Question about Vacuums
Hello, I have a Dyson DC17 that is not working properly. I emptied out the canister to find the tiny holes clogged on the cyclone part of the vacuum. How can I unclog those holes? Thanks!
I had this problem. Part of the clyclone is hard plastic and part is softer - where the holes are. Basically, I removed the rubber gasket at the bottom and kept beating on it - thumpig the hard plastic on a hard surface and then banging the softer sides against a rounded corner. Eventually, I got about a cup of dirt out of it. It now works well.
I presume that you have cleaned the filter, too. Slower air velocity won't help this problem.
Posted on May 16, 2009
The directions say that the bottom filter should be cleaned every six weeks or so. It becomes clogged each time we vacuum
Your seal on the bottom door that dumps the dirt is not properly seated. It is possible it got bumped when you emptied the dirt one time. Take it off the center tube in the dirt canister, clean everything and put it back on. It can be put on upside down so in the event you took it off once, it is possible you put it on upside down.
Mar 06, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Upright positon dyson won't work
Have you checked your permanent filter? Have you checked the hoses for clogs. As a last resort you can disassemble the cyclone and clean it. If the vac is less than 5 years old, Dyson will probably send you a new Cyclone to replace yours.
Also check that you have the gasket inside the center of the bottom of the clear canister on the right way. If it is backwards your suction will be much less
Jul 10, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuum works but doesn't pickup dirt
there is a clog. check the hose, and the entry to the canister, check the holes inside the canister and check / clean your filter. also remove any threads/ animal hair from the brush so i can freely grab the carpet :)
Mar 26, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hello- my motor filter is becoming clogged every time i use it. i have removed and washed it--I thought maybe i didn't have the lid closed tight enough but for some reason dirt is pouring into the filter,...
One way or another, dirty air is by-passing the cyclone. My best guess is that when you emptied the clear bin, a seal has dropped out (or become displaced) and the base of the clear bin is no longer sealing properly against the bottom of the cyclone. Check that all the seals are undamaged and in place. Also check that the bin base closes tight after you've emptied it.
If this doesn't help, please post a response and I'll try again. If it does help, please remember to rate me!
Jan 23, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
8 holes in root cyclone are clogged
There is no real solution other than to call Dyson provided still under warranty.
IMHO, DC17 Animal has a flawed design with the sealed canister (at least as purchased in December 2006 purpotedly has been corrected at this time).
The rubber gasket (where you close the bin at the bottom) is so delicate, that even the routine maintenance of emptying the bin can dislodge it (or even crimp it) so that debris (carpet lint, pet hair, etc) enters the cyclone itself eventually clogging it.
After going throught their recommended solution on their web site without fixing the problem, it was a typical customer service experience on calling. But with persistence in explaining their faulty design to them (particularly with regard to the fact that it's caused by routine maintenance), they'll break down and send you a new cylone unit at no charge - from there on out ensure that the thing is sealed after emptying or performing normal maintenance.
Although the original question is somewhat dated, hopefully this will save others some aggravation in dealing with the problem.
A grumpy old guy who simply insists that companies put service/care back into the customer service/care hotlines....
Aug 23, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson collecting debris/hair, ect on top of hepa filter?
Called Dyson today about the cyclone canister clogging in my DC17 Animal. Turns out it's a problem with the black rubber gasket in the bottom of the canister. This also causes the HEPA filter to get lots of dirt and debris on top of it. They are sending me a new Cyclone canister with the corrected gasket. This will prevent anything but small particles of dust from entering the top of the cyclone and the HEPA filter should no longer collect all that stuff. Hope so!
Feb 09, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal
I have the same problem with my Dyson dc17...there is dog x2 hair collecting in the 'cylinders' just underneath the purple cap on top of the cyclone/canister. And i can see twisted 'braids' of hair coming out of each pea-size hole. I called Dyson's Support number and after they asked a few questions about the round filter (tell them you clean it every month or so), the representative told me that you should not see anything collecting on top of your filter located at the base of the canister (mine was covered with dog hair, etc.). They told me that nothing larger than minute dust particles should be there...which eventually travel into the purple cap. They said the cyclone canister has since been redesigned to correct the faulty rubber seals, etc., and they are going to send me a whole new cyclone/canister within a week or so. so call Dyson directly before you try to get inside "the purple chamber"...I know I could not figure it out!
Oct 02, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal Vacuum
you just need to blow those holes out with a air compressor or similiar device and the filter can be washed in water and dried for 24 hours every once in a while, this is just how the vacuum works, nothing is perfect
Mar 02, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuums Logo
106 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
