I bought a new 2GB sd card and a 1GB sd card and my player won't read either one. Format problem? How do I change the format?
Reformatting the 1gb or the 2gb disk is a snap, but that won't fix your problem, here's how to reformat then I'll discuss the way to make a 1 or 2 GB work, first with the disk and also the reader that came with the Harley MP3 player just plug it into the usb port on your computer, then click start on the computer, then my computer, now you will see Icons for the A,D,E and F drive, the F drive being your storage device ( sound disk ) right click on this and when the drop down window appears you will see either fat or fat32, most likely it's already set to fat32, if not then change it to fat32, now just click on format, a drop down will tell you that all info on the disk will be lost, click O.K. and it will reformat the card.Now to get your Harley HA90 Road Tech MP3 player to read the card, the player will not read a card that has the soundtracks in a folder so you have to open the folder, I have explained the how to in another post on this site, so to save space try to find it, if you cannot then make a post to let me know
I have the same problem and reformatting with fat32 does not work
Reformat with windows using fat32
I can't rate you when I don't know what fat32 is or how to get it, but I do appreciate you telling me what I need. now if I knew how to get it and what to do with it I may be able to rate you. Thanks, streetglide
I have the same problem and reformating to the fat32 does not work !
