Casio CTK520L won't turn on
My jurassic Casio CTK520L electronic keyboard won't turn on when it fell on the floor. I opened it and everything's intact, and also tried turning it on with batteries, thinking maybe the adapter isn't working but still didn't work. Help!!!
  • 1 more comment
  • Anonymous Oct 21, 2008
    My casio won't turn on at all, i've tried batteries, plugs, everything! There doesnt' seem to be any wiers loose or broken
  • Anonymous Jan 01, 2009
    same thing here. I have CTK-573. I've tried new ac adaptor, batteries, and nothing works. It turned itself off a few times before it completely died. Can somebody help?
  • fernleyrodeoking Mar 10, 2012
    My slammed some guy over the head with my Casio CTK520L and now it wont turn one.. what do I do??
5 Suggested Answers
jitenok
  • 151 Answers
SOURCE: Casio CTK-710 Electronic Keyboard BUZZING
any key is in pressed position or short in side,or hot key is used
Posted on Feb 29, 2008
SOURCE: Casio CTK520L Electric Piano
I WANT THE SIT OF MORTHER BOARD KEYBOARD CASIO 671
Posted on Dec 09, 2009
sawdust46694
  • 398 Answers
SOURCE: Logitech CE0560 keyboard and mouse; first keyboard
First put new batterys in the mouse and key board. if you don't have a tester use a flashlight. pen light. push the remote pickup. light will blinknext push key board button and the mouse next. then try it and see if it works.
sometimes do the mouse first, Then the key board
Posted on Aug 10, 2009
  • 3 Answers
SOURCE: My casio keyboards ac adapter does not power up
Try this out- check for a blown fuse. If you have never done this before, here is a simpler step by step procedure-
1. If you have the tools and little bit of adventurous spirit, I would suggest you open the keyboard and check for a fuse (a small glass tube with a metal wire running through it).
2. Pull it out and look at it against a light source (like a window) check if the wire if cut (that means the fuse is blown).
3. If it is not blown, put it back, if is blown find a shop that sells it- an electronic spare part shop that stocks stuff for TV, and computer spare will have it). Get a new one and put it in.
4. Try plugging the adapter again.
Best of luck...
Posted on Aug 20, 2009
My Casio keyboard 2100 won't turn on
check the batteries and then press the reset button on the back.
Jun 07, 2013 | Computers & Internet
Casio keyboard ctk 2100 won't turn on
Do you have dead batteries, remove and use the adaptor only - try again.
Oct 21, 2012 | Casio CTK-2100 - 61 Key Portable Keyboard...
Manual Casio CTK-650
Hi! When I turn on my keyboard it shows "03.2" on the multifunction display and the lights of "Split", "Digital effect" and "Touch response" remain "ON" and in someway it get blocked for the most of the functions. I cannot turn off that lights. Please, help me!!! You can answer me to dramosm@hotmail.com Thank you very much
Sep 30, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
I have a Casio Privia & I believe liquid fell unto the keyboard & as a result 8 notes do not have any sound. How can I get this repaired? I bought this 3 years ago.
You can try to dry the inside of the keyboard by taking the end of the key board off.
Take a hair dryer and place it at the end of the keyboard and let the air dry out the fluid this may take some time depends on how much fluid you have inside.
Do not use the dryer on high because the heat will warp the bed the keys fit into, this will damage the board which cost about $ 400.00 to repair. Do not turn on the key board while the fluid is still inside this can also damage the keyboard. I belive you have already turn it on because you said eight keys do not work.Do not open the keyboard because the keys will be hard to put back in the grooves the way they were.
You can try and have it repaired at American Perfect Crystal Corporation
Casio Parts Distributor 520 Eight Ave. 2nd Floor
New York, New York 10018
212-246-8292
800-345-0537
sales@americanperfit.com
www.americanperfit.com
They will charge about 50-89 dollars to check it for you and if its reparable the checking fee will go toward the repair.
I wasted kool-aid in my casio privia while the keyboard was off, but made a grave mistake because I tried to repair it my self with the hair dryer at a high level. I was told that the major board was warp, that being said try not to do self repair.
Oct 05, 2010 | Casio Privia Keyboard Case
I have connected my casio to pc but pc songs and piano sound is not hearing in pc how it will work if any driver will use tell me about that i have casio ctk-2100 electronic keyboard
ASSUMING you have a MIDI interface connection, (not audio) then you need to set the PC to use a general MIDI sound and turn on the synth in the PC.
Go to control panel and open the sound icon. Select the device to use for MIDI playback in the appropriate section.
Sep 19, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
My camera fell and the lens is stuck!
Hi there, after fall in the floor , your camera's lens guider is broken & thats why its not able to came out fully & not doing proper focusing. Replace the lens guide pin. After that it will work fine like before. Thanks.
Feb 25, 2010 | Casio Exilim EX-S500 Digital Camera
Camera fell on the floor (carpet) and now the
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
http://www.fixya.com/support/t102982-e_18_problem
Mar 23, 2009 | Casio Exilim EX-Z750 Digital Camera
How to do a master reset a casio ctk 496
According to the manual for the 496, "All keyboard settings are returned to their initial defaults whenever keyboard power is turned back on after being turned off by operation of the Power/Mode switch or Auto Power Off.
Nov 26, 2008 | Casio Ctk 496 Electronic Keyboard with 61...
Computers & Internet Logo
948 people viewed this question
David Payne
David Payne
