Question about Kenwood KDC-MP528 CD Player
Reseting cd player
After changing battery on my car my cd player need to be reset it becouse it plays for about 30 minutes and then it will turn off automatically
ce player is kenwood kdc-mp528
    Problem Solver:
  • 20 Answers
Is it connected to your ignition if so then unplug the cd first and them your battery in this sequence negative first then positive and wait ten secs.then reconnect with positive and then negative and then replug the cd.
Posted on Jul 12, 2008
How do i reset the cd player/exchanger of my 2000 dodge neon es. The lights continuously blink since the battery was disconnected to clean the heater core.
pull your neg . cable off battery then turn your key to on position ...leave on for 15 to 30 seconds .then turn to off position ..reconnect neg cable
Jan 05, 2015 | 2000 Dodge Neon
Panel lights up, plays CD, plays iPod, but none of the controls work.
switch off, remove battery and replace it after two minutes. switch on. Goodluck Mark
Dec 03, 2013 | JVC KD-HDR50 Car CD/ MP3 Player
Philips Gogear Connect 3 8Gb runs out of battery in less than two hours.
I had the same issue. Device would charge in 30 minutes, but would then die in about 40 minutes of playing music.
Solution in my case was to reset. The first time I tried the reset I did it with the device off and that didn't seem to work, the second time I did it with the device on and it worked great. The device showed 8% battery life remaining. I reset and turned the device back on and it showed 93% battery life remaining!(I did not charge it) Since that time I have been playing music through Bluetooth to some remote speakers and still have 91% battery left.
To reset get a pin or knife and push in the small reset button on the non button side of the device.
Good Luck!
PS - If you don't own a Phillips GoGear Connect 3 DO NOT buy one. This problem aside it is the worst mp3 player I have ever owned. And if you subscribe to Rhapsody THIS IS NOT RHAPSODY ENABLED.
Jul 12, 2012 | Philips Gogear Connect 3 8 Gb Digital Mp3...
My DP-M5560 wont play the cds and is frozen. Is there a security reset process that will reset it?
The only thing you can try, unplug cord from wall receptical, press and hold power on for 30 seconds to get rid of any residual charge, allow player to sit for 30 minutes before you plug it in, this will usually reset the microprocessor in hopes it will make the equipment respond.
Mar 06, 2012 | Kenwood Audio Players & Recorders
CD stuck on Pause
you can try resetting it. there might be a hole about the size of a pencil tip on the sub panel (behind the face). if no reset switch, try disconnection power to the radio. if you can't get to the back of the radio to disconnect the wire harness, try disconnecting the battery for a few minutes.
Apr 21, 2010 | Alpine CDA-9827 CD Player
Message center displays "CD Changer Error" Won't play music, or display mileage info
reset the computer by disconnecting the battery for 30 minutes.
If that doesnt work you will have to take it for repair. the dealer is very expensive on this, my experience is it is cheaper to take it to a audio specialist who is cheaper and will do a better job.
Oct 08, 2009 | 2004 Chevrolet Malibu Maxx
The player will not eject the cd but it will not play it either.
I know it sound crazy, but turn the system on, press eject while using a PLASTIC knife to lift the CD in the player. If the system is stock also try disconnecting the radio fuse for about 10 minutes or so with the car off. Reconnect it to see if the radio resets. You'll know the power completely went out because you'll have to reset your stations. By Resetting, hopefully the issue will solve itself. In a few of the system issues I've seen, when the motor won't open the faceplate, or the CD player won't give the CD back. I usually remove the faceplate or disconnect the negative side of the battery for about ten minutes. Try this if the fuse removal doesn't work. Good look. Let me know how it goes. there are other things to try.
Jul 27, 2009 | 2004 Honda Pilot
Sony Xplod - cd reset
UNPLUG THE HEAD UNIT HARNESS FROM THE HEAD UNIT. WAIT 30 SECONDS REPLUG AND RESET and hold the reset button down for 5 seconds
Jul 01, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony cd car radio
if you got the radio password or radio code..try to reconnect the battery of your car..turn on your radio,then enter the radio code you hav...:)
Oct 30, 2007 | Sony CDX-M610 CD Player
Kenwood KDC-MP528 CD Player Logo
133 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
