There is a Singer Baseboard Heater in one of my rooms. We bumped it while moving furniture today and it turned on. We have tried moving the dial both left and right and can't get it to turn off. Any idea of how to turn it off? If not, how do we remove it altogether.
I was able to determine and turn off the breaker. I am having a heating and air conditioning company remove the heater altogether. Thank you for checking back with me.
Posted on Jul 14, 2008
Electric Hydronic Baseboard Heater, 240 Volt: WHEN I TURNED ON MY ELECTRIC BASEBOARD HEATER THER...
My PLF504 detonated this morning (11-25-2010). It worked fine for two years then BANG. Room was lit by flame coming from center (left to right) of unit. I wrote Marley asking them to honor the 10 year heater element warranty. Also, no burnt wires at thermostat connection, no dust bunnies on the fins. Source of fire was the fluid filled encapsulated heater core. Thank God, circuit breaker tripped and wall was tiled.
May 17, 2010 | Fahrenheat Electric Hydronic Baseboard...
I have a baseboard heater in my apartment (small dining area) that has a dial that I can control the heat..the knob has #1-10...what is a good number to set it to and do I keep it on all the time. Thanks...
Hi!
The number you keep it on is whatever temperature that is comfortable to you. The settings on the dial are graduated from #1(lowest-coolest) to #10(warmest). If you want to keep the room temperature somewhat even you need to play around with the settings( one number at a time) until you find what is comfortable to you. Hope I was of help to you.
Dec 02, 2009 | Fahrenheat FBE15002 Baseboard Heater
DPDT thermostat for Singer baseboard heater.
as close as I've found
http://keithspecialty.com/k/67-411.htm
http://www.heater-store.com/specialty-thermostats_91_ctg.htm
Nov 02, 2009 | Honeywell Programmable Thermostat Heater
How do i know what size baseboard heater to use in any given room.
Basically each baseboard should be rated for a particular heat output...Watts...which should have an equivalent to square footage...look in the Specs or askj the Supplier....and that will vary on the Heat loss of each particular room...how big the windows are....how well insulated the room is etc
Oct 16, 2009 | Fahrenheat Electric Convector Baseboard...
Baseboard heater
the stat points are stuck together or the stat is defective. try tapping on it to make them loosen up or replace the thermostat.
Dec 08, 2008 | Fahrenheat FBE15002 Baseboard Heater
Electric baseboard heater heats up...but no longer heats room..
Some baseboard heaters have an adjustable damper panel inside. Make sure this didn't accidentally get closed. If that is not the problem, perhaps the heater is clogged with dust or lint, or a rug has been pushed up against the bottom air inlet. You may have to pull the cover off of the heater to clean it out.
Nov 19, 2017 | Heating & Cooling
one eight foot unit - 3000 watt high density heater will do the job.
Nov 15, 2007 | Fahrenheat Electric Convector Baseboard...
Baseboard heater
Make sure BOTH fuses on each heater circuit test ok -- they are no doubt 220V -- hence 2 fuses
Nov 08, 2007 | Honeywell (CT62B1015) Baseboard Heater
Heating & Cooling Logo
106 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
