Question about Car Audio & Video
JVC KD-s34 Both power cords have power. Yellow constant, red with ignition key.
  • 2,427 Answers
And the speakers are hooked up right ?
then it should be working..
did you check the fuses ?
did you check if it comes on with the car started?
are the wires the correct amp ?
try connecting both wires directly to the battery ?
if all that is correct then by all means you got everything hooked up corectly and it should work, return it to the store and have them check if its working correctly
Posted on Jul 13, 2008
I want when i turn my radio to start at the last channel i powered off in my JVC KD-G511 Car Radio
rewire it so that the red wire is constant 12 volts and yellow is ignition switch power
Jul 20, 2015 | JVC Car Audio & Video
KD- R538 radio wont turn on
Make sure you are getting power to both the red and yellow wires. Red is switched or ignition and yellow is constant and controls the memory of the radio.
Feb 12, 2012 | JVC Car Audio & Video
JVC radio operation instructions for model kd-S34
JVC has the manuals on their support site: http://books.jvc.com/booklist.asp?Model=KD-S34 . The direct link to the installation guide is: http://books.jvc.com/Download/138327414/GET0518-002A.pdf . The operating instructions are here: http://books.jvc.com/Download/138327414/GET0518-001A.pdf . If you want to buy a printed copy, see http://store.jvc.com/product.asp?Model=KD-S34 . Note you will need a program like Adobe Reader to read the files.
I hope this helps.
Oct 03, 2011 | Car Audio & Video
What color is the power wire
Black is ground (negative), red is switched or ignition +(positive) power, Yellow is constant +(positive) power.
Aug 05, 2011 | JVC Kd-a315
Wiring problem with jvc radio and Pontiac Montana, looks like everything is wired correctly. Connected yellow wire to dimmer and illumination wires in metra connector for Montana. Unit will eject a cd but...
YELLOW WIRE IS CONSTANT, SO YOU NEED TO FIND A CONSTANT POWER SOURCE. GET A TEST LIGHT, GROUND IT, AND TEST THE WIRES WITH YOUR CAR OFF AND KEYS OUT OF THE IGNITION. MAKE SURE IT HAS A GOOD GROUND. LET ME KNOW HOW THAT WORKS OUT.
Dec 02, 2010 | JVC Arsenal KD-AR200 CD Player
I have bought a jvc KD-AVX77 and every time I switch off the engine and take the key out all my settings go back to default! Can you please advise.
the yellow wire MUST be connected to constant power that stays on regardless of where the ignition key is. It isn't getting this and the memory wipes because of the power is lost when you turn off the key. The red power wire is the only one that should connect to a switched line (ie: goes off when the ignition switch is turned off).
May 27, 2010 | Car Audio & Video
JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Jun 10, 2009 | JVC KD-G200 CD Player
JVC KD-G110 car music system is taking CD and not getting played am not able to function any ...?
Hi. your radio has 2 power wires. A red one and a yellow one (with most decks) It sounds like your radio is getting only constant power but no "key on" power. Check your radio with the key on you should have power on both the red and yellow wires. If you are missing power on one of the wires theres your problem. If you have power on both wires then there is something internally wrong with your radio...
Sep 08, 2007 | JVC KD-G110 CD Player
Car Audio & Video Logo
164 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
