Hi its me again
IT IS THE TOP PORTION OF THE AGITATOR THAT IS NOT TURNING DURING THE WASHING CYCLE.EVERYTHING SPINS DURING THE SPIN CYCLE.SOMETIMES WHEN CLOTHES ARE WASHING IT SOUNDS AS IF SOMETHING IS GRINDING INSIDE THERE.I WAS TOLD THAT THE AGITATOR IS STRIPPED ON THE INSIDE-PLEASE HELP (IF YOU CAN FIGURE IT OUT)MODEL # LXR9245EQ1=WHIRPOOL
  • 246 Answers
Sorry for the delay. You need to replaced your agitator dogs. (yes this is really what they call them). They are 4 small pieces inside the agitator that act as a "clutch" They allow the top half of the agitator to turn freely one direction and not the other. When the worn dogs slip, it causes a grinding/ grunting type noise from the machine. So first this fist. You will need to purchase the inexpensive dogs from a local appliance parts store or from the manufactures web site on line. (part # 80040).
For the model you have, begin by removing the fabric softner dispenser on top of the agitator. It just sits in the with a clip, so gently rock it back and forth until it comes free. Under it you will find a mostly clear plastic cap with a black seal around it. Use the tabs on the cap to pry/ pull it up. Underneath you will find a 7/16" bolt. Go ahead and take that out. Now you will be able to remove the top half of the agitator by pulling it straight up. If the bottom half comes with it, not to worry. Look down in the opening where you just removed the bolt from. On the bottom you will see 2 white plastic tabs, pry these with a small flat head screw driver to separate the lower half from the upper half. Now weather you had to separate the 2 halves or the top came off by itself, take the top half of the agitator and turn it upside down. You will feel the inner piece fall out. Now we will work with just the inner peice. Turn it upside down (so you can see the dogs just like the ones you purchased) There is a small collar that keeps them in place. Gently pry it up. (it should slide pretty easy. Remove the old dogs. Now using a paper towel of washclothe, wipe down any fabric softner, or shavings from the old dogs, so the new ones can move smoothly. Install the new dog and begin re-assembly. I would reccomend wiping out the inside of the large peice that is one the top half of the agitator too. Re-assemble in reverse order. To get the clear cap back on more easily, a thin rubbing of liquid detergent or fabric softner on the edge of the black seal, will help it go in without binding so much.
Posted on Jul 17, 2008
  • issomig Nov 28, 2010
    I have the same problem above, needing to change the dogs in the agitator. But I can not get the fabric softner dispenser off. I tried to unscrew it, pop it off, and even gently rock it back and forth. It is not budging. Any ideas?
Grinding noise during spin cycle/ will not spin
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Aug 04, 2009 | Washing Machines
Noise during spining cycle
Jul 22, 2009 | Kenmore Washing Machines
Kicking out water during wash cycle - spin instead of agitation
Try these
  1. Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  2. The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  3. Check the drain control lever
  4. Test the drain control coils
  5. Check the cam bar
pls rate my suggestion..
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
I have a GE Profile Prodigy top load washing machine. Sometimes the spin cycle does not spin, sometimes it spins. It makes a clicking noise during gentle cycle
The gears maybe going out. Sometimes it is able to engage in the other direction which the spin, sometimes not. Washing machine have complex gears that in one way agitator works, and the other the gear locks to turn the whole tub. The clicking noise is probably the locking mechanism in the gears that has caused the whole intermittent problem.
Jul 01, 2009 | GE Profile Prodigy WPSE4200A
Agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Jun 29, 2009 | Washing Machines
Washing machine skipping cycles, not spinning noisy
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
May 04, 2009 | Washing Machines
Drum won't spin during wring cycle.
Jan 31, 2009 | Washing Machines
Spin cycle with agitation motion occurring simultaneously
Hi again,
Appreciate the "Ask Me".
I believe the dampness is due to slow spin speed as you also have concluded. And I suspect that partial winding of the motor is the culprit. Hence, replacement is in order.
As to your concern why the agitator also operate during the spin setting, it could possibly be stuck or locked agitator dogs. Agitator dogs function is better explained here by another FixYa member, jsrock516.
Cheers.
Jul 25, 2008 | Washing Machines
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Washing Machines Logo
296 people viewed this question
Top Washing Machines Experts
