Question about Refrigerators
My freezer will not get cold. The compressor runs, but the temp never goes down in the freezer. There do not appear to be any breaks in the coolant lines, and the unit is only about 3 years old.
The solution to this was actually to replace the compressor, which I thought would be the case. Basically, it was running, but not doing anything except using electricity, so we replaced it.
By the way, the unit is a Bosch fridge-freezer (freezer on the bottom), model begins KX00, but I don't recall the rest.
Posted on Jul 14, 2008
Fridge and freezer at 50 degrees with settings on max cold. I can hear compressor cycling and all power is on. Suggestions?
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
Nov 23, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jcd 2389GT frig side by side does NOT appear to be getting cold. What could be wrong? Thermostat? Compressor? How can I test it? Fan for freezer is running but also appears to be generating cold air. Can...
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM). Heavy frost indicates defrost problem.
Dec 01, 2009 | Refrigerators
Refrigerator not cold/Freezer cold.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
1991 Kenmore 16 model 253 in storage for 7 years. Plugged it in and turned it nn last night and seemd to run fine, nice and quiet just like before. Today it is not cold and the comressor seems to be r
If the freezer was stored and not running for 7 years it may have lost coolant.  Since the compressor is running recharging the coolant may fix the problem.  Hot compressor might indicate low coolant since its motor is immersed in it.
May 30, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Freezer not freezing, refrigerator side not cold enough
sounds like compressor might not be running. pull unit out and remove bottom panel to access compressor area. beware of electrical wiring!!!! touch compressor to see if it warm. make sure fan motor by compressor is running.
May 07, 2017 | GE Refrigerators
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Freezer freezes but does ever stop running
thermostat is stuck on! set to medium setting and gently tap stat. does it turn off? it was stuck. does it still run? its still stuck. if you feel comfortable find stat and power in and out. disconnect - it has to turn off then. but 99 % of the time its the stat. they fail closed and run 24 -7 or fail open and temps get real hot and they never close and restart compressor . yours appears to have failed closed. sometimes you can firmly twist em max cold to min cold a few times and break the stuck contacts and they'll do ok for a while. try to reset at a little higher or warmer temp when done so its not making and breaking on the same old worn spot again. good luck.
Nov 20, 2008 | Haier Freezers
Our amana fridge model # BH2055W, with a botom freezer will not maintain the temperature.A repairman put in more fluid, but that did not solve the problem. It will not get cold enough and does not...
CHECK THE FREEZER TEMP FOR ZERO DEGREES. PUT A THERMOMETER IN THE FREEZER THAT WILL MEASURE DOWN TO ZERO DEGREES. LET IT SET OVER NIGHT BEFORE CHECKING. IF THE TEMP IN THE FREEZER IS ZERO OR LOWER, THE SEALED SYSTEM IS O.K. IT IS AN AIR FLOW PROBLEM. ON SOME MODELS, THE AIR TO THE FRESH FOOD COMPARTMENT IS CONTROLLED BY AN ELECTRIC, MOTORIZED AIR DAMPER. IT COULD BE DEFECTIVE, STAYING CLOSED WHEN THE CONTROL CALLS FOR MORE COLD AIR. IF YOUR REFRIGERATOR HAS A DIGITAL CONTROL, THERE IS A SENSOR IN EACH COMPARTMENT TO TELL THE ELECTRONIC CONTROL WHAT THE TEMP IS. THE SENSOR (THERMISTOR) COULD BE BREAKING DOWN, GIVING A FALSE READING. THIS WOULD ACCOUNT FOR THE TEMP VARIATIONS.
IF THE FREEZER IS ALSO WARM, THERE COULD BE A RESTRICTION IN THE SEALED SYSTEM. THERE COULD ALSO BE A PROBLEM WITH THE RELAY ON THE COMPRESSOR, NOT ALLOWING THE COMPRESSOR TO START UP WHEN IT IS NEEDED.
BE SURE THE CONDENSER FAN MOTOR IS RUNNING WITH THE COMPRESSOR AND THE CONDENSER COILS ARE NOT PLUGGED WITH DUST, DIRT OR FOREIGN OBJECTS.
Apr 08, 2008 | Refrigerators
Jenn Aire side by side - freezer and fridge not working
Yes the compressor could be stuck but it's also possible the PTC could have failed - each will show the same symptoms. If you're a tech you can check the compressor or you can just replace the PTC also known as "relay". Part # 12002784 should run somewhere around $60.
Dec 30, 2007 | Jenn-Air JCD2389G Side by Side...
Refrigerator in garage
Yes it is very possible that exactly what you are describing can be happening. Also try a thermometer frozen in a cup of water to get more accurate temps. Also 33 in the fridge is very normal for the cold control set on max and the heater installed. Let me know the temps in the frz with the thermometer sensing product temp not air temp which fluctuates often.
Dec 22, 2007 | Frigidaire FRT21P5A Top Freezer...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
