Question about Microwave Ovens
Keeps blowing fuses whirlpool mc8130-1 hope someone can help thanks mike
  • Microwave Ovens Master
  • 9,086 Answers
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Please feel free to contact me directly if you need more help. And please mention your model number when you write.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 12, 2008
How do I fix a blown microwave fuse?
How to Fix a Microwave Oven - Simple Fuse Replacement ...
? 18:04
https://www.youtube.com/watch?v=IN0BqiVX5ds
May 21, 2013 - Uploaded by GuruBrew
How to Fix a Microwave Oven - Simple Fuse Replacement. GuruBrew .... I'm hoping it's just a blown fuse ...
Whirlpool Microwave Keeps Blowing Fuses - YouTube
? 2:35
https://www.youtube.com/watch?v=KGQgendKTR0
May 7, 2013 - Uploaded by AdamDIY
Whirlpool Microwave Keeps Blowing Fuses ... MicrowaveThermal Fuse Replacement - GE Microwave ...
Microwave Oven Repair 101 ' DoItYourself.com
Dec 06, 2015 | In Microwave Ovens
My Whirlpool microwave MT6120XEB-0 keeps blowing the fuse. Inststalled new fuse and display and timer works. Cooking blows new fuse. It turns on, makes grinding sound and blows a new fuse within a second...
You almost certainly have a shorted high voltage capacitor.
See the safety warnings and help information here.
Chances are you will have to remove the oven from the wall to replace it.
You can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 26, 2013 | Microwave Ovens
Whirlpool Microwave (model WMH1164XVS-1 ) does not turn on
This could be a lot of things. IT might be a capacitor or diode. MY money is on the capacitor. Since it works for a minute before it quits.
May 06, 2013 | Microwave Ovens
Whirlpool gold YGH5184XPS-0 fuse location, I believe i blew a fuse and cant find the location, the thing worked fine and then i shut the door and lost all power, either the door latch is broken or the...
Mike - Unplug the unit and unscrew about 4 screws on the top and then the side panel and the fuse will be in that location.
Note: If the fuse looks brown, it's definetly blown, you can get the same fuse at your local Radio Shack for about $0.97. hope this helps
Aug 14, 2012 | Whirlpool Microwave Ovens
THE MICROWAVE KEEPS BLOWING FUSES, AS SOON AS I HIT THE START BUTTON THE FUSE BLOWS.iT WILL KEEP THE TIME AND THE LIGHT WILL COME ON BUT AS SOON AS i HIT START IT BLOWS
Sorry to read about your problem, I hope this helps you out.
you have a defective control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Kenmore 63792 Microwave Oven
Oven lights won't come on, bulb good, no volt. to socket, is there a fuse
Well here is the delima...Customer changes one of the light bulbs without unplugging unit.....this allows a cap. to discharge on the main computer PCB and zaps the on/off light function.
Contact whirlpool customer service they may may help you out.
This is a known issue.
Hope this helps
Mike
Jan 09, 2010 | Whirlpool MH7130XE Microwave Oven
Fuse keeps blowing.
It appears like the high voltage capacitor is shorted or the diode connected to the capacitor. You might want to check the monitoring switch as well if the capacitor and diode are good.
Click here for more info on how to work around these high voltage devices.
Let me know if you need further assistance.
Oct 16, 2008 | Whirlpool MH6140XK Microwave Oven
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson Mwg9111sl microwave blows 20 amp internal fuse instantly everytime.
check your thermal fuse its about 2 inches long white on the outside black on the inside it has 2 wires going to it check for
cotinuity becareful of the capacitor you need to disapate that first by touching the two teminals together with a screw driver
Apr 01, 2008 | LG LTM9000 Microwave Oven
Fuse keep blowing up
You have a short in the system. removeing the fuse was not a good thing to do. The fuse in a microwave helps keep the system from an overload which can and I have seen this blow-up. The micro pump inside might have a dead short it,
Aug 30, 2006 | Whirlpool MH7130XE Microwave Oven
Microwave Ovens Logo
90 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
