Question about Panasonic Televison & Video
Re Panasonic VCR model NV-HD90B. Loads and briefly plays video tape satisfactorily, then stops and won't allow cassette to eject. When immediately turned off and re-powered it turns off again within 3 secs and tape still won't eject. When left off overnight (this has now happened twice) the cassette immediately ejects when unit switched on and eject button pressed. However excess tape then has to be pulled through the eject cover as it remains inside the unit. Thanks.
robotek
  • 1512 Answers
SOURCE: I have had the same
Hi alan
Check the reel brakes. Simple as that
Posted on Apr 16, 2008
SOURCE: My Panasonic NV-SD270 video player
when the loading mechanism have a trouble and did not thread the tape properly , the eject mode commands primarily coz the tape in sensor activated properly
Posted on Apr 29, 2008
SOURCE: I have a NV-FJ620 video
One possible explanation is a faulty mode switch (this is a multi contact rotary swith located under the mechanical deck) which needs cleaning probably not a job for the DIY enthusiast
Posted on May 15, 2008
ilragatzzo78
  • 241 Answers
SOURCE: cassette player
the tape is very tight
get a pen and try to loosen up the tape
100 % is the tape not the radio
Posted on May 16, 2008
  • 1894 Answers
SOURCE: Own a Philips 14PV415/07 TV/Video
did u try a hard reset or not?
if u dont know how to do it means
please reply back
Posted on Jun 20, 2008
Panasonic vcr model nv sd-300 auto eject when i insert cassette
Hi have u tried another tape it's rare but the tape is possibly Faulty it happened to me years ago... Cheers
Jan 06, 2017 | Panasonic Televison & Video
I have a VCR Panasonic NV - FJ623 and when I insert a video cassette into it for playback or recording purposes,it always ejects the video cassette.Can you help, please?
I'ts likely that the record sensor that pushes on the tab on the tape is bent or broken. Making the VCR think you are trying to record on to a protected tape.
Oct 22, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
I have a Panasonic NV-FJ600 VCR which ejects every cassette which is loaded , and the two guide rollers remain at the rear of the machine and do not move forward to engage the tape .
If you mean the guides are on either side of the head drum, and the carriage is in eject position, the mechanism is out of alignment. Re-alignment and re-timing may require a workshop service by a professional Panasonic agent.
The bad news is the likely cost(s) involved if parts are replaced.
The NV-FJ600A VCRs were good models a few years ago, one of the first 'super long play' series Panasonic launched.
They use the Z-mech series of decks. These are not impossible to re-align/re-time, unlike previous mech designs, but depending on the extent of wear/damage, can prove uneconomical for a budget VCR which would now be close to 10 years old.
Oct 18, 2010 | Panasonic NV-HD680 VCR
Panasonic NV HD630 is showing error f06 when the eject button is pressed. The tape cassette seems to be locked in and does not rise. I have removed the top. The tape is withdrawn back to the cassette....
You have a K-Deck mechanism. F06 means the mechanism locks after unload. The cause of this is the load motor or the carriage alignment.
If you enter "Panasonic K-Deck" into google you should find service information and a guide to getting the tape out - all free!
Oct 13, 2010 | Panasonic NV-HD680 VCR
The vhs cassettes keep being ejected when put in the vhs player
Well the vcr might be broken for the part that allows the tape to sit in there or something is stuck inside of the vcr so it will need to be fixed.
Jun 17, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Vcr will not play tapes,it ejects the tape after a few seconds
This may be caused by the mode switch.
By the way it uses a K-Deck Mechanism.
Sep 11, 2009 | Televison & Video
Tape ejects when inserting into video player
check the tab on the back side of the tape- make sure its intact- if tab is missing it will not let you record - i've sometimes added tape to replace the tab ,,
Feb 02, 2009 | Panasonic NV-HS1000 S-VHS VCR
Panasonic NV GS 15 deck jammed
Yes i had the same problem ...
1.Put the cassette as far as it allows... and move the cassette left and right slightly twisting , and you will activate the mechanism
2.SOON the mechanism gets fully out immediately!!!! remove the battery
3.CLEAN contacts (I'm looking right now on the internet to find where the hell sensors-contacts are)
4.PREY that it works :-)
Feb 22, 2008 | Panasonic PV-GS2 Mini DV Digital Camcorder
Tape keeps ejecting - panasonic nvfj620
Is it only the Head cleaning cassette which keeps getting ejected, or is it happening with every tape you insert? Was the Head Cleaning Tape a little tight in the Cassette compartment? Did you have to put some pressure to push it in or did it come out with difficulty? From your symptoms, it looks like there is a gear timing problem with the cassette loading compartment gears. It could also be due to some obstruction inside. try shaking the VCR, and if you are hearing some noise, Open cover and check for foreign objects.
Apr 25, 2007 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Televison & Video Logo
71 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
