Question about Frigidaire FGQ332ES Gas Dryer
Timer the auto timer does not run down so the dryer will not shut off automatically.
  • merle512 Jan 04, 2009
    Hello
    I have a Kenore
    MOD 110646-2300
    SER MP2804457
    TYPE DWR ELE 2406028 FM54
    It will heat up and dry my clothes but it will not buxx or shut off
    I am tight on money right now and would like to try and not have to call out a repair company to fix it
    Thank you
    Champion:
  • 210 Answers
You need volt meter. test voltage to timer motor while running in time dry mode. if 120 volts, replace timer.
Posted on Jul 12, 2008
On my kenmore dryer 970-c82062-00 I can get all 3 timers to start but the heated automatic dry portion does not time out.
that model number doesn't come up,you sure that isn't the serial number?also does the dryer have heat,when you run it on time dry the timer just counts down like a clock,when on auto or more or less the heat comes on until the dryer heats to temp. the heat shuts off and the timer will advance,when the heat comes back on the timer stops moving,it will do this until the clothes are dry,if you do have heat you could have a bad sensor or a bad cycling thermostat but you'll have to check it with a meter.send the model number and i can help you better.
Feb 16, 2014 | Dryers
Dryer does not automatically shut off on auto mode. It will run continuosly. I see on the scematic there is 2 thermostats. any suggestions?
Is the dryer taking a long time to dry even in a timed cycle? Twice as long as usual? If so, replace the elements. (one coil of the 2 coil element set is likely burnt out. Some models just happen to need that working to feed power to the timer motor in the auto cycle)
Feb 05, 2011 | GE Dryers
The dryer will not shut off automatically. It would run forever if I let it. It also takes a very long time to dry the clothes. As if it's not heating them properly.
Well first of all you may try running the dryer with the vent hose removed. A slow vent will cause what you're describing. Then you'll need to look at the cycling thermostat. That is the part that tells the timer to advance. It sends a signal to the timer when the proper temp is achieved in the drum. Means when the element cycles off the timer motor moves a little bit. When it cools down and the element comes back on the timer stops. This action takes place when you're using one of the auto cycles.
If you have a slow vent it can cause the high limit thermostat to do the cycling. Please let us know for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Jan 26, 2011 | Hotpoint NLLR113EV Dryer
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
My kenmore 110.86273100 wont heat and the timer knob dosn't run down when running
if there is no heat the timer will not shut off in the auto dry seting. If a gas dryer possable bad thermo and fuse. Ele poss bad element
Dec 23, 2009 | Dryers
My dryer will automaticall start the auto dry
appears that timer is not timing out or shutting off at end of cycle.correct ,the timer itself appears to be the problem.
Oct 16, 2009 | Dryers
Gas dryer continues to run on the Auto cycle.
try to get the manual for the dryer you got and locate the moisture sensor if this sensor is bad what happen is that the automatic timer thinks that the clothes still wet and continues to dry once the sensor detects no moisture then it shut off the dryer normally is located behind the dryer on the exit line of the air duct and tested for conductivity and see if is good or not
Mar 27, 2009 | Amana DLG330RAW Gas Dryer
Electric dryer timer
the auto temp sensor is bad / Larry
Nov 01, 2008 | Kenmore 62602 Electric Dryer
Auto feature
Faulty selector switch or control card. There is the possibility of a faulty moisture sensor. Can you operate the machine in manual mode ?
Jan 26, 2008 | Whirlpool GEW9250 Electric Dryer
Frigidaire FGQ332ES Gas Dryer Logo
79 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
