Question about Bosch Nexxt WTMC 3300 Electric Dryer
Cricket stuck in glass section of dryer door series 500
A live cricket is stuck in our daughter's dryer. She removed the door and cannot find a way to remove it. Any suggestions?
    Champion:
  • 210 Answers
Call bosch.
Posted on Jul 12, 2008
Need to replace the foam strip that seals the front door on my Bosch 500 Nexxt series electric dryer....do I do this from the front?
Most likely yes. Get a good adhesive for it though and make sure it is dry before you close the door and before you use it.
Aug 12, 2013 | Bosch Nexxt 500 Dryer
My gas dryer Kenmore 500 series won't start when I push the start button. The light is on in the dryer chamber. The door latches and there is gas running in it.
the one side of the door switch is bad,one side controls the light when the door is open,the other side of this switch makes the unit run when the door is closed,replace the switch,or if you dont care about the door light,reverse the 2 larger connections and it will work again,but no light with door open then
Feb 11, 2011 | Kenmore 500 7953 Dryer
HOW TO REPLACE THE HEATING ELEMENT IN KENMORE 500 SERIES DRYER
UNPLUG UNIT remove screws securing back to unit element is in lower right section of duct hase 2 screws holding unit dissconnect wiring remove screws reverse order to reinstall
Aug 07, 2010 | Kenmore Dryers
Bosch Nexxt 500 series dryer, E:01 and lint light flashing. nothing is stuck in the door.
This indicates the sensor near the lint filter gets too hot. This is usually caused by bad air flow.
Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting.
You may need to have it cleaned out. May be lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, there may be heat escaping somewhere within the dryer. This is only resolved by technician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 26, 2010 | Bosch Nexxt 500 Dryer
My daughter's necklace is stuck in the drum of my bosch nexxt 500 washer
the drum may have to be removed and taken apart in order to get the necklace out.or the chain may have to be broken and the rest ran down to the drain pump for removal
May 18, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
How do you change the door switch kenmore 500 series dryer
Two metal clips hold the lid down, if the lint trap is on top there will be two screws under it.  Pop the clips with a long skinny flathead, lift the lid up and the door switch should be on top.
Dec 18, 2009 | Kenmore 500 6953 Dryer
Bosch 500 series dryer stuck on pause mode
things I would try:
remove the power from the dryer and let sit for a while. Plug back in when you feel it is time.
If that does not reset, I would take the cover of the board to see if the button is not stuck. (remove the top 1st, the the cover of the control board will come out)
Jun 05, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
2003 ford taurus drivers window will not go up.
you either need a motor or motor and window regulator assembly.
SECTION 501-05: Interior Trim and Ornamentation 2002 Taurus/Sable Workshop Manual
REMOVAL AND INSTALLATION Front Door Trim Panel Removal and Installation
  1. Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
  1. Remove the front door trim panel screws.
  1. NOTE: To release the door trim panel two part pin-type retainers, first pull outward on the bottom of the door trim panel.
    Remove the front door trim panel.
    • Disconnect the electrical connectors.
c64985a.gif --------------------------------------
SECTION 501-11: Glass, Frames and Mechanisms 2002 Taurus/Sable Workshop Manual
REMOVAL AND INSTALLATION Front Door Window Regulator And Motor
Special Tool(s) s2h~us~en~file=st1132a.gif~gen~ref.gif Heavy Duty Riveter
501-D011 (D80L-23200-A) or equivalent
  1. Remove the front door window glass. For additional information, refer to Front Door Window Glass in this section.
  1. Disconnect the front door window regulator motor electrical connector.
  1. Remove the window regulator rivets.
REMOVAL AND INSTALLATION Door Window Regulator Motor Removal and Installation
  1. Close the window.
  1. Remove the door trim panel. For additional information, refer to Section 501-05 .
  1. If equipped, remove the radio speaker.
  1. Position the watershield aside.
  1. Disconnect the door window regulator motor electrical connector.
  1. Remove the bolts and the door window regulator motor.
May 04, 2009 | Ford V6 Pony Cars & Trucks
Front right door window will not go up or down, it is electric. it works, some times, and some times not. it is in the down position. Would like to move to up position. I live in Arizona, I need it up for...
does it act the same whether you use the driver door switch or the passenger door switch? Please rate as fixya if this helps. thanks
here's repair procedure
Window Regulator, Front Door, Explorer Removal
srk~us~en~file=ani_caut.gif~gen~ref.gif WARNING: IF THE REGULATOR COUNTERBALANCE SPRING MUST BE REMOVED OR REPLACED FOR ANY REASON, MAKE SURE THAT THE REGULATOR ARMS ARE IN A FIXED POSITION PRIOR TO REMOVAL TO PREVENT POSSIBLE INJURY DURING C-SPRING UNWIND.
