Question about Epson Stylus CX6600 All-In-One InkJet Printer
Broken printer I had a misfeed in my printer and took the paper back out of the machine while it was half way through. Now it makes a horrible noise like a dying refrigerator, and it keeps saying I need to load paper, even though there is paper in it. Can it be fixed or do I need to trash it and get another one?
    Genius:
  • 1,447 Answers
Hi-
You can have that fix but might cost you as much as buying a new one, suggest you call epson 562-276-4382 and ask for a servicer and loyalty website and passcode for you to compare prices.
Hope this help! Thanks for using Fixya!
Posted on Jul 12, 2008
Samsung printer ML 1860 knocking noise
The only answer I'm afraid is to visually inspect to see what's knocking. Look for misfeeds and paper jams, they are the most likely problems
Jun 25, 2014 | Samsung A4 Mono Laser Printer Refurbished...
Tip
How to retrived your machine from misfeed or stacking up in fuser unit
first introduction misfeed have alot of places in machin copiers actually some times trays is not convenient with criterion on machine that mean yo have tray a4 horizontal if yo made a3 it's make misfeed and fuser unit make misfeedes in fingers may broken and may cooler roller accumulate on it masses of burned toner make heavy load on fuser unit mechanism
on Apr 22, 2011 | Office Equipment & Supplies
How removed misfeed indicated problem?
a miss feed mean the roller could not get the paper, so clean the roller (s) or have them replaced, try a different paper draw
Jun 25, 2014 | Konica Minolta Di2010 Di2510 Di3010 Di3510...
A misfeed has occurred
If this is a regular home-use printer, a misfeed usually indicates a jam when the printer is pulling blank paper from the tray. The most likely solution is to just clear the jam (gently but firmly pull any stuck paper out of the machine), make sure the paper tray is adequately filled (not overfilled, and make sure the paper is all the way in so the rollers can reach it), and hit the okay button on the printer. (If your printer has no okay button and there's no message box appearing on your monitor, then restart the device.)
If that doesn't work, then more specific information (brand, model, your computer's operating system) might help determine the cause of the problem.
Mar 21, 2011 | Office Equipment & Supplies
Paper stops half way, I get a message saying it's a paper jam or misfeed, but I can't find anything jammed
try to shutdown your printer and then ....arrange the paper properly on the tray or add some ..and then print an alignment page on it.....
May 17, 2009 | HP PSC 1315 All-In-One InkJet Printer
PAPER JAM
If you pull the drum out of the machine. Close front cover. is the noise still there. If it is then you have a broken fuser gear. If noise is not there remove the toner cart. from drum reinstall the drum unit in machine see if noise is there. if noise is there then it will be the drum. If not reinstall the toner try that if noise comes back then it is your toner cart.
Apr 11, 2009 | Brother IntelliFAX 4100 Laser Fax
The machine gives a false error message.''misfeed A :internal path
Pull out paper cassett and look for paper in the feed section. Fold a sheet of paper in half and using the blue lever inside right side door feed paper between feed rollers. Make sure you do the whole width of feed section. There might be a small piece stuck you can't see.
Mar 11, 2009 | Ricoh Aficio CL7000 Laser Printer
My Lexmark all-in-one printer which I've had less than 2 months, began making a horrible noise and perforating the right side of paper.
Hi, If you are having this kind of problem so soon after buying the machine I would take it straight back and either get a replacement or a different machine altogether.
Nov 21, 2007 | Lexmark X5470 All-In-One InkJet Printer
How do I clear misfeed.
In most cases where the machine says there is a jam, and there is no paper in the paper path, it's because the paper never got out of the paper drawer and didn't reach the 1st jam sensor. If you can open the machine and it resets, then chances are the paper feed roller is either slipping or in some cases not turning at all. If you can't clear the jam by turning off the machine, and back on, then you have a bad jam setect sensor or perhaps a small piece of paper lodged on the jam sensor. This will take some additional troubleshooting on your part. Need to know if the jam indicator goes away when you restart the machine. Let me know and I'll try to guide you from that point. Aloha, Bill Monroe
Sep 17, 2007 | Ricoh Aficio 1018D Copier
Misfeeds
DEAR SIR WHERE YOU REMPVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEAZ CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Sep 16, 2007 | Sharp AR-M455N Copier
Epson Stylus CX6600 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
