I have an e-machine, my hard drive was corrupted, thus I just replaced the same, I have to re-install all the software from the recovery disc. I have installed th hard drive, when I press the power button the computer dose start, in order to install the software, I have to install it thru DVD / CD drive. The DVD / CD would not work. I did chage the cable, I did open the DVD drive manually, but the same will not work. Let me know what should I do, in order to reinstall, I have to make sure the DVD/CD drive works.
    President:
  • 1,314 Answers
1. Make sure the two cables are installed in the back of the optical drive.
2. When you start your computer, press the key that it tells you to go into system setup or BIOS. From there, you need to find the boot device and/or boot order option and select the optical drive as the first boot device.
3. Press F10 to save and exit, making sure the first recovery disc is in the optical drive.
4. Save and exit; your computer should boot now from the optical drive.
Posted on Jul 12, 2008
Where is the reset button
If you mean how do you return to factory condition, press F11 just before it boots and follow the prompts.
Recovering your computer without recovery discs
Creating recovery discs (or USB storage device solution)
Ordering recovery discs from HP in the United States and Canada
Finding recovery discs from other Web sites
Contacting Support
HP recovery discs can be used to return a computer's software configuration to its original condition. HP provides a recovery solution on the hard drive, but it is still a good idea to keep recovery discs stored in a safe place in the event of a hard drive failure. Use the sections in this document to obtain a recovery solution that works best for you.
NOTE:HP computers designed for commercial use, such as Workstations or Pro series, use "Operating System" or "HP Restore Plus" DVDs. To order these types of discs, go to the HP Replacement Part Store . Recovering your computer without recovery discs You may not need recovery discs to recover the software on your computer. HP provides a recovery solution on a separate area of the hard drive. If the hard drive is still functional, you can still perform an HP system recovery from the hard drive as long as the recovery information has not been destroyed or corrupted.
To do a software recovery from the hard drive, turn on the computer and repeatedly press the F11 key until "Windows is loading files..." displays on the screen. If your computer originally came with Windows XP or earlier, press F10 to enter recovery instead of F11.
  • graphic.php?im=im_e58rok73o1nlhbzFeedback
  • Dec 21, 2013 | HP Pavilion dv6000z Notebook
    Loss my recovery softwear for hp pavilion dm 1
    This is from the HP site:
    HP recovery discs can be used to return a computer's software configuration to its original condition. HP provides a recovery solution on the hard drive, but it is still a good idea to keep recovery discs stored in a safe place in the event of a hard drive failure. Use the sections in this document to obtain a recovery solution that works best for you.note.pngNOTE:HP computers designed for commercial use, such as Workstations or Pro series, use "Operating System" or "HP Restore Plus" DVDs. To order these types of discs, go to the HP Replacement Part Store . Recovering your computer without recovery discsYou may not need recovery discs to recover the software on your computer. HP provides a recovery solution on a separate area of the hard drive. If the hard drive is still functional, you can still perform an HP system recovery from the hard drive as long as the recovery information has not been destroyed or corrupted.To do a software recovery from the hard drive, turn on the computer and repeatedly press the F11 key until "Windows is loading files..." displays on the screen. If your computer originally came with Windows XP or earlier, press F10 to enter recovery instead of F11.
    If you are simply trying to restore the computer to factory install, you may not need the recovery discs.
    If you have suffered a hard drive failure, then there are a couple of options on their website, just ensure you have the exact model number of the computer.
    Feb 12, 2013 | Computers & Internet
    I cant open or format my hard disc
    Try this method
    Uninstall the hard disk
    Connect it to the other system/laptop as external drive
    Install data recovery software on system/laptop
    Scan the external drive for recovery options available
    Save the data you want to recover
    You can download a good data recovery software from http://www.windowsdatarecovery.com/
    Aug 16, 2011 | Computers & Internet
    Hi mate i have a wd passport hd, and i took it out when my computer wa restarting. and now my computer and any other computer dont read it it say reformat. it has very importent files on how can i retrive...
    Here is a 10 day free trial of a software recovery program that can be burned to a disk. You would then boot from that disk with your external drive plugged in, and after it loads the software, tell it to find all available files. When you find your files, copy them to your regular hard drive and reformat the external. Copy the files back to your external drive. Hope that helps some.
    http://www.ntfs.com/products.htm
    May 03, 2011 | Western Digital Passport 320GB External...
    Toshiba U400 - when switched on the toshiba logo will appear and followed by a black screen. kindly help me with this problem. I tried F8 but F11 and pressing to reboot but nothing happens.
    This probably means it can't boot off the hard disk or the CD ROM.
    Make sure there's no CD in the drive.
    Try holding F1 as you turn on the unit to see if you can get into the setup if it still won't boot with no CD.
    Feb 28, 2011 | Toshiba Computers & Internet
    I have a error message when I start start my acer aspire 4710 machine. It's stated that "windows failed to start. A recent hardware or software change might be the cause. To fix the problem: 1.insert your...
