Question about Avanti G20AW-1 Gas Kitchen Range
My GE stove top ignitor keeps clicking after the flame is on
  • Glen giaquinto Apr 05, 2009
    Ignitor keeps going on despite all knos in the off position.
4 Suggested Answers
mgprice
  • 744 Answers
SOURCE: ge gas stove top keeps clicking
Hello, your problem is going to be 1 of 2 problems, 1st did you spill liquid on the switch? if so the switch has shorted out, unplug the appliance for 24 hours to dry the switch out then plug it back in...if after 24 hours it is still clicking you have a bad switch (these are the burner knobs) check each one with a ohms meter, the one that is bad will read infinate on your ohms meter when it is switched off. If you have any other questions please feel free to comment. Good Luck!! Mike
Posted on Sep 22, 2009
Testimonial: "yes, liquid was spilled into the burner, thanks for the advice will give it a shot.."
heatman101
  • 43501 Answers
SOURCE: ignitors won't stop sparking
This tip I wrote to help people with the problem of the spark not shutting off...the clicking non-stop is a common problem.
Gas Range2_bing.gif Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on May 04, 2010
meztang
  • 112 Answers
SOURCE: I can't get one of my burners to light on my ge
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 18, 2010
My ge monogram stove top burner( model zgu366h)continues to ignite. even after the flame is lit
If you are saying the clicking continues you must move the burner knob past the LITE position.
If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Nov 30, 2010 | GE Cooktops
My GE gas stove keeps clocking and I can see the spark for every click. But, it doesnt turn on for a long time. It atleast takes 20-30 clicks before it turns on.
If it is clicking while a pilot is present, the sensor or ignitor box is not sensing the flame. If it stops clicking as soon as a pilot is present, the spark may not be hot enough to ignite the gas or the gas may be slightly low on it's flow amount. don't over look the obvious, such as the oven being exposed to drafts which blows out the flame.
Hope this helps.
Feb 07, 2010 | Ovens
I have a GE Kitchen range XL44, stove top burners work fine, but oven won't light??? HELP please
Unplug the range.
Remove the oven racks.
remove the oven base pan.
remove the flame spreader pan.
remove the glow bar ignitor on the left hand side of the gas burner and replace it with a good ignitor.
Jan 25, 2010 | GE Kitchen Ranges
Gas flow problem with stainless steel GE Adora stove.
If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Dec 19, 2009 | GE Adora JBP77SMSS Stainless Steel Kitchen...
How do you light the pilot on a GE stove The top of the stove works
Hi, If this model has a standing pilot, use a lighter and put the flame to the back center next to the burner assembly. Most newer models have electric ignitors now. It is fastened to the burner assmbly on the laft side.
If this an electric ignitor, turn the oven on and see if the ignitor glows. These ignitors are a very common problem and will probavly need replaced.
Please let me know if I can assist youu further.
Vic
Jul 03, 2009 | GE JGRP17 Gas Single Oven
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Whirlpool gas range stove top
You may have lodged something in the pilot hole while cleaning.
I would chech closely and make sure the are no obstructions.
Feb 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 Gas Stove
Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Avanti G20AW-1 Gas Kitchen Range Logo
318 people viewed this question
Top Avanti Kitchen Ranges Experts
Craig Butler
Craig Butler
ray gallant
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
