Hoover Nextra HNWL 3126 Front Load Washer / Dryer Logo
A
Anonymous Posted on Jan 10, 2011
My washing machine Hoover nextra 6 has stopped working I was in middle of wash and saw that I had a peice of clothing jammed out of the door and it was leaking water so I turned it off waited for when I could open door once allowed to open door I put clothing in machine and tried to start wash but it will not go the start light is just flashing on and off even when I turn off by wall it won't reset
pro appl ser
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 75 Answers
  • Posted on Jan 10, 2011
pro appl ser
Expert
Level 2:
New Friend:
Cheetah:
Answers
75
Questions
0
Helped
10957
Points
209
It may be a stuck cycle. try to unplug it for 20-30 min and try again.
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
2helpful
2answers
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
17helpful
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
2answers
Draining & Spinning
I had a problem and when they took the back off. Underwire bra had got jammed through drum holes which stopped it spinning and water issues. I hope this might help.
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
