Question about Motorola Mobility RAZR V3xx Cellular Phone
Keypad light how to on the keypad light.
  • g_jagansisi Jul 12, 2008
    my theme was corrupted how to repair it.
  • Anonymous Feb 22, 2009
    where is the flex cable in the v3xx
    Brigadier General:
  • 7,752 Answers
If the keypad lit is not coming on the flexcable needs to be replaced
Posted on Aug 18, 2008
The number illumination has gone out. How to fix?
My keypad won't light up when door is locked when you push lock won't light up green:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Jan 07, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
No backlight or key pad light nokia e71
There is a light sensor in your Nokia E71
This light sensor senses the outside light and activates the keypad light accordingly.
When you have enough backround light the keypad light wont light up.If the background light is less then the keypad light wil light up.
You dont get the keypad light ON because the light sensor might have activated.
If in dark also you wont get the keypad light on then the fault lies with the keypad light unit.please give your mobile to the nearest authorised service centre for service.
Jul 26, 2010 | Nokia E71 Smartphone
Keypads will not respond. Either can't turn on or
Possible power supply problem--low voltage from master unit or dead batteries at each switch. Good luck!
Jul 25, 2010 | Lutron Electronic Low-Voltage...
My keypad light is not on
Have your keypad lights replaced.
Sep 21, 2009 | Nokia E71 Smartphone
Lock 9 light is on
The numeric keypad functions like the numeric keypad on an external keyboard. Each key on the keypad has multiple functions. The keypad numbers and symbols are marked in blue on the right of the keypad keys. To type a number or symbol, hold down <Fn> and press the desired key.
  • To enable the keypad, press <Num Lk>. The keyboar2.jpg light indicates that the keypad is active.
  • To disable the keypad, press <Num Lk> again.
Mar 20, 2009 | Dell Latitude D410 Notebook
Keypad for chamberlin garage door opener stopped working
You need to reprogram the keypad. Press and release the learn button on the back of the motor. Within 20 seconds, press your four digit code into the keypad and press and hold the enter button until the lightbulb on the motor blinks once. You are finished.
Feb 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad light wont turn on
It is the problem of your ribbon flex that is connector..
If you have not a good hand you cant do it. Take it to a Motorola Repair Center.
I'm sure the phone will be full functional again.
May 19, 2008 | Motorola Mobility SLVR L7 Cellular Phone
How do I use Dell inspiron 1300 keypad?
If you are referring to the Number keypad.
Tap the "Num lock" key and you will see a light flashing.
Make sure the light is on when you stop.
Now try the keypad.
Mar 15, 2008 | Computers & Internet
Keypad light n display light not working
display light and keypad not working i have changed keypad light ic and keypad coil what to do?
Jan 11, 2008 | Nokia 6070 Cellular Phone
Motorola V265
1 of two things: Go into your settings and look for either "Keypad" or "Display" and see if keypad lights are set to ON.
2. Your phone does have a light sensor built into the keypad, normally the keypad will not illuminate unless insufficient lighting conditions are present. If it's pitch black out and the keypad still isn't illuminating and your settings have the keypad lights ON .... You should bring your phone to the nearest Verizon wireless corporate store to see about either replacement or upgrading.
Dec 19, 2007 | Motorola Mobility V265
Motorola Mobility RAZR V3xx Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