  1. Remove front door trim panel and front door trim shield . Refer to Section 01-05B .
Trim Panel, Front Door, Explorer Hi-Series, Two-Door and Four-Door Removal and Installation
  1. Remove the two screws retaining the front door trim panel (23942) located above the window regulator handle (23342) . Also remove one screw in the upper front portion of front door trim panel .
  1. Remove inside door handle cup (22634) at the window regulator handle using a screwdriver or sharp object. Retention nibs will flex for easy removal.
  1. To remove window regulator control switch (14529) and outside rear view mirror control (17B676) , use notch located at lower end of outside rear view mirror control using a screwdriver to lift and remove.
  1. Remove outside rear view mirror control from front door trim panel pulling wire harness from inside of front door trim panel .
  1. From bottom of outside rear view mirror control, remove two screws and disconnect connector from switches. NOTE: Do not pull on the front door trim panel to remove clips from the inner panel holes.
  1. At each plastic clip location, pry the front door trim panel away from the door inner panel using the front door trim panel removing tool from Rotunda Moulding Trim Kit 107-00401 or equivalent. NOTE: Pay special attention to the cut-out in the door trim panel for the door handle, so that it clears the handle during removal without breakage.
  1. When wiring and disengagement of trim clips is completed, it is recommended that to remove panel, lift slightly to remove flange at the top of door trim panel from trough in the glass weatherstrip.
  1. Disconnect socket and bulb from illuminated interior lamp (13776) before total removal of front door trim panel. For installation, follow removal procedures in reverse order. Replace any bent, damaged or missing plastic clips on the front door trim panel to the front door trim panel , firmly loading clips into slots provided on front door trim panel .
    Trim Panel, Front Door, Explorer Hi-Series Four-Door
  1. Remove inside door belt weatherstrip and glass stabilizer.
  1. Remove front door window glass as described in this section.
  1. Remove two nut and washer assemblies attaching the equalizer bracket.
  1. Remove three rivets (manual) or four rivets (power) attaching the regulator base plate to front door trim panel finish panel (23712) .
  1. Remove window regulator electric drive and front door window channel bracket from vehicle.
  1. Working on a bench, carefully bend tab flat to remove arm slides from front door window channel bracket .
  1. Install new window regulator electric drive arm plastic guides into front door window channel bracket and bend tab back to 90 degrees. Use care not to break tab; if tab is cracked or broken, replace front door window channel bracket . Make sure rubber bumper is installed properly on new front door window channel bracket , if replacement is made.
Installation
NOTE: The front door window channel bracket and window regulator electric drive are installed into the vehicle as one assembly. The front door window channel bracket may be disassembled from the window regulator electric drive as described in Steps 7 and 8 of Window Regulator, Removal.
  1. Install front door trim panel finish panel with preassembled glass bracket into vehicle. Set the regulator base plate to window regulator electric drive using base plate locator tab as a guide.
  1. Install three (manual) or four (power) rivets (385189-S100) to attach regulator to front door trim panel finish panel . Two 1/4-20 x 1-inch bolts and two 1/4-20 nut and washer assemblies may be used as alternates for glass retention. However, torque must not exceed 4-7 Nm (3-5 ft-lb). Equivalent metric retainers may be used.
  1. Install equalizer bracket.
  1. Install inside door belt weatherstrip and glass stabilizer.
  1. Lower regulator arms to access holes in front door trim panel finish panel . Install front door window glass as outlined.
  1. Adjust glass to ensure proper alignment with glass run. Cycle glass for smooth operation.
  1. Install front door trim panel and front door trim shield . Refer to Section 01-05B .
Apr 20, 2009 | 1994 Ford Explorer Limited
Frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
May 05, 2008 | Frigidaire FGR341AC Electric Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
110 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
