My Panosic PT-61LCX65 is having a problem turning on. It was running fine and then my wife said it just.. stopped. She wasnt paying attention to it so not sure if it made a noise. Upon trying to turn it back on, the power LED blinks green (for powering on) as normal, but then I hear a clicking sound, very close together in timing, and it stops clicking.. and then comes back after about 3-8 seconds or so and will continue to do this until I press the power button again to turn it off, or unplug the TV.
I do not think the lamp is coming on because the screen remains the same shade of "black" as when it is turned off. I took off the bottom back panel where you can view the circuit boards and such, but it doesnt look like anything is blown. It is coming from the left side of the TV if you are looking at the front, right side if you are looking at the back. I think it is coming from this silver box (voltage supply?). Any ideas?
It just happens so, i have the same problem. Did you find out what was wrong, because exactly same thing happens as you have described. Same clicking noise every 8-10 seconds and no picture. Thanx!
Check your bulb. I had the same problem and it turned out that the bulb was shattered. At no time, did the lamp light turn on.
