Question about Maytag MAV2755A Top Load Washer
Maytag Washer leaking from front
Problem Leaking water in front of washer.
Took front panel off, and found water leaking from a bolt in front of drum of washer. It appears stripped and I can not tighten it. How do you get to the inside of the drum to get to the head of the bolt to replace.
Thank you.
  • 234 Answers
If I remember correctly, you need to remove the drum to get at the bolt that you are talking about. There is a rubber washer that provides the seal. The locking collar on the hub is Left hand thread. If you work at it you can get it loose.
Posted on Apr 27, 2009
Cold water leaks into tub when machine is off
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the WATER INLET valve
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace inlet water valve
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace pump .
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. 9696d86e-1b8b-4b2e-af2c-6f3a3ae921dc.jpg
May 23, 2013 | Siemens WK61420GB Front Load Washer /...
Maytag washer leaking water into tub when idle
A intake water valve is leaking and will need replacing.
Dec 30, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Samsung Front Loader wf306law took off back panel as we had lots of water under neath ran washer rinse/spin soon as the cold water came in there was water all over the inside any idea why? the washer is...
I found MayTag has a full report on this washer.$FILE/Samsung_Frontier_Washer.pdf
The part number is DC97-10417A and can be ordered at
Jun 11, 2010 | Samsung WF337AA Front Load Washer
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
Water leak from bottom of Maytag Neptune washer
The water pump is cracke,. replace the water pump. Peter
Mar 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
This machine has two removable front panels. At the bottom of the unit are two (2) 10mm bolts. Removing these bolts will give you access to the working parts since this is an inspection plate, The upper panel : There are two (2) 10mm bolts located at the bottom corners. Remove these bolts, pull the bottom of the panel toward you to release the top latches. This will give you full access to see where the water is coming from. I suspect a leaking pump but cannot rule out a bad tub seal.
Jan 08, 2008 | Maytag SAV515DE Top Load Washer
Maytag front load washer leaking water from detergent dispenser
The other end of the dispenser to outer drum hose only connects to the outer drum and if you remove the top cover of the machine, you will see it clearly. You can unclamp the hose from the bottom of the dispenser and feel inside the hose for any obstruction. Do not remove the hose from the outer drum. Pour some hot water down the hose and squeeze the hose from top to bottom to remove build up of detergent and softener on the inside walls of the hose.
Oct 28, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag MAV2755A Top Load Washer Logo
108 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
