Question about Apple iPod nano
Ipod probelm my ipod not working
  • john_killerk Jul 16, 2008
    my ipod shows wait logo and stand on it it do not go more plz help me
    on this john_killerking@yahoo.com
  • Anonymous Jul 22, 2008
    Yes my i pod is not working.
  • 3 Answers
How old is it? Do you exclusively charge through the USB cable? I had the same thing happen to my Nano (2ndGen 4GB) turned out my battery was hosed. I didn't know that using the USB cable to charge it would over time reduce the battery's ability to hold a charge. If that's the problem, Apple will charge you $60 to replace the battery, and you should be good.
If you have data on your iPod you don't want to lose, or you have personalized it, Apple repair might not be desirable. They don't usually return your unit to you, they replace it with a refurbished unit. If that's the case, you probably want to go thru a third party.
I had my name engraved on the back of mine, so I went to Vaxtex, a little company I found on the internet. They charged me the same thing as Apple to replace the battery, and sold me a high-voltage charger so it would last longer. Took about a week, and then I was back in business.
Posted on Jul 24, 2008
Not showing display
Posted on Jul 22, 2008
  • 38 Answers
Est solution is to reset it
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Hope this helps
Posted on Jul 20, 2008
ITouch not connecting to wireless
Do you still got your manual? If you do go to the back and find your page that has a number for your apple ipod type, then they should be able to help you with your probelm. If you don't have it, go to your ipod website and type in there search box WGR614v6. Then it should have help or support or firmware and it should fix it. Hope it works.
Aug 26, 2009 | Apple iPod touch
My ipod won't let me go back to main menu and i can't turn it off
The easiest solution is to restore your ipod. This will erase everything on it and reset it back to factory defaults. You will need to sync when complete to copy your songs / apps / settings back over. Make sure you've synced recently before you try this procedure.
Press and hold the power button and the home button at the same time. Continue holding. Your ipod touch will power off. Wait a few seconds, and power it back on. Is it working now?
If not, turn your ipod back off then press and hold the Home button. Reconnect the USB cable to the ipod touch and your computer. When you reconnect the USB to ipod, the device should then power on.
Continue holding the Home button while it starts up. While starting up, you will see the Apple logo.
When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message. Click OK and iTunes will restore your ipod to factory defaults and re-sync your data.
If this is helpful, please rate me accordingly. If not, let me know and I'll see if I can offer other suggestions.
Mar 29, 2009 | Apple iPod touch
My ipod wont turn on or charge.
More than likely the battery just needs to be replaced. I let my nano go dead and it was doing the same thing. So just get it replaced and that should fix your problem.
Mar 23, 2009 | Apple Audio Players & Recorders
Nothing recognizes my ipod.
it is may be becoz the usb hub of your ipod have a probelm try to connect or plug it to the other computer if still it wont work then it is broken... sometimes this hub have lead malfunctions. though it beep but it does not recognize it... the cause of it was that few lines from the ipod hub are either short circuit or cut...
hope i help u....
Feb 20, 2009 | Apple iPod classic MP3 Player
How to Unlock Passcode on Ipod touch
Hey
I've written the solution to this problem on this page
http://www.fixya.com/support/r977231-disabled_or_code_forgotten
let me know if you need anything else.
Feb 02, 2009 | Apple iPod touch
ITouch screen frozen on USB and ITunes
ipod touch only reads apple's usb cord are you using apples usb cord
Jan 11, 2009 | Apple iPod touch
Pros and Cons
Sansa e200 is increasingly not supported by the manufacturer, it may require you to manually switch between USB modes, and generally has a lot of problems. I can't think of any pros, actually.
The iPod has great support from the manufacturer and rarely has a problem that can't be solved. It is hard to use an iPod on Windows Media Player, but definitely not impossible. The probelm arises when you try to sync with Windows Media Player AND use iTunes.
I would definitely go with the iPod. Sansa sucks.
-Tha Mp3 Doctor
Dec 22, 2008 | SanDisk Sansa e250 MP3 Player
My ipod did not charge when i connect it to the usb.
check the usb that might be broken if thats not the case then you might have a dead battery on your case. And if you have questions you can allways call apple and they will help you with and probelms when mine broke they gave me free software update that didnt even come out yet for the ipod it was a spaecial update so yeah give them a call or make an appointment online at the apple website and they will help.
Nov 28, 2008 | Apple iPod MA446LL/A MP3 Player
No sound from ear phones or docking jack
if the ipod has a probelm thats not phyisical damaged done by you and its still has one year warrenty hasnt exspired then they will refuned you with a new ipod.
Apple iPod nano Logo
65 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
