turn the flywheel towards you through a stitch sequence and they should reengage as the needle rises.
Nov 20, 2010 | Elna 1010
When I try to sew, the thread on the bottom of my fabric gets all bunched up. Sometimes the needle gets stuck. This happens all the time. I re- thread the whole machine, but it always eventually happens...
put a new needle in the machine
clean under the needle plate in the feed dog area for lint
also clean in the bobbin area for lint & loose threads
keep a check on the thread take up lever,, because when the thread comes off the thread take up lever it will build up thread under the fabric & can jam up the sewing machine
Nov 17, 2010 | Elna 1010
Elna Sewing machine jammed
What type of elna and do you know how it was jammed?
If concerns bobbin area - make sure you have all lint and thread cleaned out. That could be jamming it.
Feb 12, 2010 | Elna 1010
Sudden knotting under fabric
I have an Elna 2005 machine and had a similar but opposite problem whereby the tension up top was too tight - thread wouldn't pull smoothly. I found adjusting the feed dog lever slightly helped the stitches a lot, even though the needle tension up top is no better. Hope that helps! :-s
Jul 01, 2007 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
53 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
