Question about Linksys Wireless-G Broadband Router
Changing wireless channel
How do I change the channel on my wireless? i cant find anything about that on the default IP address...thanks again!
  • amoscochran Jan 03, 2009
    i am wanting to change the channel so my wii will work on the internet. i have gotten to the page where i can change the channel but my only option is channel 6. the drop down box only gives me 6 and i can not type a number in. help?
  • jgibson19 Jan 12, 2009
    My AT&T wireless phone (Blackberry Curve) is on the same frequency as my Linksys router. It knocks me offline constently unless I have the phone turned off. I thought the router was bad until I bought a second one and had the same problem.
  • 137 Answers
When you log into router you go to the Wireless tab and from there you are able to change the default wireless channel. It should be like a drop down box where you can click and have the option to change it.
Posted on Jul 14, 2008
    Scholar:
  • 59 Answers
Alright with linksys routers you go to the IP address in your browser usually 192.168.1.1 and then click on the wireless tab on the top. Make sure it's in manual mode then there should be a drop down with the list of channels. If you have any more questions just post them and out of curiousity why do you want to change the signal frequency?
Posted on Jul 13, 2008
Hallo, i recently installed and configured a WAp200E-EU-UK access point. i changed the default ip address to 192.168.1.11 and changed the SSID and key, when i logged out of the web interface, i could not...
As you have changed the default IP Address of the router, you can access the router by using the newly assigned IP (192.168.1.11) and new username and password (if you have made any changes to the defaults).
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 20, 2011 | Linksys (WAP200) (WAP200-UK) 802.11b/g...
It always shows unsecured net work
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Jan 10, 2011 | Belkin (F5D8231-4) Wireless Router...
How do i change the channel
In the 802.11b/g (2.4Ghz) standard there are 11 channels (US) to choose from, all but three are overlapping channels. Channels 1, 6, and 11 are the only non-overlapping channels. The channels can be changed to avoid interference from other wireless devices that run on the 2.4 Ghz frequency range (I.E. 2.4Ghz cordless phones, bluetooth, and X-10).
Step 1 Open your web browser and type the IP address of the router in the address bar. The default IP address is 192.168.0.1. At the login, enter your username (admin) and password (default password is blank).
Step 2 Click on the Home tab at the top of the configuration page and then click the Wireless button on the left side.
Step 3 Select a channel from the drop-down menu. For best results, use channel 1, 6, or 11.
Step 4 Click Apply and then click Continue to save your settings.
In most cases, you only need to change the channel on the router. Most wireless adapters will "find" your wireless network by the SSID you assigned to the router, and then will automatically lock onto the channel of the router.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 22, 2010 | Linksys Wireless-G WRT54G Router
My HP 309 series printer will not stay connected to my wireless network. Can someone help? I end up having to go through wireless network wizard all over again with my WEP password. Very time consuming!
Hello geekgurl !
There are a few things you have to check
When choosing a location for your wireless router, avoid having the following items between the wireless router and wireless devices on the network: long distances, walls, other wireless devices (like cordless phones), and large appliances.
Don't use two wireless routers in your home unless you are very knowledgeable about wireless networking. If your Internet Service Provider (ISP) provides your wireless router as part of their equipment, don't add another wireless router to it or attempt to change the existing settings without the ISP's help or knowledge.
Make the following settings on your wireless router, or verify that they've already been made:
1-Change the manufacturer's default name for the network name (SSID) to something unique.
2-Set the broadcast SSID to "on" or "enable". Note that "on" or "enable" is typically the default setting.
On the printer:
1- See if the wireless indicator lamp is illuminated. Can you turn on the wireless radio from the control panel of the printer?
Print a Network Configuration page and a Wireless Network Test report from your printer's control panel, if available.
* Does the Wireless Network Test report indicate trouble?
* Do the reports indicate that the printer is connected to your wireless router, and not to a neighbor's? The network name the printer is connected to will be shown on the both the Network Configuration page and Wireless Network Test report.
* Compare the printer's IP address to the gateway IP address. They should have a similar format (for example, the gateway IP address might be 192.168.0.1 and the printer IP address 192.168.0.5). If the printer has an IP address similar to 169.254.XXX.XXX, it probably is not connected to your wireless network.
* On some printers, the Network Configuration Page will list all wireless networks detected in your area. Is your network listed among those found? Does it have good signal strength?
* Are there several networks on your same channel or using channels close to your channel? You should use a channel at least 5 channels away from the closest used channel. Consider changing your wireless router's channel to 1, 6 or 11.
