Question about Gateway Computers & Internet
I have a Gateway notebook model MX6956. Upon startup, I get ascreen that asks if I want to start normally or in safe mode. Either one gets me an error message that starts with UNMOUNTABLE_BOOT_VOLUME and then the computer will restart itself after a few seconds. I have pictures I would like to get off the hard drive but can't get the computer up long enough to do so. I made recovery discs after it's purchase but would like to save the pictures if possible. Would appreciate any help
    President:
  • Gateway Master
  • 1,314 Answers
1. That would indicate your hard drive is either bad or corrupt.
2. You can try and boot of your windows xp cd, select R at the first prompt to go into recovery console and run chkdsk. That often fixes these kinds of problems.
3. If that doesn't work, you can take your hard drive and, using a usb enclosure or cable to convert the type of hard drive you have to usb, attach it to another computer and remove your files that way.
4. If the chkdsk didn't work, it may be time to purchase a new drive.
Thanks and please take a moment to rate as fixya. Thank you.
Posted on Jul 12, 2008
How to safemood in asus x200m
Normally on start up screen bottom left should say press f2 for bios you should press f8
Jul 22, 2014 | ASUS NB X200MA-QSP2T-CB 11.6 Pentium N3520...
I cant figure out how to get my laptop off of safe mode
at startup press f8 anf select "start computer on normal mode"
Jan 14, 2013 | Gateway P-6831FX Notebook
Averatec 3200 PC Notebook freezes at startup but
I suspect one of your startup items to be causing this problem. I suggest you to disable the startup items in safe mode and then try booting in normal mode.
Since you have already tried in safe mode i believe you know how to get in there so lets start from second part on how to disable the start up items.
Step1: Click on start and then click on Run.
Step 2: Type msconfig and hit ENTER.
Step 3: Click on Startup tab.
Step 4: Click on Disable all then click on apply and then Click on OK.
Step 5: Your system will be prompted for a reboot. Go ahead and restart it.
Step 6: As soon as the system is backup you would get system configuration utility screen where in you should check "Don't show this message again".
If you are curious to know which start up item is causing this problem then you might want to try enabling few at a time and narrow down.
Jan 15, 2011 | Averatec 3200 Notebook
My sons acer kav60 is stuck on the windows start up screen and will not reboot.
If it's still under warranty, take it into the shop for repairs.
Jan 14, 2011 | Acer Aspire One PC Notebook
I need to do a System Restore on a Gateway 7322 Laptop
try running this virus FREE prog No cost- removes too...: http://www.f-secure.com/en_EMEA/security/tools/online-scanner/
Jun 29, 2010 | Gateway 7322GZ Notebook
Gateway MX6956 screen flashes when dc adapter plugged in...hard t
The jack is soldered to the mo bo. If that is the only thing wrong all you have to do is open up the unit carefully, get access to the mo bo, resolder it and reassemble everything. A real PIA job but do able. Good luck
Sep 18, 2017 | Gateway MX6956 Notebook
Laptop goes into loop upon startup...
How did you manually configure it to go into safe mode? Did you edit boot.ini? if so try editing this back to normal. You could try hitting F8 on startup and doing a different Safe Mode startup to break the loop. From there you may be able to get it stable enough.
Another option would be to make a Bart PE boot disk and use that to edit Boot.ini
Dec 17, 2009 | IBM ThinkPad T42 Notebook
Gateway laptop mx3414-black screen cannot load windows
Try going into safe mode upon startup by hitting the F8 button. If it does then hit safe mode to get into your computer. Go to start>accessories>system tools>system restore. Follow the wizard to restore your computer to a date earlier than when you started having problems. Let me know if you have any problems or questions.
Mar 19, 2009 | Gateway MX3414 Notebook
Computers & Internet Logo
55 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
