Sony Playstation 3 (PS3) Console Logo
Posted on Jan 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The console when switched on goes red firstly then green for a second and then stays flashing red.
Anonymous
Level 3:
  • Master 943 Answers
  • Posted on Jan 10, 2011
Anonymous
Master
Level 3:
Answers
943
Questions
0
Helped
163037
Points
2880
This is mostly as a result of software failure or problem. This occurs mostly when there seems to be an error in the system of the console.
You can decide to send it to a repairer or send it to sony for check up and maintenance but first it is quite advisable that you try to reset your console and see if that would help you.
You can do this by following the procedures below
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Hope this solution helped you? Please comment for more information and thank you for using fixya.
Ps3 does not turn ON
looks like the YLOD, you can search some fixes of refloating the solder with a heat gun or take it to a repair shop. lastly and most expensive is sending it into sony assuming its out of warranty if it is its 150 to fix it. If still under warranty then call them asap.
Flashing red light
it would make a goooooooood trafic light
1helpful
Ps3 will not switch on. The green light turns orange than red
This is known as the yellow light of death (ironic i know because it blinks red). This is caused when the unit overheats causing the solder on the board to melt and bridge(connect). Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty.
2helpful
4answers
My Ps3 is only staying on for 4 seconds (green for 2 seconds and yellow for 2 seconds) and then flashes red. when i tap the power button it stays red and repeats.
call sony the problem can be several things
call sony even if your console is out of warenty
i had the same problem a couple of months back and warenty was expired by a few months i called them and they gae me a refurbished ps3 free
My ps3 it goes green beeps twice then goes red and flashes on/off
you might be holding the power on button to long. you hold the power on button until it beeps to reset the video output. try turning it on by using your controller. just press the ps3 button and if the red light is on then it should come on.
SLIMLINE FAULT PLEASE HELP
try holding the button wen its at standby for about 3 seconds..it should stay green after that..mine did that for a while too but then i held it for a while n it workd
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
