Question about Pioneer AVIC-N1 Car DVD Player
No power yel wire to bat +red to *** ingtion 2 blk wires to groud along with light green for emer brake we have nothing only red light Flashing (we have no remote) please help thank you
  • fancisco13 Aug 08, 2008
  • 171 Answers
First make sure you have constant 12volts (no matter if the car ignition is on or off even without the car key has to be 12volts) connected to the yel. wire, them when you put the car key at the accessories position in the ignition key you must have 12vol.
If the connections are ok, check the fuse, there is one fuse at the yel wire coming from the radio and also check the fuse at the fuse panel on your car.
Posted on Jul 29, 2008
1992 dodge dynasty radio diagram
Assuming the radio connects to the RS amplifier, the harness is as follows:
From fuse 13: PNK or BLK -> PNK/LT BLU -> PNK or BLK -> PNK/LT BLU -> radio (!)
From fuse 20: RED/WHT -> radio
From fuse 10: VIO -> amp
From radio: ORG and BLK/YEL to interior lights
From radio to amp: DK BLU/RED, BRN/RED, DK BLU/ORG, BRN/ LT BLU, VIO, DK GRN or DK GRN/WHT, DK BLU/WHT, BRN/YEL
From radio to pwr ant: DK RED/GRN
From RS amp to:
R. door: LT BLU/VIO and LT BLU/DK GRN
R. front: ORG/BLK and ORG/RED
R. rear: TAN/BLK, TAN/RED, TAN/DK GRN, and TAN/VIO
L. rear: WHT/DK GRN, WHT/VIO, WHT/BLK, WHT/RED
L. front: YEL/BLK and YEL/RED
L. door: LT GRN/DK GRN and LT GRN/VIO
Mar 17, 2017 | 1992 Dodge Dynasty
I have 1985 ford f150 5.0 v8 the starter soleniod wires got bat,starter and the 4 fusible linked wires are my problem which side do they go and how many on each post 1 red,1 blkandorg,2 yllw which are...
On the battery side should be the blk/org (alternator wire) and yel/blk-w/fusible link with of course the positive battery cable, On the other big terminal should be the other yellows, for your small terminal marked with an "i" should be the red/blue if it has the small terminal, if not on the big terminal opposite of the battery.
Mar 19, 2011 | Ford F-100 Cars & Trucks
02 altima wiring for all three harnesses
12V'green '+ 'ignition harness '
' STARTER'black/red '+ 'ignition harness '
' SECOND STARTER'black/yellow '+ 'ignition harness '
' IGNITION'black/red '+ 'ignition harness '
' ACCESSORY'red '+ 'ignition harness '
' SECOND ACCESSORY'white/blue '+ 'ignition harness '
' POWER LOCK'pink *7 '- 'pin 37 @ BCM by fuse box '
' POWER UNLOCK'brown *7 '- 'pin 44 @ BCM by fuse box '
' LOCK MOTOR'yellow/red ' 'pin 30 @ BCM by fuse box '
' UNLOCK MOTOR'green/white ' 'pin 23 @ BCM by fuse box '
' DISARM DEFEAT'green/red ' 'pin 31 @ BCM by fuse box '
' PARKING LIGHTS +'red/blue ' 'driver kick panel '
' HEADLIGHTS'blu (L), red/yel (R)'+ 'IPDM E/R *1 '
