Hi, If the problem is associated to you replacing the battery, then it could be a few different things. 1) Is the replacment battery fully charged? If not, charge and retry. 2) Are the positive and negative battery cables connected correctly to the battery? With this you have to be sure that you have a good connection to each battery terminal. Try removing the cables and taking a wire brush to the terminals. Once clean, reconnect them and try to start again. 3) Is the positive cable broken? If broken replace the cable. 4) Is the negative battery cable broken or properly connected to the car? If broken, replace the cable. Good Luck!
SOURCE: 2005 nissan frontier crew cab won't start
Make sure you have 12 volts from the positive side of the battery to the starter. Check the small wire on the starter solenoid and make sure you have 12 volts when cranking engine. If voltage is correct, the starter is bad
SOURCE: where is the fuel filter 2005 nissan frontier?
Built in the gas tank. It is cleanable. Don't have to buy a new one.
It is built into the pump so if it would have to be replaced then you
would have to replace the whole pump. To me thats pretty crappy design.
Crawl under the truck, you should have two or three lines coming off the fuel tank, one will have the filter, one is the return, and one is emissions.
SOURCE: 2005 nissan frontier wont start i have fuel and
Take one of the spark plugs out and let us know what it looks like. Dry and light grayish tan means you have spark but fuel supply problems. Wet spark plug that smells like gas means it is more of a spark issue.
Good Luck
SOURCE: Problems starting my 2005 nissan frontier
Sounds like the battery is weak which will cause the gauges to twitch.
Testimonial: "solution was correct battery needed to be changed "
SOURCE: I have a 2005 nissan frontier it wont start. It's
You need to check that it is getting proper fuel & presser,Has there been any maintenance,That is a good place to Start, it sounds like it is getting spark You mite wont to make sure , Hope this helps you get started fixing, feel free to ask again if we can be of any farther assist. Thank you,
