1998 Dodge Caravan Logo
Posted on Jul 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need help please
I had my 1998 Dodge Caravan worked on today...I am going out of town on vacation...My anti theft alarm was triggered and my radio will not turn on...How can i get the code to disable the alarm?
Anonymous
Level 3:
  • Master 321 Answers
  • Posted on Jul 13, 2008
Anonymous
Master
Level 3:
Answers
321
Questions
Helped
271165
Points
1273
The code will be written down in the owner's manual.If you do not have your owner's manual,call a Dodge dealer with your VIN number (vehicle identification number),the service department.
I have a 1998 chysler town & coutry,,i need complite disarmed the anti-thif alarm hoe can i do it
Dealer needs to plug in a computer to reset unless you have the computer key. If you have the key with the chip, unhook the battery, lock and close all the doors. Tap the battery cables together then hook the battery back up and unlock the doors with the key. If you don't, then the alarm will keep going off. Low battery can also trigger the anti-theft system.
1997 dodge caravan, full battery, turn key and it clicks, door chime buzzes, wont start. what should i look at?
Corrosion at the battery cables first. After that, remove the alarm system. Fix the wires as you go.
2answers
Anti theft wont let me start car
The problem may not be with anti-theft but with a bad fuel pump,cam/crank sensor etc. Also, you may try unlocking the drivers door with the key. On most cars that is the standard method for disabling the security system.
2003 dodge grand caravan 3.3l wont start!
You may have to get the key reprogramed. The ECU is not reading the key, resulting in Anti-theft mode (Disable Ignition). You need the Dealer and OBDII Test .
2answers
Anti thief device
Check the help links mentioned below :---Relearn Theft deterrent module? http://technoanswers.blogspot.com/2012/01/relearn-theft-deterrent-module.html
---------theft deterrent module Relearning? http://howtobyme.blogspot.com/2012/01/buick-theft-deterrent-module-relearning.html
--------Engine will not crank after relearning Theft deterrent module? http://howtobyme.blogspot.com/2012/01/engine-will-not-crank-after-relearning.html
--------Can car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
Car Factory Alarm will go off? http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html
---------Car will not start security lock out? http://technoanswers.blogspot.com/2011/12/car-will-not-start-security-lock-out.html
---------Alarm will not disengage? http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html
--------This will help.For more info keep updated.Thanks.
6helpful
3answers
My 1998 dodge intrepid wont start and the alarm wont shut off
Try "cycling the key in the passenger door lock. Turn it all the way to the right and all the way to the left.
2answers
Need bypass factory alarm in 99 dodge
well thats an interesting idea but by bypassing the alarm your car will not usualy start it is a safety feature that is built in to all chrysler autos it will disable the starter coil door locks windows and half the electrical systm as a safety feature and anti theft feature
2answers
Single mom can't do nothing cuz of car
You may have a faulty ingition. Otherwise you have the very common GM anti-theft system. If you have a flashing anti-theft light with key in igniton, then this is what you should do:
Put key in ignition, turn to ON position (Do NOT Start)
Leave in on position for EXACTLY 10 Minutes
Then while watching the anti-theft light, as SOON as the light turns off after 10 minutes, START CAR IMMEDIATELY after light turns off.
This will reset the anti-theft
Battery replaced on 2001 grand dodge caravan now radio dont work
U will need to enter the radio anti theft code, this lock out was triggered by the loss of voltage to the radio during the battery change, this code is unique to each radio and cam in the owners information packet when the cat was sold new.
1helpful
VEHICLE WONT START
Section 13-11: Anti-Theft System, Active 1998 Windstar Workshop Manual DESCRIPTION AND OPERATION Anti-Theft Alarm System NOTE: The system immediately monitors the ignition key lock cylinder upon removal of the key from the ignition. It is not necessary to arm the system for ignition key lock monitoring.
The anti-theft alarm system:
  • protects the vehicle from unauthorized entry into the passenger compartment, engine compartment and cargo area.
  • monitors the status of the ignition key lock cylinder.
  • is controlled by a remote anti-theft personality (RAP) module. The remote anti-theft personality module also controls the electronic door lock functions. Refer to Section 01-14B for more details.
  • when armed, detects unauthorized entry into the passenger compartment by using an input from the GEM module regarding the state of the door or liftgate (open or closed).