' DOOR TRIGGER'*2 '- 'BCM to right of fuse box '
' DOME SUPERVISION'comes on with unlock' ' '
' TRUNK/HATCH PIN'purple/white '- 'pin 18 @ BCM by fuse box '
' HOOD PIN'yellow/black '- 'hood pin switch '
'TRNK/HTCH RELEASE'red/blk or blu/red '- 'pin 76 @ BCM by fuse box '
' FCTRY ALARM ARM'pink/blue *3 '- 'driver switch in door '
'FCTRY ALRM DISARM'white/blue *3 '- 'driver switch in door '
' TACHOMETER'white/green ' 'ECM behind glove box *4 '
' SPEED SENSE'blue/yellow *5 '8 'pin 9 @ instrument cluster '
' BRAKE WIRE'red/green '+ 'brake pedal switch '
' HORN TRIGGER'green/white '- 'steering column '
' WIPERS'blu (L), blu/blk (H)'- 'wiper motor '
' LF WINDOW UP/DN'blu/red - blu/wht 'A 'driver window switch '
' RF WINDOW UP/DN'green - yellow *6 'A 'driver kick panel '
' LR WINDOW UP/DN'purple - blue 'A 'driver kick panel '
' RR WINDOW UP/DN'red/yel - yel/blk 'A 'driver kick panel '
' SUN RF OPN/CLOSE'not recommended ' ' '
' RADIO 12V'yellow/green '+ 'radio '
' RADIO GROUND' ' ' '
' RADIO SWITCH'purple '+ 'radio '
' RADIO ILLUMINATE'red/blue '+ 'radio '
' POWER ANTENNA'green '+ 'radio '
' LF SPEAKER'blu/wht - blu/red ' 'radio or amp under rear deck'
' RF SPEAKER'wht/blk - blu/blk ' 'radio or amp under rear deck'
' LR SPEAKER'grn/yel - blk/yel ' 'radio or amp under rear deck'
' RR SPEAKER'blue - red ' 'radio or amp under rear deck'
here is a wire diagram for the altima .you should be able to just buy a radio harness to attach to the factory harness with diagram of wires on back and find out what color are what on your factory wires
623.10482.150x100.nn03b.jpg 02 harness for your car from scosche
http://www.tintingbyfredjohnson.com
Dec 31, 2010 | Car Audio & Video
Stereo wiring for a 91 honda accord
1. red/blk ---------lighting switch
2.wht/yel-----------to fuse No.24 (7.5A) under hood relay box
3. yel/red---------- to fuse No. 11 (10A) Dash fuse box
4.brn/blk ----------- (--) R front speaker
red/grn ----------(+)
6. brn/blk-------------(--) L front
blu/grn
7.brn/wht -----------(--) R. Rear speaker
red/ywl-------------(+)
8. gry/wht----------(--) L..Rear
blu/yel ----------(+)
9.BLK----------------- to the ground.
Apr 05, 2010 | 1991 Honda Accord
1993 ford thunderbird stereo installation guide/ wiring guide
bat.-lt.gr/ppl; grnd-blk; ign-yel/blk; lights-lt.blu/red & org/blk; grnd-blk/org; L.F.-org/lt.grn & lt.blu/wht; L.R.-pnk/lt.grn & tan/ylw; R.F.-wht/lt.grn & dk.grn/org; R.R.-pnk/lt.blu & brn/pnk
Nov 07, 2009 | 1993 Ford Thunderbird
I am trying to find out the wiring colors and what they are. I am trying to install a cd player in my 94 honda accord but ca't figure out the wire colors to be able to hook up correctly. Need Help!!
