Question about LG LMV2053 Microwave Oven
LG LMV2053ST sound of sparks at top-front-right side.
When i plug my 16 month old LG LMV2053ST microwave oven to power, the display is blank and there are sound of sparks at top-front-right side of the unit. we use the vent fan a lot but rarely use the microwave. thanks.
  • twoduck Jul 13, 2008
    Mr. Miller:
    I thank you for taking time helping people. I used chopstick with cloth to remove some grease through the fins then plug LG LMV2053ST microwave oven to power, the display is back to normal. It heat food as normal but there are sound of sparks at top-front-right side of the unit from time to time. I will clean up some more. Can anyone show me how to open up that section so that I can clean it thoroughly? thanks.
  • LG Master
  • 9,098 Answers
It sounds like your varistor or low voltage transformer on your control circuit board is failing.
We repair these for customers nationwide with our guaranteed $39.95 service.
Please feel free to contact me directly if you need more help. And please mention your model number when you write.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 12, 2008
  • William Miller
    William Miller Jul 13, 2008
    Okay, sorry if I misunderstood before.
    At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes: http://www.microwavedisplay.com/
    Please write back with more details if you need further help.
I have a old jenn air wall oven and a old jenn air microwave mounted on top. it was a countertop model. when i removed it it was plugged into the top of the oven. would that be a 110 appliance outlet?
The Jenn Air microwave that is mounted above the oven in your unit is 110v 60Hz. The socket in the upper rear right corner of the oven is a 110v 6Hz socket and is where the microwave would be plugged in. If you are going to replace the microwave, you can plug it into that socket. If you would rather not use that socket, you will have to drill a hole in the side of the cabinet holding the over/microwave to get the power cord out.
Sep 29, 2014 | Jenn-Air Microwave Ovens
Microwave is 6 months old. clock won't light up. when i try to set cooking time the inside starts making a clicking sound and a light flashes in the top right inside
Sounds like the waveguide cover has been contaminated with food that has carbonised and burning.
Call a Whirlpool repair agent and get the waveguide cover replaced.
They need to be kept clean and leaving the door open after cooking helps to dry the moisture out in the cavity. Making it last longer.
Jan 23, 2011 | Whirlpool MH1170XS Microwave Oven
Fire sparks when in use off pad on right side of microwave
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jul 09, 2010 | Dacor DMT2420SS Microwave Oven
Not heating digital display says
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
Jun 11, 2010 | Maytag MMV1153A Microwave Oven
Microwave LG LMV1630 st is totally dead after power outage
yes it s a large ceramic fuse and you have to remove the outer cover to access this. it will be on the top of the M/wave frame either front L or front right. Cost is about $40.00
Please rate our help to keep the sevice online
Aug 20, 2009 | LG LMV1630ST Microwave Oven
Emerson Microwave stopped working
Have 1 of 2 choices, the main fuse or the control board for the front switches and clock. primary of the small power transformer has opened. Unplug the unit and take case off and measure the fuse with an ohm meter. if u read 1 ohm or less then fuse is good. then measure across the main power plug tips. If read open then the power transformer is bad. Need to replace the board as not sure if transformer is available.
Jul 26, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Crackling sound in microwave vent when power is off
By "powered off" can I assume you mean that it is plugged in and at idle, not cooking, just showing the clock?
If so, I'd say your control board is failing.
If my assumption is wrong, please write back with more details.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
Nov 02, 2008 | GE JEM25 Microwave Oven
I have a GE profile advantium oven. The oven seems to operate, however the green display is blank with a dash in the upper left corner. Cannot set clock or get any written information from the green...
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Jul 10, 2008 | GE Microwave Ovens
NO power display dimesnion 4 range national microwave NNC 2000P MODEL
on front panel there is alow voltage transformmer the primary side isopen circuit replace
Mar 20, 2007 | Panasonic NN-C994S Convection/Microwave...
LG LMV2053 Microwave Oven Logo
336 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
