Question about GE 25GT270 TV
GE 20GT320 TV
TV is about 10 yrs old. In setup mode i have autoprogram and below that i have channel memory. Channel memory has a stored or erased option and i have stored all channels that i normally get. When i select autoprogram the channel memory starts erasing all the channels that i have stored. Even as i store each channel one by one, they still will not come in. TV was given to me and when i first plugged it in i was able to get ten or so channels but since i tried auto program.....no channels. Thank you very much.
  • 1 more comment
  • mtcincny Jul 13, 2008
    Thank you very much for your input. I cannot find the manual or semi auto mode you are speaking of but somehow i was able to get channels 51 thru 79. I am almost certain it has something to do with the storing and erasing channels mode but i havent quite figured the trick to it. I searched google for a manual for this model of tv to no avail. Anyway thanks again.
  • Anonymous Oct 28, 2008
    pls how to get diagram this model thank you.
  • Anonymous Mar 26, 2014
    I am only able to store 2 channels on this TV I followed the steps to store but nothing saves
    New Friend:
  • 23 Answers
Don't use auto programme.
use manual or semi auto.
you have to press the auto programme button a few times.
Posted on Jul 13, 2008
Ge remote xs stereo TV Model# 19GT352
It sounds that the main system control memory IC to your TV is faulty. Replace it, and re-program it with initial data values. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 26, 2014 | Televison & Video
Accidentally pressed a button on the remote which has returned our 26' dynex rc701da hdtv to setup mode cannot get it set up again despite following instructions always ends up "plse run channel auto...
Hi:
The unit is telling you to run autoprogram to program in your channels, make sure also the TV is in cable mode and not TV mode which is for local channels, If you have cable do a autoprogram so the set can program in channels. Auto Scan is the same as autoprogram.
Mar 17, 2011 | Televison & Video
We have not had this tv on since went over to digital freeview built in hopwever just put it on and there are no channels stored how do we get channels?
Hello
Your TV has to be initilized. It should be retuned to get the channels memorized in its memory section. Then only you can get the channels stored. Hopes that you have its remote control hanset with you. Replace two new cells in it and proceed the folloing steps. Connect ariel to its back socket before doing these.
[1] Press power button on the front panel of your tv. The initial setup screen appears.
[2] Press Ch+ on the remote control handset or on the front panel of your TV to start auto program, or Ch_ button to exit.
The initial setup screen will appear each time you switch on the tv until you perform autoprogram.
To perform autoprogram again
[1] Press Menu button.
[2] Press to highlight Channel Menu
[3] Press Pr Dn button to hilight cable. Press [+] to select.
[4] Press Prog Up or Prog Dn to hilight On or Off according to how you connected your TV. Press [+] to select.
[5] Press Prg Dn to hilight autoprogram. Press [+] to search for channels.
[6] After autoprogram finishes, press "Menu" again to exit.
TO RESET THE TV TO FACTORY SETTINGS
[1] Turn TV on.
[2] Press and keep hold the "Reset' button on the remote control hanset.
[3] Press and release the "Power button" on the TV front panel. The TV will turn itsef off.
[4] Release "Reset Button" now from your hanset.
These are the processes to be done to either autoprogram or turn it to factory settings. Ok.
Oct 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Video mode on GE 27GT610
Try hooking up the dvd player and turning it on. Then use the setup and add/erase channel feature to look thru all of the channels. On my older GE tv I found that channel 91 was the correct channel for the video input. I saw the logo for the dvd player on this channel. I just added that channel and now it works. Your channel might be different.
Feb 22, 2009 | GE 27GT616 27" TV
Get channel 3 on tv with autoprogramming
When you select channels, the one that comes in the channel number will be green and if you manually select 03 it will probably be red. Hit menu and add channel 03
Jan 16, 2009 | GE 32GT740 32" TV
Doesn't get all cable channels
With the menu set to cable signals, the autoprogram should catch all of the cable channels. The Cable Channel option allows you to use either channel 3 or 4 as the "cable" channel. This is when you have an external box that you use to tune in cable rather than the TV directly. The easiest way here is to autoprogram the TV while playing a VCR tape. That will insure that channel 3 is included.
Does the autoprogram fail?
Dan
Aug 20, 2008 | Televison & Video
Channel Program/Setup
I have the same problem. Try to programa de ic u201v with the original program.
good look
Aug 05, 2008 | GE 27GT271 TV
Symphonic television
Use the original remote, or the menu button on the tv. Press menu. Find "setup" or "channels" or the word cable or autoprogram. Choose cable. Then choose autoprogram or find channels. It will scroll up all the channels and stop in a minute and store them all in memory. The words may be slightly different on your tv, but the procedure will work. Play around in the menus. You will find it.
Mar 25, 2008 | Televison & Video
GE 25GT270 TV Logo
356 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