yel/red battery(always hot),wht/blue hot w/ignition,red/blk hot w/lighting switch,blk ground,red/grn rt ft +,brn/blk rt ft -,blue/grn lt ft +,gry/blk lt ft -, blue/yel rt rr +,gry/whte rt rr -,red/yel lt rr +, brn/whte lt rr -
Oct 16, 2009 | Honda Accord Cars & Trucks
What are the stereo color codes for a 2002 jaguar x type 2.5.. hooking up amp with the factory deck and dont wanna buy the iso harness thaNKS
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red/grn & red/org |+ |ignition harness |
| STARTER|gry/blk or lt. blue |+ |ignition harness |
| IGNITION|green/black |+ |ignition harness |
| SECOND IGNITION|pink/white |+ |ignition harness |
| THIRD IGNITION|red/wht (key sense)|+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| SECOND ACCESSORY|pink/yellow |+ |ignition harness |
| POWER LOCK|black/blue |- |DDM *1 |
| POWER UNLOCK|black/white *2 |- |DDM *1 |
| LOCK MOTOR|yellow/black | |DDM *1 |
| UNLOCK MOTOR|white/purple | |DDM *1 |
| DISARM DEFEAT|white/green | |pass. kick, harness to rear |
| PARKING LIGHTS +|use neg. wire only | | |
| PARKING LIGHTS -|white/green *3 | |headlight switch |
| HEADLIGHTS|white/green *3 |*3 |headlight switch |
| DOOR TRIGGER|black/white *4 |- |underdash light |
| DOME SUPERVISION|comes on w/unlock | | |
| TRUNK/HATCH PIN|white/black |- |REM *5 |
|TRNK/HTCH RELEASE|black/blue |- |release switch or REM *5 |
| FCTRY ALARM ARM|arms w/ lock | | |
|FCTRY ALRM DISARM|disarms w/ unlock | | |
| TACHOMETER|brown or brn/stripe | |main harness pass. firewall |
| SPEED SENSE| | | |
| BRAKE WIRE|org/yel or org/blu |+ |brake pedal switch |
| HORN TRIGGER|gray/orange |- |FEM *5 |
| WIPERS|red/blk(L),red/grn(H|+ |wiper motor |
| LF WINDOW UP/DN|white - yellow |A |DDM *1 |
| RF WINDOW UP/DN|wht/pur - yel/pur |A |FEM *5 |
| LR WINDOW UP/DN|blu/red - pur/blu |A |REM *5 |
| RR WINDOW UP/DN|blu/orn - pur/wht |A |REM *5 |
| RADIO 12V|orange/black |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/green |+ |radio |
Notes:
NOTE: This vehicle is equipped with a passive immobilizer that needs to be bypassed for remote start operation only. Use DEI part number 555U to bypass. *1 The DDM (drivers door module) is located in the center of the drivers door. *2 Requires a double pulse to unlock. *3 Parking lights require a negative trigger with a 1800 ohm resistor in-line to the white/green wire. Using a negative trigger with a 780 ohm resistor in-line to the same white/green wire will turn on the headlights as well as the parking lights. *4 This wire may cause the aftermarket alarm to false when the vehicles electrical system shuts down. Use a relay to isolate it. *5 The FEM (Front Electronic Module) is located in the drivers kick panel. The REM (Rear Electronic Module) is located in the trunk, just above the battery. hope that helps
Sep 27, 2009 | Car Audio & Video
New vr-3 going into used 2004 Status. Current wiring has black connector and grey connector, also one blk/yellow stripe wire. Have wire colors written down, need to know what existing wires are -new radio...
According to www.the12volt.com The color codes for your vehicle are:
RADIO 12V CONSTANT |orange/black
RADIO SWITCH (ACC)|white/black
RADIO ILLUMINATE|green/white
LF SPEAKER|wht/blu - blk/blu
RF SPEAKER|wht/red - blk/red
LR SPEAKER|yel/blu - gry/blu
RR SPEAKER|yel/red - gry/red
Feb 24, 2009 | Clarion VRX935VD Car DVD Player
I need a wiring diagram for a stock radio
this info comes from 12volt.com :
RADIO 12V = yellow
RADIO SWITCH = purple
RADIO ILLUMINATE = red/white
POWER ANTENNA = green/white
LF SPEAKER = (+)blu/wht (-) blu/yel
RF SPEAKER = (+)brown (-) brn/wht
LR SPEAKER = (+)lt. grn (-) blk/yel
RR SPEAKER = (+)blue (-)pink
this info comes from alldata :
LH FR SP (-) GRN/YEL
LH FR SP (+) PPL
RH FR SP (-) BRN/WHT
RH FR SP (+) BRN
BATTERY BLUE
ILLUM CONTROL RED/YEL
LIGHTING YEL/RED
ACC PINK
AMP BLU/WHT
LH RR SP (-) BLK/PNK
LH RR SP (+) ORG
RH RR SP (-) GRY/RED
RH RR SP (+)GRY
Omega and alldata match , i expect the second set to match .
obviously only one of these color codes match your radio , which ever one matches , is the one . cheers
Jan 10, 2009 | 2000 Nissan Sentra
Pioneer AVIC-N1 Car DVD Player Logo
182 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
