My laptop battery has stopped charging up. Do I need a new battery or id there something else i can do ?
  • 796 Answers
Just try power drain once..
remove the battery,,press the power button..you will see the light turning on for few seconds....and then again put the battery and connect the charger and turn it on...if it is fine no problem..
even still you find hard to get long back-up
you need to replace them
Posted on Jul 12, 2008
Battery dies
Hello there.
With age (could be only a year old) ; laptop batteries stop 'holding' their charge and will drain very quickly. I am afraid the only sure answer is to buy a new one or similar one that will fit your laptop, and FOLLOW the INITIAL CHARGE instructions that should come with it. If it is not done properly, the battery will not have a long life.
Aug 23, 2014 | Battery Biz Computers & Internet
My N5010 dell laptop battery won't charge anymore. Could I just need a new battery, or charger, or could there be something else going on internally that I need to know about? For the most part, I
If your laptop is still under warranty, contact dell and they should be able to fix it free of charge, The same thing happened to my laptop a few years ago and fortunately, it is still under warranty, The fault is the charger itself which dell replaced free of charge.
Jun 26, 2012 | Dell Inspiron N5010 Laptop Core I5...
I bought a brand new 170.00 battery for my Dell studio 1737 laptop. It continues to say plugged in, not charging. What can i do? I've tried plugging in and replugging in the charger.
For a new battery, we advise that you update the BIOS of your laptop, and open the hardware automatic identification port of your laptop.
When you use it firstly, you need to discharge till 5%, then charge it about 11 hours. Usually, new battery need to fully discharge and charge for three or four times, which can achieve the best performance.
About the new battery, please set the power management of your laptop: Property -> Screen Saver -> power -> Power scheme -> Portable / Laptop -> please cancel about low battery alarm and serious shortage of battery alarm when use the battery.
For some laptops, you could try to close your power management tool to test your new battery.
You could try to take out the battery from your laptop, and put it back again, repeat several times. Make sure that it isn't a poor contact problem between the battery and your laptop.
If the battery works in higher temperature, the battery protection plate will work and the laptop restart program will make a termination order. You can take out the battery, put it back again, and avoid work in high temperature.
In order to avoid some damage to the battery, please note:
Please don't take out the battery when the laptop is in run status.
Please don't pull out the ac adapter frequently when the battery is charging.
Please use high quality and reliable laptop charger, not to use the universal laptop charger.
Are there something wrong with the new battery can not charging?
That's not usually the case. When equipment for the first time to recharge the battery, the instability of the voltage and current may cause the battery charge to 50% (sometimes more, sometimes less), and equipment stop charging the battery.
If this happens,don't worry. You just remove the battey from the equipment, recharge again. First charging a new battery may need several repeated process. Please be assured that this is normal.
Or you can visit http://www.batteriescenter.com.au/.
Jun 19, 2011 | Dell Studio 1737 (Studio 1737-RubyR) PC...
Computer does not recoginze the ac power supply and will not charge the battery
Dell laptops are notorious for wanting the exact model of charger they are designed for. Simply, they will not run on a non-genuine Dell chargers as far as charging is concerned.
IF you are already using a genuine Dell charger, for that models amperage and voltage, there is an issue with the charging circuit on the motherboard
Jan 12, 2011 | Dell Studio 1737 Laptop
My battery has stopped charging. Do I need to get a new battery or is there something I should check first?
FIRST U NEED TO CHECK UR POWER ADAPTER BY REMOVING THE BATTERY, IF IT WORK'S THEN U SHOULD CHANGE UR BATTERY
Dec 15, 2010 | Acer Aspire One PC Notebook
My Dell precision m90 stopped working. It won't turn on. It sounds like it wants to but then stops. It was saying that the battery needed to b replaced 4 like a month. Do I need 2by a new battery? Or...
The computer runs off the battery, if it will not hold a charge or take a charge, there will be no power to run the computer. Rechargeable batterys will get to a point of no power at all and will not except a charge of anykind.
Oct 29, 2010 | Dell Precision M90 Notebook
When I plug in the adapter the blue light on the charger goes out immediately and does not charge the battery. I bought a new charger and it does the same thing. I've had both chargers checked and they are...
I got a brand new 170 battery for my studio 1737 . Now the battery has charged, but I plug it in and the window says battery plugged in, but not charging
May 14, 2010 | Dell Studio 1737 Laptop
Why does my battery stop charging at 35%?
The battery pack will need to be replaced. It has reached it's full life expectency
Jul 11, 2009 | Computers & Internet
Battery is not charging
it is not your battery that is the problem but the charger so you will need to go somewere like officemax and buy a universal charger and if you still have problems then call HP tech support there friendly people
Jun 23, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
David Payne
David Payne
