Question about Logitech Z-5500 Computer Speakers
Sub-woofer malfunction My problem is the diaphragm of sub-woofer is acting erratically. Sometimes it functions and some times not. A bit of **** is required to make the woofer functional. I checked the wiring inside and they are fine. Do I have to get a replacement speaker or it can be repaired??
  • 167 Answers
If the amp is going bad repair or replace, the sub you would probably have to replace, this would be the best fix. but check the amp also.good-luck!
Posted on Aug 02, 2008
Cutting on and off
the short tracking in the connections occurs normally after a long period of use.get it repaired if you want.or i will suggest you to get new sub woofers as the old one is at the end of its life.
pls do rate the solution
thanks.
regards.
fixya expert team
Sep 03, 2008 | JBL Northridge E 250P Subwoofer
Why does my woofer go off then back on again when I touch it?
A woofer consist of 4 parts, the diaphragm, the gasket ,the coil and the magnet. So when u touch the diaphragm it goes back on after no sound?....assuming this is what happens, there are 2 wires running from the coil to the diaphragm it could either be broken or worst case the coil itself has a broken or burnt coil wire. Recoil the coil if that is the case, idk from where u are but in RSA we get recoiled replacement kits for these situations
Jun 14, 2014 | Infinity PS-12 Subwoofer
2007 Mahindra Scorpio has an erratic rev counter and battery light
check the condition and tension of the drive belt. Check that the battery terminals and posts are shiny clean and tight. Have the battery load tested for faulty cells. Have the alternator tested for output
Apr 04, 2014 | 2007 Mahindra Scorpio 2.6TD
My mission Mv-as subwoofer has an intermittant problem - it works for a short time and then the unit fails to function. there is not a problem with the power and the speaker unit is not damaged. is this...
Yes , the possible fault can be a suspected fault in the sub woofer power amplifier. You will need to remove to check the circuit.
It can be a faulty or dry soldering in the main board., re solder IC.
Also if the IC is faulty it can be erratic, a signal test must prove it right applied to the input.
Oct 27, 2010 | Audio Players & Recorders
I have problems with the turbo of my Passat 2002 TDI Sometimes it stops working other times it works perfectly. What factors affect the turbo performance. Is the oil type, or coolant a factor?
The wastegate controls the operation of the turbo, it directs exhaust pressure to the turbo, If it does not function properly the turbo will act erratically
Oct 01, 2010 | 2002 Volkswagen Passat
Sub woofer
You are suppose to hook subs up to a amp.
May 04, 2010 | Car Audio & Video
My speakers only work one at a time...
Check you have plugged them into the correct socket on the back of the PC ..
Chances are you have 3 sockets - first = 'front' (or pair), middle = 'back' (for 4+ speaker sets) and last = 'center & sub-woofer' ..
Sounds like you have plugged into the 'center & sub-woofer' socket :-)
Mar 13, 2009 | Dell A215 Computer Speakers
Sub-woofer Malfunction
sub can be detecting signal from your amp. maybe your amp has some small output when in standby mode. some amps throughput signal from satellite boxes when they are supposed to be off.
try shutting off that signal source as well.
good luck
mark
Dec 28, 2007 | Sony SA-FT1H TV Speakers
Logitech Z-5500 Computer Speakers Logo
216 people viewed this question
Top Logitech Audio Players & Recorders Experts
sonic boom...
sonic boom...
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
