Question about Toshiba Computers & Internet
AC adapter not working in power socket at back of toshiba laptop mx30-156. The power will only come on if it is held into the machine
    Sergeant:
    Champion:
  • 285 Answers
The dc jack is loose from the board and would need soldering back on.
Posted on Jul 12, 2008
Toshiba satellite c55t wont power on, just blinks once every 4 seconds
check power cord is fully inserted into laptop
if no joy
try also forcing a power down by holding in the power button for 30 seconds and then try power button again to power it up .
might be in hibernate mode !
Dec 04, 2017 | Toshiba Computers & Internet
Toshiba satellite c655 won't power up
Take off the top keyboard and power lid. Check for damage to the power flex cable. Plug in AC adapter. The port where connected power flex cable should have two or three pins. With small screwdriver try two-pin jumper shortly. Does not turn on again? All you need to replace the motherboard
Oct 04, 2013 | Computers & Internet
Toshiba laptop will not turn on
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Mar 01, 2013 | Computers & Internet
Dead Board or Battery? My "new to me" Toshiba Satellite M55 worked for about 30 minutes w/out external power. When it told me to plug it in; I did. It gave about three more warnings to plug in; then d
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 09, 2013 | Toshiba Satellite Laptop / Intel Core i3...
I have a toshiba laptop about 2 years old. I didn't use it for a few days and now it won't turn on at all.
was it plugged in when you tried to turn it on?
if not, try charging it for a couple of hours. the battery must be completely empty
other than that I might need more details
Aug 07, 2011 | Toshiba Computers & Internet
I shut down the laptop at once and i turned it on immediately.so only power light is on and the computer is not working.only black screen is seen.
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
Jul 11, 2011 | Toshiba Satellite P105-S6084 Notebook
Ac adapter dont work it isnt the laptop itselfs its the ac adapte
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
The adapter is a sealed unit and is very difficult to open and repair. Usually you need to replace the power adapter.
Oct 19, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba satellite m35
Are you sure that you fixed the power issue it sounds like there is still a bad connection in the power socket if you want info on this problem go to this site http://www.ask.com/bar?q=laptop+repair&page=1&qsrc=0&ab=1&u=http%3A%2F%2Fwww.laptoprepair101.com%2Flaptop%2F2006%2F01%2F04%2Ftoshiba-laptop-overheating%2F
Mar 29, 2009 | Toshiba Satellite M35-S456 Notebook
Worked fine yesterday, today zilch !!
One computer I fixed had its internal power regulation confused. With the AC adapter plugged in, holding the power switch down for twelve seconds, then pressing it again, switched it back on. This sort of problem can come from a variety of causes, though. There is an internal power distribution chip which could have received a static electric shock or power surge and gotten cooked. The RAM could have gone bad. The socket where the adapter plugs into the computer could have been cracked loose. Check the power switch and then RAM first, and write more if that doesn't fix it.
Jan 05, 2009 | Toshiba Satellite M105-S3041Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
