Question about Sony KDSR50XBR1 50" Projection HDTV
Sony SXRD Projection TV
Was working just fine last night but today turns on for 2 sec then PowerStandby light flashes 4 times. Was working just fine last night but today turns on for 2 sec then PowerStandby light flashes 4 times.
  • FUNSEEQUER Nov 26, 2008
    I removed the large and small fans and I forgot which way the fans go back in label out or in.
    Please help Thanks
  • 23 Answers
This is a fan issue, most likely the large fan in the rear, lower left (from the back)...
Here's the fix, I promise, it's EASY........
Ok, I think I have the answer for the BIG FAN failure. I recently did a similar fix on the spindle of an xbox 360 and it is identicle. Ok, this is an EXTREMELY EASY FIX...
Open the back of the tv, locate the large fan (on the lower left on the back of the set.) unscrew the screen and remove the fan.
Once the fan is removed, you will see the side with the model number and the other side is totally open.
On the open side, pull...
The fan will come off, into your hand, it is only held by magnets...
You will notice a spindle on the fan and the other side has the magnets and the hole where the spindle came from (this is the fan motor).
Clean both the spindle and the hole (motor) with a q-tip. The hole is smaller than the q-tip, but do the best you can to remove the old lubricant.
Get a bit of WD40 and lubricate the spindle and spray a touch in the hole.
Put them together, reconnect your fan, test it on startup and thank me...lol...
HOPE THIS HELPS!!!! IT WORKS, TRUST ME...
Posted on Oct 01, 2008
Just replaced lamp/housing and now tv turns off after 2 minutes of being on. Green light flashes continually(about 30 sec.) then tv turns back on and the cycle continues. The tv is a sony bravia...
Strange situation, have you tried unplugging it for a few minutes and letting the TV cool. I have a older 2006 Sony SXRD rear projection and it takes forever to turn back on if you shut it off then turn it back on. Check this link and maybe its giving you a blinking code. Try counting the number of blinks. Hope this helps.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Jun 17, 2011 | Sony KDF-50E3000 Television
My sony sxrd 60 comes on only for a sec than go off and red stanby lamp blinks 4 times,i have cleanned vents and checked bulb door,can only turn tv off and back on ,and still onlly get screen to show...
4 times red light blinking indicates problem with exhaust fan that is not running and tv shuts down instantly due to protection mode activation.
Please check exhaust fan and make sure its connector is plugged in and fan runs freely.
Thanks.
Apr 19, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Sony, SXRD Projection TVKDS-55A2000 Was working fine, then picture vanished. We have red blinking light on front, indicating lamp. I presume that lamp need to be replaced, but TV has only been operating...
Same thing happened on mine, you need to replace the bulb, on our TV I have 2 kids so the TV was always on but lasted 2 and a half years which impressed the warranty people. From what I have heard the average life is about 2 years. I have the same SXRD TV.
Aug 10, 2009 | Sony XL5300 Replacement Lamp for XBR2 SXRD...
Sxrd rear projection standby light blinking 4 times. I unplugged tv and when I turn it back on,it comes on for about 5 sec then goes off and red light blinks 4 times. Changed bulb about 2 months ago. And...
check the bulb door and make sure its closed all the way. be sure the bulb is firmly pushed into its socket. if the problem is still there you may need to repair the power supply board.
Jun 17, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Ok, I think I have the answer for the BIG FAN failure. I recently did a similar fix on the spindle of an xbox 360 and it is identical. Ok, this is an EXTREMELY EASY FIX...
Aug 28, 2008 | Sony KDS-R50XBR1 50" HDTV
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Video
How many times does the light flash?
Sep 28, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have the 50" SXRD TV and have expereienced many of the same problems as other owners. Sony replaced the optical block at no charge after the screen yellowing effect took place. Recently, I have the TV shut down with the flashing red light blinking in sequences of 4. After unplugging the TV for a few minutes, replugging it, and turning it back on, it worked again. However, this was not a pemanent solution as the problem returned. After reading several posts here, I turned the TV to look into the fans and voila, the one on the left was not spinning.
I took the back off of the TV (9 screws) and took apart the fan housing to vacuum everything. In addition, I vacummed everything else I could see. After putting it back together, the problem was solved. Save yourself a repair call. Get out a phillips screwdriver and a vacuum cleaner. Thanks to the posters on this site!!
Sep 12, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
218 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