    Oh Boy...
    It seems that your computer has corrupted some very important files and thus, just doesn't want to play.
    There also lies the possibility that your hard drive is about to completely fail and that the damage (physical damage on the actual Hard drive internally) is what is corrupting/corrupted your data to a point that it may not fix itself.
    If you have access to another computer, take your hard drive out of your Acer and have your geek guru attach it to his/her system as a secondary drive. This will allow you to do 2 things, test if the drive is still good and if not you have the oportunity to get your important data off before catastrophic failure occurs.
    In either case, you may find yourself having to do a complete system re-install, so best to get you files off before anything else anyway.
    At least that's my recommendation from the information that you gave. Hope this helped...
    Oct 12, 2010 | Computers & Internet
    Hard Drive recovery
    Have you tried some data recovery software? You can use the Google search tool in this regard. .My Mac Book Pro hard drive has crashed and I'm in the process of replacing it. However, I had a lot of important data on that hard drive that he needs recovered. Then I found this data recovery software that recovers data from corrupt/bad hard drives. And fully supported for NTFS/FAT32 mac files. Mac Hard Drive File Recovery Recover Files from Formatted Mac Hard Drive
    Dec 08, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
    Pc restarted
    Irrespective of being a PC or a Mac the computer system behavior and consistency are dependent upon certain factors. These factors are broadly divided into software factors, hardware factors and the surroundings.
    The common software factors leading to a logical failure are:
    i.) System files responsible for handling control to the operating system missing or corrupt
    ii.) Unsigned drivers or drivers trying to access read only system area
    iii.) Operating system files corruption due to incomplete automatic update, malicious software
    The common hardware factors leading to a physical failure are:
    i.) Problems related to mainboard in terms of the chipset or connector, power supply issue like incompetent power supply to run the hardware setup
    ii.) Problems related to hard drive itself or the data or power cables
    iii.) Improper setup of hard drive cooler fans (if any)
    The common surrounding factors leading to data loss are:
    i.) Heat dissipation issues related to closed or poorly ventilated surroundings like in a basement or store
    ii.) Moist surroundings leading to the formation of thick dust layers and thus increasing heat
    iii.) Direct sunlight leading to extra heat and thus hardware failure
    We should logically negate these scenarios so that we can narrow down to the root cause of the problem and take corrective measures.
    In case we find that the data loss is due to any logical failure, we can use data recovery software as they are programmed to meet the challenges due to all kind of logical crashes. They scan through the file system, locate all the files which are marked as deleted and are distributed as fragments across the partition, logically rearrange them as per the file system information and then recover them. The data recovery software are indispensable in cases like file system corruption, hard drive formatting operating
    system corruption, accidental file deletion or malicious software like virus, spyware etc. We can perform a ‘Do It Yourself’ data recovery using these utilities as they are self descriptive and User friendly.
    We need to install the data recovery software on another hard drive which is bootable. We can also use a different working system preferably using the same operating system platform as for MS Windows. Then, we can attach our hard drive to the same for scanning. For attaching the hard drive we nowadays use USB 2.0 Hi Speed or IEEE 1394/Firewire Cables, Attachments or Enclosures. The same can be achieved by a Master and Slave setup that requires hard drive jumper operations and thus is a little complex. We should avoid any other jumper operations as of the mainboard as they may lead to unstable system behavior based on BIOS settings.
    We should always save the recovered data on a healthy hard drive.
    In case of data loss due to hardware failure where the hard drive is either not getting powered or can not be recognized by the BIOS, we need to go for hard drive recovery service. The data recovery service is personalized help, delivered by data recovery experts. Such experts can extract your data in all possible scenarios of physical data loss.
    Apr 03, 2009 | Intel D101GGC Motherboard
    Data recovery from corrupt external hard drive
    Well, in your case you should format the external drive and then try some so-called data recovery software.
    First of ALL - Connect your hard drive to your personal computer. And install this software Wondershare Data Recovery on the computer in order to perform data recovery. Get the program from its site.
    data recovery (for Windows OS)
    Mac data recovery (for Mac OS X)
    Good luck. I hope that my reply has shed some light on the problem!
    Dec 07, 2007 | Computers & Internet
    Compaq Presario V200 wont boot up
    Unmountable boot volume means that the computer can't read the hard drive. Which means that either the data on thehard drive is corrupt, or that the hard drive is dead (gone bad).
    If you have important data on your computer, there is some disc recovery/maintenance software called SpinRite http://www.grc.com/spinrite.htm It is $89.99 but is really good at recovering data for when the hard drive isn't completely dead.
    If the hard drive is still good, but only the data is corrupt, and you don't care about it too much, you can just use the restore discs that came with your computer to re-install the OS (Windows).
    Your other option is to buy a new hard drive for your laptop and re-install Windows.
    Nov 15, 2007 | Toshiba Satellite A45-S250 Notebook
    Computers & Internet Logo
    David Payne
    David Payne
