Back to:
Tags:
CD and DVD Burners
Generic problem for all CD and DVD Burners
CD/DVD won't read (by 2 users)
posted by harleymonk on Jul 12, 2008
I have a dual boot 2000/XP system. This issue only occurs on XP and only recently without any changes to BIOS or XP system config.
1. I have CD and DVD master E:\ slave F:\ drives. If I boot with E:\ loaded, E:\ can read/write. If I then load F:\, it cannot detect a disc in the bay. If I open then close E:\, it still reads the disc in the bay. If I removed the disc, close E:\ then open and reload the disc, it no longer reads the disc. Still nothing on F:\
2. If I boot with E:\ empty and F:\ loaded the situation is reversed from number 1, above, i.e., F:\ is readable initially and E:\ is not. After opening and closing F:\ bay, it is no longer readable.
3. If I boot with both E:\ and F:\ empty, neither is readable.
4. If I do a hard boot with both E:\ and F:\ loaded, both are initially readable. Open and close F:\ an it become unreadable.
I have a custom machine: XP SP3; 2.4 gig Athlon 64; 1.1 gig RAM; both ROMs are TDK; the master/slave HDs are on the primary, the master/slave ROMs are on the secondary IDE.
It may be unrelated but I have also noticed lately the my modem (ZOOM V92) tends to freeze if I connect after I've been using other hardware devices like the ROM or scanner.
I am wondering if the BIOS IRQ assignments are all of a sudden not to XP's liking??
Any thoughts would be appreciated.
Thanks, Monk
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by saldivar00, posted on Aug 24, 2008
I have the same problem with my acer aspire 5100, my notebook will not detect the dvd drive. I did the regedit fix and it didnt work. I've done a driver scan and the dvd drive (matshita 850s) shows up and has the most updated driver, but the drive does not show up anywhere else on my computer not even in the device manager.
Best Solution
posted on Jul 24, 2008
Helpful (85)
kikoksky
Rank:Guru Guru
Rating: 85%, 69 votes
try this Step 1: Start Registry Editor loadTOCNode(3, 'resolution'); Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the Upper/lower Filters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value? The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
do same thing to erase the lower filter then restart your computer
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on CD/DVD won't read:
I don't want to Accept this solution
Can you Help with these CD and DVD Burners problems?
Medion (40002895) CD-RW/DVD-ROM (Combo)...
no sound want to download sund driner for free wiv out...
Mitsumi (CR-4804TE) CD-RW Burner
when i put in a cd disc it is not recognized-when i drag...
QPS Que! USB 2.0 Drive CD-RW Burner
My system can detect the icon for CD Drive but when i...
LG GSA-H42N 18x DVD RW DL IDE Drive (Black)...
can you send me..tnx..jane_mirabuna@yahoo.com.ph
NEC ND-3540A DVD RW Dual Layer Burner
Trying to transfer data using the Roxio creator 2009. The...
Loading problems.
Repair Service
Find CD and DVD Burner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
