Question about Acer Computers & Internet
Acer 5100 problem: windows failed to start because a requiried file is missing, or corrupt file:acpi.sys status:0xc0000098 do not have windows installation disc
  • 796 Answers
I am sorry to tell your windows booting files or dlls are missing...only way to solve this is by repairing or installing a new version of windows.
if you dont have one..you could request for one from the microsoft website or download from online..they will be available if you google it
Posted on Jul 12, 2008
Windows failed coz of critical system driver is missing or corrupt.. volsnap.sys status 0xc0000098
That can be frustrating :( hope my solution below helps..
based on the current situation, I suggest trying the following steps: restart the computer and keep pressing F8; Use Last Known Good Configuration.
If the issue still occurs after that, I suggest testing if we can boot from a Windows disk. If so, please install Windows on another partition and access your important data. After backing up those data, you can use Windows disk to format the drive and reinstall Windows.
However, if we cannot boot from a Windows disk, the issue can be caused by incorrect BIOS settings or damaged hardware. I recommend contacting your computer manufacturer to check BIOS and hardware.
May 26, 2011 | Computers & Internet
File: \Windows\system32\drivers\wdf01000.sys status: 0xc0000098 info
Boot up from the DVD drive with a windows bootup DVD, or boot up in recovery console, Ok, rename the file Wdf01000.sys to Wdf01000.old and copy new file from the Vista CD back to local drivers folder. then you will be back in business.
May 19, 2010 | Acer Aspire 3680 Laptop
Where can I get a recovery CD for my laptop?
Sounds like a disk error. I would run HDD to check.
Mar 14, 2010 | Lenovo 3000 V100 Notebook
Help on reformating pc!!!
Use different CD installer or burn your present WindowsXP to another disc. Your files might have been corrupted due to poor disk surface of your Windows Installer.
Jan 21, 2010 | Acer Aspire T310 PC Desktop
My acer 5100 laptop will not boot up. I get
you could try going to the boot menu, and choosing 'last known good', but that is probably not going to work.
you should be able to run a repair off the CD....
the file is a kernel, a neccessary file used by Windows. It may have gotten corrupted or deleted.. possibly by a virus or bad hard drive sector.
get a disc, and run repair, if that doesn't fix it, you may need to re-install a fresh copy of windows, which will over-write all your data. you may be able to boot to that upgrade CD and that may have a repair option...
good luck.
Sep 11, 2009 | Acer Aspire 5100 Notebook
Windows boot manager problem acer aspire 5920
Creating recovery discs After setting up the computer for the first time, be sure to create a set of recovery discs of the full factory image. the recovery discs are used to start up (boot) the computer and recover the operating system and software to factory settings in case of system instability or failure.
Jun 16, 2009 | Acer Aspire 5920-6727 Notebook
Will not boot
Try booting into Safe-Mode and check if it happens again. If it doesn't go to Device Manager and remove any device with an exclamation mark. Also, try reinstalling the mouse driver.
If it doesn't work, backup your things and format the drive.
May 26, 2009 | Acer Aspire 3680 Laptop
Dell vostro 1700 NETIO.SYS 0xc0000098
This is probably a problem with either the media (bad disk, or picky optical drive) or with some hardware. In the first case, I would try to reinstall first, and if that fails consider using a different drive or disk (if possible). As it points to the Netio.sys file, in the second scenario it may be related to a network device (i.e., ethernet). My suggestion in that case would be to remove all devices possible from the computer, and to disable on-board LAN/audio in BIOS to see if that helps.
Apr 15, 2009 | Dell Vostro 1700 Notebook
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
Computers & Internet Logo
114 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
