Question about Fisher and Paykel Dryers
Flashing light on fisher and paykel multitemp ed56 dryer
i have a fisher and paykel multitemp ed56yer with a flashing light, that won't allow it to work. I have cleaned out the lint filter. I know it must be something simple, but can't figure it out. The flashing light is under the POWER/PAUSE button, and is on it's own.
Hope you can help, thanks,
Karyn.
  • 351 Answers
SOURCE: How to install capacitor to
if the cap has two terminals it doesnt matter where you put the wires
Posted on Aug 28, 2008
  • 10 Answers
SOURCE: Lint is not going into pull out lint trap. The lint screen is torn and lint is collecting behind trap.
Poor air flow would be my guess. How long is the vent hose? Does it have more than one angle/turn before venting outside? Is the lint gathering around the outer edges of the door? Keeping the length of air travel shorter will improve the operation.
Posted on May 12, 2009
TheMobilian
  • 8220 Answers
SOURCE: Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Posted on Sep 08, 2009
SOURCE: Fisher & Paykel ED56 not working
Replace (repair) the exhaust sensor this looks like a transistor with the middle leg cut off. it is situated below the lint filter but can only accessed by removing the back panel, top panel (or rear screws to allow the removal of the drum). drum and then front panel to remove the connector from the mainboard. If you follow the exhaust tube once the back is off you will see a single phillips head screw that is the sensor. check the wires to the circuit board are not broken or dry joints or just replace it. sorry i had a spare machine i scavenged from to fix my problem so i dont know where to buy new.
Posted on Apr 09, 2010
SOURCE: Dryer Problem
Grinding noise most likely due to the front drum bearings worn out - result is the metal drum making contact with the rim of the from panel.
This requires a total disassembly of the dryer to investigate & likely replacement of the front slipper pads (dry nylon slipper bearings 4 x ).
This will only be a succesful repair if you stopped using the dryer the moment it started screeching.
If you have let it run, the metal-on-metal will have gouged the edge of the drum and will rip up any new replacement bearing pads.
Do not attempt this unless you are a very competent handyperson. Many screws lost, cut fingers and swear words will ensure if you are not confident in approaching this job, so either toss the dryer or get a competent repairman to do the job.
Posted on Apr 19, 2010
I am getting a lot of lint on clothing is there a cleaning process with my smart drive pride 5.5 fisher & paykel washing machine
clean the lint filter in the machine
put any clothes that are likely to shed lint or are susceptible to collecting lint in a wash bag before putting in the machine
Oct 17, 2017 | Fisher Washing Machines
I want to clean out lint filter of my fisher paykel washing machine but i do not know how to dissasemble the machine to get to iy
Search in Google how to change lint filter in fisher washing machine and click on images link
see and follow the photos
Dec 13, 2013 | Washing Machines
MW512 Fisher & Paykel Washer Machine...Where is the lint filter located?
Fisher & Paykel machines don't have a lint filter.
Manual cleaning of agitator and s/steel bowl will make your washing cleaner.
Oct 12, 2012 | Fisher and Paykel Washing Machines
The lint trap door won't come out. It is like there is a interlock that won't allow it to be pulled out and cleaned.
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 20, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Does it have a filter
Yes it filters on the outside od the tub through all the small holes you see, if it is not filtering lint do a hot wash to clean out old softner that can clog these holes.
Apr 04, 2010 | Fisher and Paykel Fisher & Paykel Washer
Mar 06, 2010 | Fisher and Paykel Dryers
The filter does not filter idon't know where it is to clean it
Filtering is performed by the perforations in the inner drum, which allow lint to exit but not re-enter. There is nothing that requires cleaning.
Feb 27, 2010 | Fisher and Paykel IWL12 Top Load Washer
Blocked filter in Fisher & Paykel washing machine top loader
Fisher & Paykel washers do not have lint filters inside the tubs as they are designed to drain away any debris from the wash during the drain cycle.
Mar 10, 2009 | Fisher and Paykel IWL12 Top Load Washer
Wont heat
the sensor may need to be reset. My felt filter had come off but the dryer worked fine until everything filled with lint. Much of the lint was in places you can't get to easily and Fisher Pykel doesn't mention cleaning these areas in their manuals. I know it is to late to help you but it may help someone in the future.
Nov 15, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Open Questions:
Dryers Logo
135 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