  • protects the engine compartment with a hood switch which is located on the LH cowl vent panel and is part of windshield wiper motor wiring (17A477) .
  • triggers an alarm if the ignition lock cylinder is forcibly removed from the steering column.
Once triggered, the system responds by:
  • flashing the low beam headlamps, the parklamps, rear lamps and the alarm indicator warning light emitting diode (LED).
  • sounding the horn (13832).
  • disabling the starter circuit until the system is disarmed.
Remote Anti-Theft Personality Module
  • The remote anti-theft personality module is located behind the instrument panel (04320).
  • It contains a radio receiver that receives the RF signal from the keyless entry remote transmitter (15K601) through the alarm and lock system antenna (15603) and sends the appropriate command to the power door locks, the horn relay, or the generic electronic module.
  • The remote anti-theft personality module is equipped with an internal backup power supply which holds the programmed code in memory in the event the vehicle battery is disconnected.
Remote Anti-Theft Personality Module Removal
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove radio. Refer to Section 15-01 .
  1. Remove lower instrument panel center finish panel. Refer to Section 01-12 .
  1. Lower glove box.
  1. Remove two remote anti-theft personality module bracket retaining screws.
  1. Disconnect electrical connectors and alarm and lock system antenna (15603).
  1. Remove remote anti-theft personality module and bracket.
  1. Remove remote anti-theft personality module from mounting bracket.
Installation
  1. To install, follow removal procedure in reverse order.
  1. Tighten remote anti-theft personality module bracket retaining screws to 6-8 Nm (54-70 lb-in).
Components The system is composed of the following components:
  • remote anti-theft personality (RAP) module with integral antenna
  • alarm indicator LED
  • door lock cylinder switch RH, door lock cylinder switch LH
  • liftgate door lock cylinder switch (220A40)
  • hood switch (part of windshield wiper motor wiring (17A477))
  • ignition lock anti-theft switch (19A438)
The following vehicle components are also used by the anti-theft alarm system:
  • generic electronic module
  • power door lock switch (14028)
  • door open warning lamp switch (14018)
  • autolamp relay (14N089)
  • horn relay and bracket (13853) and horn (13832)
  • low beam headlamps
  • rear lamps (13404) and parking lamps (13200)
  • starter relay
  • door lock relays
  • keyless entry remote transmitter (15K601)
Disarming an Untriggered System NOTE: A perimeter alarm will "shut off" after 165 seconds, but the system is still triggered and is not disarmed.
An armed but untriggered perimeter anti-theft system can be disarmed by one of the following four events:
  1. Unlock the doors by pressing the keyless entry remote transmitter (15K601) UNLOCK button once.
  2. Unlock any door with a key.
  3. Turn ignition switch to RUN or ACC.
  4. The remote entry PANIC button will disarm the anti-theft system only when the perimeter alarm is triggered and sounding.
System Triggering NOTE: Although the remote entry PANIC alarm is not associated with the monitoring of the vehicle, the user will frequently say that the theft system was triggered when actually the keyless entry remote transmitter PANIC button was inadvertently pressed. A panic alarm will not flash the THEFT indicator.
The alarm can be triggered by the following events if the system has been armed and has not been disarmed first:
  • Open any door or liftgate.
  • Open the hood (16612) (if the hood was open when the system was armed, it must be closed before it can trigger the alarm).
  • Dislodge the ignition key lock cylinder.
  • The anti-theft system may be triggered inadvertently when the module is disconnected and then reconnected. To avoid inadvertent alarm triggering, disconnect the smaller 22-way connector first.
When the system is triggered the perimeter alarm will operate as follows: The remote anti-theft personality module will pulse the following outputs at approximately 1.3 Hz, 50 percent duty cycle for two minutes 45 seconds for North America. NOTE: Other perimeter alarms can be programmed for the system.
  • parking lamps
  • horn
  • THEFT indicator
The perimeter alarm can be retriggered, after a perimeter alarm has sounded for 165 seconds. After a perimeter alarm has timed out, if any trigger input is first seen as normal and is then seen in its trigger state, the perimeter alarm will be retriggered. The perimeter alarm can be triggered a total of three times between an arming sequence and a disarm event. An active panic alarm will be deactivated when a perimeter alarm is triggered (a perimeter alarm overrides a panic alarm).
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