* Make sure your computer is not connected through a VPN (Virtual Private Network). You cannot access devices on your wireless network while connected to a VPN.
* Disable your operating system's firewall and your security system's firewall and re-test. If this fixes the problem open ports in the firewall.
HP's Network Diagnostic Utility can also be useful
Visit this link
http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-926&h_lang=en&h_client=s-h-e013-1&h_keyword=dg-NDU&jumpid=ex_r4155/en/hho/ipg/easy_wireless/network_diag/
Check if theres anyway to set an Static IP (does not change) on your printer instead of a Dynamic Hp (constantly changes)
Good Luck !
Aug 13, 2010 | Office Equipment & Supplies
I have Dlink 615 model router. i reset one time and now i want to change again my name and password but i cant log into. I try admin in with the IP address and also my user name and password but i cant get...
When you reset your router the IP address will revert back to its factory default IP address and access information, if you changed the IP address prior to the reset you will have to use the default IP.
default IP: 192.168.0.1 (make sure that your network cards IP address is somthing similar like 192.168.0.2 and not 192.168.1.2)
Default username: admin
Default pass: leave blank
If you are still having issues let me know.
Jun 20, 2010 | D-Link DIR-625 (790069292637) Wireless...
I purchased a wre54g range expander and have tried everything but it doesnt work
Who is the manufacturer of your wireless router?
check the IP address of your router.
connect the computer to the router and check the Ip address of the computer and the default gateway number. Default gateway is the IP address of your router. suppose the default gateway is 192.168.1.1. then open the set up page of the router . check the wireless settings of the router SSID ,channel and the security settings. Do not change the settings on the router.
If you are using WPA2 security settings them that will network on the WRE54G.
Now your range expander and the router IP addresses should be in the same range. Suppose you router IP address is 192.168.x.y and the IP address of the WRE54G is by default 192.168.1.240.
Now the x in the router IP address should be 1.
If it is, then connect the WRE to the router and open the set up page of WRE. change the wireless settigns on the WRE and power cycle the WRE and the router.
It should work
For more info about networking Click Here
Oct 06, 2009 | Linksys : WRE54G Wireless Range Extender...
D-Link AirPlus Xtreme G DI-624
Using the Configuration Menu
Note: if you have changed the default IP Address assigned to the DI-624, make sure to enter the correct IP Address.
 Open the web browser
 Type in the IP Address of
the Router (http://192.168.0.1)
12 Type admin in the User Name field
Leave the Password blank
Click OK
Home > Wizard
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
.13
Using the Configuration Menu (continued)
Home > Wireless
Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
SSID-
Channel-
6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP-
Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-624 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption-
Select the level of encryption desired: 64-bit, or 128-bit.
Key Type-
Select HEX or ASCII.
Keys 1-4-
Input up to 4 WEP keys; select the one you wish to use.14
Home > WAN > Dynamic IP Address
DI-754
Dynamic
IP Address-
Choose Dynamic IP Address to obtain IP Address information automatically from your ISP. Select this option if your ISP does not give you any IP numbers to use. This option is commonly used for Cable modem services.
Host Name-
The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address-
The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone
MAC Address-
The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the "Clone MAC Address" button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Enter a DNS Address if you do not wish to use the one provided by your ISP.
Primary/
Secondary DNS Address-
MTU-
Enter an MTU value only if required by your ISP. Otherwise, leave it at the default setting.15
Home > WAN > Static IP Address
Static IP Address-
Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address-
Input the public IP Address provided by your ISP.
Subnet Mask-
Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP
Gateway Address-
Input the public IP address of the ISP to which you are connecting.
Primary
DNS Address-
Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary
DNS Address-
This is optional.
Aug 27, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Problems with my new WNR834B
try to customize your wireless settings. change the wireless name/ssid to something else and change the wireless channel as well. verify also if there's a wireless security enabled, if it has you need to use the correct wireless security/network key when connecting your laptop wirelessly. you can go to the router's setup page to verify your wireless settings by typing the ip address of your router to the address bar of your web browser, http://192.168.1.1 (note: by default the ip address of the router is 192.168.1.1 unless you have changed it to something else. the default username is "admin" and the default password is "password")
hope this'll help you
ciao!
Aug 21, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Wireless channel
The ethernet cable connecting the router to the WAN doesn't require a channel. The channel setting is there for when laptop computer connects to the wireless router.
Channels 6 and 11 are mostly used in this scenario.
Does your wireless router communicate with your Internet provider wirelessly?
Hope this helps :) Please leave a rating. Thanks..
Nov 27, 2007 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G Broadband Router Logo
106 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
