Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
XBOX 360 wireless adapter,problems with passing test!!
It was failing at "wireless network" but know is failing at "IP address", know im re-trying and is failing at "wireless network" again!!
This is really starting to get me angry!!
if you could contact me on jonnycee9@yahoo.co.uk with a solution i would be extremly happy and appreciative!
  • Anonymous Jan 27, 2009
    htertweqtABDFUJER WGYWH WS STYSGHS
  • 34 Answers
Ok i think we have the same problem. You can call this post a same problem / solution post. Try reseting your whole computer and router by simply unpluging everything. It should work temporarily(2 days). The reason your having this problem is because of certain settings on your router which kick in after a few days of reseting thats why it will assign an ip address temporarily.comment when you have tried this. Maybe we can help each other.
Posted on Jul 12, 2009
Ip address keeps failing
Hi , Do you have static IP in place , i mean in network neighborhood type your IP and make it as the permanent, then log in , you will be able to access.If you dont know how then surf the net to manually type static IP.
Jan 17, 2009 | Microsoft Xbox 360 Console
IPaddress failed
When this sort of thing happens it is usually a DNS error. The easiest thing to do would be to cycle your network. You can do this by unplugging your dsl/cable modem for a minute and plugging it in again.
XB360 also has a network test option that will tell you where in the network the connection is failing in the case that it is not a DNS problem.
Jan 16, 2009 | Microsoft Wireless Network Adapter Xbox...
Wireless adapter for xbox 360 isconnected to bt wireless broadband because the light on xbox is green, but IP failed
try going to your router page and find all the information on your ip address and everything else and put it in manually
My wireless adapter lights up green but does not connect live
i had to change my ip address and so forth from manual to automatic because all the xbox needed to do was find everything by itself so that it could actually connect to my wireless network.
Dec 07, 2008 | Microsoft Wireless Network Adapter Xbox...
Ip address failed
I think you need to ring your internet provider and they will enable xbox live from their side. Its fairly simple and they will know what your talking about.
Oct 20, 2008 | Microsoft Xbox 360 Console
XBOX 360
go to a computer on your network
type cmd in the run box press enter the type ipconfig/all and press enter write down the ip addy the default gateway and the dns numbers
go into your xp and set everything up yourself
Aug 08, 2008 | Microsoft Wireless Network Adapter Xbox...
Ip addresses
the wireless adapter is when you have a wireless router,take off the adapter and plug the ethernet cord from the modem to your xbox
Jul 13, 2008 | Microsoft Xbox 360 Console
My 360 is not signing in to xbox live. It sais on the test connection that the ip address has failed.
  1. reset your router to factory defaults
  2. go to your 360 and reset the tests
  3. call mcrosft for help
May 03, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox live
ok, this is what i have to do whith normal computers.
(the xbox is the same)
(make sure youve got a crossover cable (red one))
1.turn on ur xbox
2.goto the system tab
3.goto Network settings
4.edit settings
5.ip settings
6.change it to manual
7.ip address
8.type in 192.168.1.2
9.Subnet mask
10. type in 255.0.0.0
11.default gateway
12.Type in 192.168.1.1
On your computer
(vista)
1.start
2.control pannel
3.Network and Sharing Center
4.manage network connections (on side Bar)
5. right click on Local Area Connection
6. go propertys
7. doble click on tcp/ip v4
8. click use the following ip addess
9. ip address
10. 192.168.1.1
11. subnet
12. 255.0.0.0
13. default gateway
14. 192.168.1.2
15. click ok
16. click ok
17. right click wireless network
18. goto propertys
19. got the sharing tab
20. tick the only box you can
21. press ok
22. your done!
phew that was a long one.
hope this helps.
Maxicube.
Feb 09, 2008 | Microsoft Xbox 360 Console
IP address Problem when connecting to xbox 360 live
i had the same problem buddy. The problem might be that you hacve another system on the wireless network that uses that same IP address. This can cause a conflict that will prevent the xbox from logging on. Try deactivating other systems on the network to see if thats the problem
Sep 26, 2007 | Microsoft Xbox 360 Console
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
281 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
