Vcr tuning the vcr and the tv are working perfectly but no video pictire appears on the screen.....it continues to show the tv broadcast.
    New Friend:
  • 23 Answers
If you are using AV leads, switch the TV to the AV channel.If you are using a coax lead, choose channel 0, put a tape in the player, and tune the Tv (probably on the UHF channel) until the movie appears.
Posted on Jul 13, 2008
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
UE40H6240AK UE40H6240AKXXU Support SAMSUNG UK
Sep 09, 2014 | Samsung 40" 1080p 3D Slim LED Smart TV...
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Vcr tape doesn't show on screen when playing
If the picture from the DVD shows on the screen, but the pictire from the VCR does not, it is most likely because you are using sockets on the back of the player that are exclusively for the output from the DVD.
Please review your connections in relation to the diagram below. If the cables from the player to the TV are only in the red box, you will not get any picture from the VCR. You will need to move the connections to the sockets in the green box or add a separate connection for the VCR using the sockets in the green box. Whether or not this is possible depends on what input sockets are available on your TV.
You will notice the heading above the red box says "DVD". This means the connections in this section can only be used for DVD. The heading above the green box says "DVD/VCR" meaning the connections here can be used for both.
There are a fews ways to set this up. To get the best picture quality from DVD, you should continue using any connections you may have in the red box and add another cable from the green box to the TV for the VCR. You will also need to select different INPUTS on the TV depending on whether you want to watch DVD or VCR if you are using 2 cables.
I suspect this will be the cause of your problem. If you need any further explanation or assistance, please reply to me by clicking on "Add a Comment" below your question. If you would like me to draw a connection diagram between the DVD/VCR and your TV, please let me know the brand and model number of your TV.
Hope this helps.
Regards,
BElectric
Feb 26, 2011 | Emerson EWR20V4 DVD Recorder/VCR
Setup VCR to TV, using RF plugs & coaxial cable
The solution was both simple and elementary - why didn't I remember it sooner?
The TV needed to be 'tuned' to the video just as it needed to be tuned for each TV channel.
I selected channel 12 on the TV, went into the tuning mode on the TV and with the video playing, cycled through the TV tuning process until, Voila, there was the video showing on the TV.
Oct 14, 2009 | Philips Televison & Video
Connect vcr to jvc c2033us tv
You will need to put your aerial into the rear uhf socket of the VCR then take another connecting lead (flylead) from the out of the VCR & put this into the aerial socket of the TV. You will now need to select a channel on the TV (best to use channel zero) & tune the TV to the VCR signal. The best way to do this is to put in a recorded tape eg a film /press play/ then tune the TV until you pick up the playback of the film, then store this on the TV. This will give you your VCR channel. You will now need to tune the VCR to your broadcasted stations so that you can record.
Apr 01, 2009 | JVC Televison & Video
Got no instructions
1-The TV needs to be on channel 3.
2-On VCR remote set VHS/TV switch to VHS. (click it a couple of times until VCR channel shows on screen)
Dec 25, 2008 | Televison & Video
Black box covers most of screen some channels, plus gibberish.
it is the closed captions on the tv. it is set to closed caption text. turn it off
Nov 24, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Problems tuning TV and SLV-900
the video recorder has it's own tuner you do not actually record from the tv... think of the vcr as like a tv but without a screen... connect to your tv via a scart lead and while you are on the vcr's 'channel' (so you could see a tape playing on your tv) and access the menu on you vcr (not the tv's menu) choos auto tune if the vcr supports it or manual tune if it has no auto tune and tune in the required channels on your vcr... it is simply then a matter of selecting on your vcr which channel you wish to record
Oct 13, 2008 | Sony SLV-D900 DVD Player / VCR Combo
Issues with my goldstar
Goldstar dvd/vcr combo was stuck in progressive scan. I used the posted solution and now it is out of progressive scan but it continuously reads the dvd and I cannot get the dvd to play. "Reading" conitues to appear on the screen. Any suggestions?
Thanks!
Patsy
Dec 29, 2007 | Goldstar GBV241 DVD Player/VCR
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
