Question about HP LaserJet 1018 Printer
Problem with hp laser jet 1018
I have install the Hp printer 1018 but when connect and switch on it bring the following error massage "USB Device Not Recognized. One of the Usb devices attached to this Computerhas Malfuntioned an Windows does not recognize it.
I have try to find drivers on the hp site it did'nt help.
then i 've tryed to install it to other cmputers and it works.
I need the windows xp driver
Posted on Aug 09, 2008
How can fix this error. i seen this "the hp laser jet 1018 has the front cover door open or the toner cartridge is missing"
Hello !!
For tha particular error you are facing, here is the reason. These printers have a switch that triggers an interrupt when the toner door is closed. Usually there is an arm on the door that pushes the switch. It is quite sensitive and delicate. Then sometimes there is a tab on the printer's toner and if that breaks off then that error will be generated.
But in your case as you have not removed or inserted the toner, I think option 1 is applicable to you.
Now, if this printer is in warranty you should send it to HP for Free repair/replacement.
and chek BLOW links too for paper jam and cleaning
Paper jam Message Displays for HP LaserJet 1018 1018s 1020 and 1020 Plus... Cleaning the Printer
Dec 23, 2014 | HP LaserJet 1018 Laser Printer -...
I have a Hp 1018 laser jet printer, trying to install it but don't have the CD. Im trying to go through the add printer wizard but at the part where I have to select my exact printer, it is not listed?...
The link below brings you to the HP Support site for your printer. You will find a drop-down menu to choose your operating system, select your operating system and click the "Next" button. You will be presented with a few different downloads. The recommended one is under the section called "Driver - Product Installation Software" and the file is "HP LaserJet Full Feature Software and Drivers". Download and install this to get your printer installed.
HP LaserJet 1018 Printer Support Downloads
Apr 06, 2011 | HP Computers & Internet
Ineed to conect hp Laser to my computer to print my documents
To use the printer with your computer, first you have to install the drivers and make power cable connection. HP LaserJet 1018 has USB connectivity. So, you have to connect it to the PC via USB Cable.
HP LaserJet 1018 Drivers & User Guide
Visit the above links from HP Official Support and download the Drivers for your Model of the printer and Operating System (e.g. Windows XP) and user manual. Double-click the downloaded driver file and follow the on-screen instructions to install the printer.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 18, 2011 | HP LaserJet 1018 Printer
How to install hp 1018 laser jet soft ware for a window 7 32 bits hp system
Hello and Welcome to FixYa!
You can download the basic Driver from the vendor's site, the installation instructions are simple download the driver from the link I've provided below, after downloading, run the file its a self-extracting process. Click to accept the terms in the license agreement. Click Next. Driver installation begins. Driver files are pre-installed during this process. A screen pops up to prompt to connect the USB cable. Insert the USB cable. Device is connected, waiting for PnP (Plug n Play) to finish installing driver. Click Finish to complete software installation.
If you got any questions/queries, do ask us. We are here to help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S; Download Link
Aug 07, 2010 | HP LaserJet 1018 Printer
I want to download driver hp laser jet 1018 so what i do
Use the link below.
HP LaserJet 1018 Printer - Download drivers and software
Download and install the driver first. Do not plug the USB cable until asked by the driver setup wizard.
Here more drivers for different brands:
I misplaced my printer driver disk.
How to download driver for a Canon printer...
How to install a Lexmark printer.
Apr 27, 2010 | HP LaserJet 1018 Printer
Can not install hp laser jet 1018 printer without cd
I dont know if you have or not but you could go to the hp websight and let them detect you printer and see if that will work.Hope this helps. Ken
Dec 09, 2009 | HP LaserJet 1018 Printer
I cant install hp laser jet 1018 on this board
Hi h_kanani1366,
It doesn't sound like your problem is with the printer, it sounds like your problem is with the USB drivers for the motherboard. Look in Control Panel and click on System, then click on the Tab that's says Hardware, From there click on Hardware Devices, and when it opens look down on the Systems configuration area and look for a ! in a triangle. If you find one then the problem is the driver. You'll need to go to the manufacturer's site for that Motherboard and download a new USB controller driver, or sometimes there call Chipsets drivers. And that should fix your USB port, if the drivers aren't the problem, then could have a faulty motherboard. Try putting something else that you knows works into that same USB port to see if you get the same response. That will let you know if it's the motherboard, or it could be the Printer or the Cable that your using to connect to.
That's it my friend, there can be no other reasons I can think of.
Good Luck,and don't forget to leave a rating based on my solution.
Thanks Mark
Apr 08, 2009 | EliteGroup P4VMM2 Motherboard
Hp laser jet 1018 problem
try to connect the usb of your printer at the back usb ports of your CPU. and try to scan your device.
or
Do as follows inst.
Unplug your printer usb on your system. then attach it back to your computer then power on your printer.
Do right click my computer>properties> in system properties select hardware> then, click the Device Manager> tab, then select your device on PORTS. then click the scan for hardware changes> to scan your device. this icon can be found above or click Action menu and select >scan for hardware changes.
then restart PC. Hope you can do it. And it will help you.
thanks.
Jun 04, 2008 | HP LaserJet 1018 Printer
How to get a HP LaserJet 1018 to actually print something?
Yes it is a print driver problem, Unplug usb, delete all previous attemps at install, delete print software and drivers, Download and install correct driver from HP, plug in usb only when directed to do so.
Dec 18, 2007 | HP LaserJet 1018 Printer
292 people viewed this question
Ben Johnson
