Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Admiral refrigerator -shelf removal
Admiral refrigerator model ATB2110DRW -how do I remove the adjustable shelves. There are little blue tabs that seem to have something to do with it (like a locking mechanism of some sort) but they don't appear to "unlock". Any ideas?
You just "pop out" the blue clips. Then pull the shelf out and relocate it to your desired position. Lastly, replace the blue clip to the top of the hole where you placed your shelf.
Posted on Aug 08, 2008
How do I remove my refrigerator shelves
Donna, refrigerators change from model to model, shelf removal usually the same. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Remove Refrigerator Shelves eHow
Aug 26, 2016 | Refrigerators
How to remove shelves?
The Blue parts look like shelf locks for transporting the fridge. Remove the blue locks and then the shelves will lift up and out.
If you need assistance with the locks post a closer picture please.
Feb 26, 2015 | Refrigerators
I have an Admiral refrigerator and i can not see how to clean/empty the drip pan underneath--Isn't there one?
remove the plastic cover underneath the main door, then you can inter you hand inside the slot and find the drip pan underneath the refrigerator
Sep 16, 2014 | Admiral Refrigerators
Can i remove the shelves in frigadaire frezzer model frs6r4eq4
Good Afternoon Friend,
I understand you want to know if you can remove the freezer shelves in your Frigidaire refrigerator, model# FRS6R4EQ4. All the shelving in your freezer is fixed, however the bottom shelf, which is located on top of the freezer basket, should flip up to allow more room for tall items that you wish to store in the freezer basket. Hope this is helpful.
-Best Regards-
Jun 14, 2014 | Frigidaire Refrigerators
Shelf lock removal on ref shelves
open lock on one side remove then slide shelve to the side to release
Apr 07, 2014 | Dometic Refrigerators
Fresh food door will not close/seal
Check to see if one of your door shelves is bigger (sticks out more into the fridge) than the other ones. If it is, theses shelves can cause door closing problems. Try removing the shelf from the door and closing it again. If this shelf is the problem, call subzero at 1800 222 7820 and give them your model and serial number, and they will send you a new standard depth shelf to replace the deeper shelf at no charge, these shelves caused a lot of door closing problems when they came out. Hope this helps!
Sep 07, 2013 | Sub-Zero 690 Side by Side Refrigerator
I cannot figure out how to adjust my shelves. There is a blue tab at the back and I cannot seem to pry it loose or remove it ino order to move the shelves.
thast blue plastic tab is a shipping tab,
grab it with pliers and pull straigt out..
remove all the blue tabs
Oct 04, 2009 | Maytag Refrigerators
Maytag refrigerator MSD2454GRW shelf removal
The above answer is only HALF right. The blue clips have to be removed to lift the shelf up and pull it toward you.
To remove the clips:
1. Get a screw driver or something to get behind the clip.
2. Slide it behind the clip and slowly pry it toward you.
3. Repeat for the clip on the other side.
4. Do the above; lift the shelf slightly and pull it toward yourself.
Dec 17, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Cleaning Glass shelves mold.
the shelves can be removed not taken apart. sorry they're glued together, just use a bristle brush and some bleach. no problem.
Mar 30, 2008 | Refrigerators
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
483 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
